Author Topic: [VB.NET] - Struggling with some code  (Read 7091 times)
Matt__W
  • I like my water diluted.
Re: [VB.NET] - Struggling with some code
« Reply #15 on: December 09, 2011, 02:23:27 PM »
Of course not good coding practice hard-coding values, should be broken, etc...........
but here is some code to maybe get you started that just prints all the attribute reference's to the command line, and of course you need to change the drawing path.
         <CommandMethod("OpenDrawingInSideDatabase")> _
        Public Sub OpenDrawingInSideDatabase()
            Dim doc As Document = Application.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
            Using sideDb As New Database(False, True)
                sideDb.ReadDwgFile("C:\Testing\AutoCAD\AttTest.dwg", FileOpenMode.OpenForReadAndAllShare, False, "")
                Using trx As Transaction = sideDb.TransactionManager.StartTransaction
                    Dim bt As BlockTable = trx.GetObject(sideDb.BlockTableId, OpenMode.ForRead)
                    For Each btrId As ObjectId In bt
                        Dim btr As BlockTableRecord = trx.GetObject(btrId, OpenMode.ForRead)
                        If btr.IsLayout Or btr.IsFromExternalReference Or btr.IsDependent Then
                            Continue For
                        End If
                        If btr.HasAttributeDefinitions Then
                            Dim brefIds As ObjectIdCollection = btr.GetBlockReferenceIds(True, False)
                            For Each brefId As ObjectId In brefIds
                                Dim bref As BlockReference = trx.GetObject(brefId, OpenMode.ForRead)
                                For Each attRefId As ObjectId In bref.AttributeCollection
                                    Dim attref As AttributeReference = trx.GetObject(attRefId, OpenMode.ForRead)
                                    ed.WriteMessage("{0}{1} = {2}{0}", Environment.NewLine, attRef.Tag, attRef.TextString)
                                Next
                            Next
                        End If
                    Next
                End Using
            End Using
        End Sub
I'll have to disect this next week.  Seems everybody wants everything NOW!!
Thanks!  :)
Autodesk Expert Elite
