Author Topic: Export coordinates of points in order  (Read 7473 times)
Coder
« on: December 05, 2011, 03:36:25 PM »
hello .
I have a problem with exporting coordinates of points to a txt file ( but according to their coordinates from bottom to top ) .
I couldn't come up with any code with my poor knowledge of programming . :oops:
Is that possible ?
Thanks in advance
danallen
Re: Export coordinates of points in order
« Reply #1 on: December 05, 2011, 03:46:07 PM »
Can you bring into excel and just do a sort on the Y column?
« Reply #2 on: December 05, 2011, 06:46:57 PM »
vl-sort
Coder
« Reply #3 on: December 05, 2011, 11:38:20 PM »
Thanks .
I tried vl-sort function but it needs a list ( according to what I read from help ) and my routine is not working .....
Please take a look .
(setq myfile (getfiled "save path" ""  "txt" 1))
(setq myfile (open myfile "w"))
(setq ponts (ssget '((0 . "POINT"))))
(setq n 0)
(repeat (sslength ponts)
  (setq sspts (ssname ponts n))
  (setq entgets (entget sspts))
  (setq xyz (cdr (assoc 10 entgets)))
  (vl-sort xyz ??????<<<- I don't know how to sort them in sequence ( the coordinates of points )
   (setq n (1+ n))
(close myfile)
danallen
« Reply #4 on: December 05, 2011, 11:55:21 PM »
here is a way to sort list of points
;;; Sort a list of 3d elements
;;; From: "Tony Tanzillo" <tony.tanzillo at caddzone dot com>
;;; Newsgroups: autodesk.autocad.customization
;;; Subject: Re: How can I sort a list of 3d points?
;;; Date: Wed, 19 Mar 2003 10:37:20 -0500
;;; You can use vl-sort, with a comparison function that
;;; weights the ordinates in whatever way you want.
;;; Here's an example that gives the greatest weight
;;; to the X ordinate, and the least weight to the Z
;;; ordinate:
;;; sort on three keys (x, y, and z)
  (defun-q compare-points (a b / fuzz)
     (setq fuzz 1.0e-6) ;; comparison precision
     (if (equal (car a) (car b) fuzz)
        (if (equal (cadr a) (cadr b) fuzz)
           (> (caddr a) (caddr b))
           (> (cadr a) (cadr b))
        (> (car a) (car b))
;;; example  (vl-sort <list-of-points> 'compare-points)
;;; If you search this newsgroup, you'll find a much
;;; more powerful sorting function along with a good
;;; discussion on why (vl-sort) can be very dangerous.
;;; For that reason, I suggest you replace the built-in
;;; vl-sort with this:
(defun-q vl-sort (lst func)
   (mapcar
     '(lambda (x) (nth x lst))
      (vl-sort-i lst func)
;;; This will ensure that (vl-sort) does not remove
;;; elements that it sees as equal.
;;; LSORT.LSP  Copyright 1992-98  Tony Tanzillo  all rights reserved
;;; Merging complex list sort
;;; LSORT.LSP implements a modified version of the classic
;;; merge sort algorithm that sorts arbitrarily-complex lists
;;; using a caller-defined relational predicate function.
;;;  (lsort <list> <OnCompare>)
;;;  <OnCompare> is a function that takes two arguments,
;;;  and returns non-nil if the first argument is greater
;;;  than the second, or nil otherwise. The arguments are
;;;  the elements of the list to be sorted. This argument
;;;  must be quoted.
;;;  The default sort order is descending. To change the
;;;  sort order to ascending, the <OnCompare> function can
;;;  return the logical complement (not) of it's result.
