Author Topic: ACAD-Array  (Read 7214 times)
theluck19
  • ABC (ADDICTED to BOOZE & CAD.)
ACAD-Array
« on: December 02, 2011, 04:07:06 AM »
In micro station V8i there is an option to array objects as per a polyline's path. However autocad has only rectangular/polar options.
Currently i am using offset-divide-copy-paste method. Is there a quickerway or does someone have a program that does this?
Am using AutoCAD 2007
Cheers. :lol:
Win 10 Pro 64+AutoCAD 2019
Re: ACAD-Array
« Reply #1 on: December 02, 2011, 06:19:40 AM »
Cheers. :lol:
The bad news is that 2012 supports this type of array (now).  However I won't tell you to upgrade.
With the Divide and Measure commands one can place a block, effectively creating an ARRAY.
I'm trying to remember if 2007 supports Dynamic Blocks; if it does an alignment parameter can aide in keeping the blocks aligned correctly to the path.
The difference is in 2012 the arrayed objects are dynamically linked to the path object.
I think there might be a routine somewhere here at the swamp that also creates a dynamic aray.
http://www.theswamp.org/index.php?topic=39015.msg448981#msg448981
theluck19
Re: ACAD-Array
« Reply #2 on: December 04, 2011, 09:17:12 PM »
Thanx... :-)
danallen
Re: ACAD-Array
« Reply #3 on: December 04, 2011, 11:26:16 PM »
I believe Divide and Measure have always had an option to align blocks with object.
Dan
alanjt
  • Standby for witty remark...
Re: ACAD-Array
« Reply #4 on: December 04, 2011, 11:36:04 PM »
I'm pretty sure dynamic blocks came out in 2006.
Dropbox
Re: ACAD-Array
« Reply #5 on: December 05, 2011, 01:37:57 AM »
Just covering all bases there. However thanks for the fact checking gentlemen.    :wink:
Jeff H
Re: ACAD-Array
« Reply #6 on: December 05, 2011, 09:10:03 AM »
Just dealt with this and yes they came out in 2006.
alanjt
Re: ACAD-Array
« Reply #7 on: December 05, 2011, 11:23:42 AM »
Dropbox
theluck19
Re: ACAD-Array
« Reply #8 on: December 11, 2011, 10:55:43 PM »
Dont wanna sound too dumb here, but thats why i posted it in new to CAD. What i want looks something like this. I dont know about dynamic blocks much. Was in Design for a long time before this new job where i have to make the CAD output as well.Please tell me if dynamic blocks does this & I shall learn about it ASAP. Thanx. :-)
Re: ACAD-Array
« Reply #9 on: December 12, 2011, 12:38:25 AM »
you shouldn't need dynamic blocs to do this....
however they could help by using predefined stretch increment (bar spacings)
so they could be worth exploring.
trogg
Re: ACAD-Array
« Reply #10 on: December 29, 2011, 09:46:54 PM »
Alan has a LISP routine that'll work http://www.theswamp.org/index.php?topic=32789.0.
You just need to offset the polyline so that the object that you want copied/arrayed will have a path to be on. below is an example.
Hope this helps...
