Author Topic: Function  (Read 7382 times)
AWW
Function
« on: December 02, 2011, 01:38:41 PM »
I've been analyzing code and putting comments on it but am stuck on the "function". I can't seem to grasp what it actually does. Here is the code with comments:
[code]  (cond (  (< (length pts) 2))
;if the # of elements in the list is less than 2
        (  (vlax-invoke-method spc 'AddLeader
     ;then draw leader in active space using addleader method
     (vlax-make-variant
       ;and create a variant data type
       (vlax-safearray-fill
;and store data in the elements of a safearrya
(vlax-make-safearray vlax-vbDouble
   ;and create a single-dimension safearray consisting of doubles
   (cons 0 (1- (* 3 (length pts)))))
;and return # of elements in list (integer). multiply by 3.
                                  decrement by 1. add 0 to beginning of list.
(apply (function append) pts)))
From the help files:
Function - Tells the Visual LISP compiler to link and optimize an argument as if it were a built-in function
What exactly does this mean? Thanks for any elaboration.
« Last Edit: December 02, 2011, 01:53:11 PM by AWW »
Re: Function
« Reply #1 on: December 02, 2011, 01:52:09 PM »
The function function tells the AutoLISP interpreter that the supplied symbol is to be interpreted as a functional argument (rather than a quoted symbol). This improves performance when the code is 'compiled' (to a .fas file for example) since the functional argument can be optimised like a standard built-in function.
Performance aside, it will achieve the same results as supplying a quoted symbol:
(mapcar '+ '(1 2 3) '(4 5 6))
==> (5 7 9)
(mapcar (function +) '(1 2 3) '(4 5 6))
==> (5 7 9)
(mapcar (function +) (quote (1 2 3)) (quote (4 5 6)))
==> (5 7 9)
All of the above are equivalent.
gile
  • Marseille, France
Re: Function
« Reply #2 on: December 02, 2011, 02:10:19 PM »
From thes tests I did (but I don't do so much), I didn't notice any optimisation while using function with built-in functions nor with 'defun' functions.
I only noticed an optimisation with 'lambda' function.
Re: Function
« Reply #3 on: December 02, 2011, 02:37:20 PM »
Here is a quick test I threw together, though perhaps not too conclusive with such a simple lambda function being tested...
Phase 1: Testing Lambda Function:
The Functions:
(defun UncompiledQuoted ( lst )
    (mapcar '(lambda ( x ) (+ x 5)) lst)
(defun UncompiledFunction ( lst )
    (mapcar (function (lambda ( x ) (+ x 5))) lst)
(defun CompiledQuoted ( lst )
(defun CompiledFunction ( lst )
[ The 'CompiledQuoted' and 'CompiledFunction' functions were compiled to an Optimised & Linked .fas file ]
Constructing a test list:
_$ (setq lst '(0 1 2 3 4 5))
(0 1 2 3 4 5)
_$ (repeat 5 (setq lst (append lst lst)))
(0 1 2 3 4 5 0 1 2 3 4 5 ... 0 1 2 3 4 5)
_$
The Results:
_$ (Benchmark '((UncompiledQuoted lst) (UncompiledFunction lst) (CompiledQuoted lst) (CompiledFunction lst)))
Benchmarking .................Elapsed milliseconds / relative speed for 16384 iteration(s):
    (COMPILEDFUNCTION LST).......1482 / 1.72 <fastest>
    (UNCOMPILEDFUNCTION LST).....1841 / 1.38
    (UNCOMPILEDQUOTED LST).......1887 / 1.35
    (COMPILEDQUOTED LST).........2543 / 1 <slowest>
Phase 2: Testing In-Built Function:
The Functions:
    (mapcar '1+ lst)
    (mapcar (function 1+) lst)
    (mapcar '1+ lst)
The Results (Using the same test list):
Benchmarking ..................Elapsed milliseconds / relative speed for 32768 iteration(s):
    (COMPILEDQUOTED LST).........1794 / 1.05 <fastest>
    (COMPILEDFUNCTION LST).......1810 / 1.04
    (UNCOMPILEDFUNCTION LST).....1840 / 1.03
    (UNCOMPILEDQUOTED LST).......1888 / 1 <slowest>
« Last Edit: December 02, 2011, 02:43:30 PM by Lee Mac »
AWW
Re: Function
« Reply #4 on: December 02, 2011, 02:58:48 PM »
What I gather is that "+" (your example) and "append" (my example) are functions, but can also be symbols as well.
I tried coding (my example) the other ways that you had listed and I always got "pts bad argument type". Am I missing something there?
Is function used more for performance reasons then?
What happens here is the list of arguments is passed and appended together, I think
« Last Edit: December 02, 2011, 03:16:30 PM by AWW »
Re: Function
« Reply #5 on: December 02, 2011, 03:31:37 PM »
Perhaps bad way of phrasing on my part, 'append' and '+' are [protected] symbols and also functions.
You could code your example in one of two ways:
(apply 'append pts)
Other than aesthetics, yes, function is used for performance in compiled code.
(apply (function append) pts)))What happens here is the list of arguments is passed and appended together, I think
(apply '<function> (<arg1> <arg2> ... <argN>)
Is equivalent to:
(<function> <arg1> <arg2> ... <argN>)
As an example:
(apply 'append ((1 2 3) (4 5 6) (7 8 9)))  <==>  (1 2 3 4 5 6 7 8 9)  <==>  (append (1 2 3) (4 5 6) (7 8 9))
VovKa
  • Ukraine
Re: Function
« Reply #6 on: December 02, 2011, 03:47:44 PM »
+1
function cannot compile what is already compiled and thus there's no speed optimization.
AWW
Re: Function
« Reply #7 on: December 02, 2011, 03:51:54 PM »
Seems to be one of those preference situations. As they say, more than one way to get things done. Thanks for the clarifications Lee. Much appreciated!
Re: Function
« Reply #8 on: December 02, 2011, 04:07:43 PM »
You're welcome, I'm glad my explanations were somewhat comprehensible  :-)
thuphong
Re: Function
« Reply #9 on: December 02, 2011, 07:14:53 PM »
Thanks Lee Mac :ugly:
« Last Edit: December 03, 2011, 01:45:27 AM by thuphong »
BlackBox
Re: Function
« Reply #10 on: December 03, 2011, 02:20:49 PM »
*Still processing*... Cheers, mate! :beer:
Re: Function
« Reply #11 on: December 03, 2011, 08:27:28 PM »
lol cheers dude  8-)
dgorsman
Re: Function
« Reply #12 on: December 05, 2011, 10:39:54 AM »
I've used (function...) once or twice when creating LISP code on-the-fly where the single-quote was giving the parser fits.  Might also work the same for those using in-line LISP in command macros in the CUIx.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
BlackBox
Re: Function
« Reply #13 on: December 05, 2011, 12:44:09 PM »
Interesting point; I've honestly never considered putting a good Mapcar + Lambda combo inside a macro before... Not that I will now, but I've always simply added an If Statement to my Macros to load the LISP (if unavailable), then call the function.