;;; Examples:
;;;  1.  Sort a list of coordinates on the Y-component:
;;;      Assume unsorted data is in 'UNSORTED
;;;    (setq sorted
;;;       (lsort unsorted
;;;         '(lambda (a b)
;;;             (> (cadr a) (cadr b))
;;;  2.  Sort a list of entity names by layer:
;;;    (setq sorted
;;;       (lsort unsorted
;;;         '(lambda (e1 e2)
;;;            (> (cdr (assoc 8 (entget e1)))
;;;               (cdr (assoc 8 (entget e2)))
;;;  3.  Sort a list of coordinates on multiple
;;;      keys (first by the X ordinate, and then
;;;      by the Y ordinate):
;;;     (setq epsilon 1e-6)
;;;     (defun-q compare-points (p1 p2)
;;;        (cond
;;;           (  (equal (car p1) (car p2) epsilon)  ; if x are equal,
;;;              (> (cadr p1) (cadr p2)))           ; then compare y,
;;;           (t (> (car p1) (car p2)))             ; else compare x
;;;     (setq sorted (lsort unsorted 'compare-points))
(defun-q lsort (input OnCompare / fun)
   (setq fun (cond (OnCompare) (t '>)))
   (lsort-aux input)
(defun-q lsort-aux (input)
   (if (cdr input)
      (  (lambda (tlist)
            (lsort-merge
               (lsort-aux (car tlist))
               (lsort-aux (cadr tlist))
         (lsort-split input)
      input
(defun-q lsort-split (right / left)
   (repeat (/ (length right) 2)
      (setq
         left (cons (car right) left)
         right (cdr right)
   (list left right)
(defun-q lsort-merge (left right / out)
   (while (and left right)
      (if (apply fun (list (car left) (car right)))
         (setq
            out (cons (car left) out)
            left (cdr left)
         (setq
            out (cons (car right) out)
            right (cdr right)
   (append (reverse out) left right)
Coder
« Reply #5 on: December 06, 2011, 01:53:33 AM »
Thank you danallen .
I am sorry , I don't know which code to use form all of these you thankfully posted .
Would you please show me the one suits my situations ?  :-)
pBe
« Reply #6 on: December 06, 2011, 04:25:45 AM »
(Defun c:test (/ myfile ponts n sspts entgets xyz pts)
(setq n 0)
  (setq pts (cons xyz pts))  (setq n (1+ n))
(foreach pt_
(vl-sort pts
  (function (lambda (y1 y2) (< (cadr y1) (cadr y2))))
(write-line(strcat  (rtos (car pt_) 2 2)
              "," (rtos (cadr pt_) 2 2) ","
              (rtos (last pt_) 2 2 )) myfile)
  )(close myfile)
« Last Edit: December 06, 2011, 05:15:32 AM by pBe »
Coder
« Reply #7 on: December 06, 2011, 05:05:07 AM »
something wrong ... :-(
Error: too many arguments
pBe
« Reply #8 on: December 06, 2011, 05:18:55 AM »
I updated the post <<somehow the formatting doesnt work with my browser>
anyhoo. all i did is add this lines to your original code
(setq pts (cons xyz pts)) after (setq xyz ....
(foreach pt_
(vl-sort pts
the text format will
27.26,-13.21,0.00
474.91,62.52,0.00
255.57,120.31,0.00
Depending on your rtos argument
Add not re-write so you may understand better yourself
« Last Edit: December 06, 2011, 05:39:08 AM by pBe »
Coder
« Reply #9 on: December 06, 2011, 05:22:30 AM »
The same error .. / i think you just removed the codes that belong to bold chars in the routine .
_$
pBe
« Reply #10 on: December 06, 2011, 05:35:44 AM »
_$
Yes thats what exactly what I did coder  :-D
try it again
Coder
« Reply #11 on: December 06, 2011, 05:53:31 AM »
I think the problem is with vl-sort function without a list , but not sure  :realmad:
pBe
« Reply #12 on: December 06, 2011, 06:29:08 AM »
pts is the list
(vl-sort pts  (function (lambda (y1 y2) (< (cadr y1) (cadr y2))))
Tell you what, close your file and try again you probably have too many floating variables
..  and check (defun c:test ( /   myfile ponts n sspts entgets xyz pts) <---- "/"
ribarm
  • Marko Ribar, architect
« Reply #13 on: December 06, 2011, 06:32:54 AM »
pts is list of xyz points... And it is written (vl-sort pts (function (lambda ...)))... But I was ab to ask why is vl-sort function dangerous to use like its written here :-o
M.R.
M.R. on Youtube
pBe
« Reply #14 on: December 06, 2011, 06:39:48 AM »
i beleive vl-sort has the tendency to remove duplicates hence its dangerous
