Author Topic: Notepad++ for LISP heads  (Read 47094 times)
ElpanovEvgeniy
  • Moscow (Russia)
Re: Notepad++ for LISP heads
« Reply #15 on: November 30, 2011, 06:07:27 AM »
I use NotePad++ to display the code without opening AutoCAD.
This allows you to very quickly see the code...
Chris
« Reply #16 on: November 30, 2011, 08:29:48 AM »
now for the noob question,  I use notepad++ quite often, and everytime I setup a new machine, I have to manually input all my coding colors.  How do I actually import this file?  I tried doing the import style theme, but I dont think thats quite the right way to do it. (IOW it didnt work)
Christopher T. Cowgill, P.E.
AEC Collection 2020 (C3D)
Win 10
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #17 on: November 30, 2011, 08:51:44 AM »
For me, the most convenient way to use a portable version notepad++
How do I add a new language:
« Last Edit: November 30, 2011, 08:56:38 AM by ElpanovEvgeniy »
« Reply #18 on: November 30, 2011, 09:03:20 AM »
That's exactly how I use it Evgeniv, portable + import, tho I'm a Notepad++ n00b so there may be a better way. Having said that, one may want to keep a copy of the stylers.xml file that hosts global color settings, migrating colors from the GlobalStyles section to suit (rather than overwriting the file as there's high probability future versions will host new info in said file). :)
Meant to say thanks Michael. I know a few people who will be pleased to see your support file.
Thank you for the nod KB. :)
Chris
« Reply #19 on: November 30, 2011, 09:23:08 AM »
that worked well, thank you very much.
Win 10
BlackBox
« Reply #20 on: November 30, 2011, 09:58:37 AM »
I'm a huge fan of PortableApps (PA)... IcoFX, Gimp specifically... now that I know there's a PA version, I'll probably use Notepad++ more often.
1+
Yes, thank you very much. :beer:
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #21 on: November 30, 2011, 10:05:40 AM »
except portable version, I like the network version program...
for example:
http://pixlr.com/
https://www.autocadws.com/
BlackBox
« Reply #22 on: November 30, 2011, 10:12:57 AM »
for example:
http://pixlr.com/
Thanks for sharing!
*Saves Pixlr link to favorites*
I use AutoCADWS for project walk through's, either on my iPhone, or iPad already :wink:
« Reply #23 on: November 30, 2011, 10:14:08 PM »
Thank you for the Methods and Properties dump file MP.
I had a few more/extra "constants" in my syntax file if anyone wanted them.
acAttachmentPointTopLeft
acAttachmentPointTopCenter
acAttachmentPointTopRight
acAttachmentPointMiddleLeft
acAttachmentPointMiddleCenter
acAttachmentPointMiddleRight
acAttachmentPointBottomLeft
acAttachmentPointBottomCenter
acAttachmentPointBottomRight
acAlignmentLeft
acAlignmentMiddle
acAlignmentTop
vlax-vbInteger
vlax-vbLong
vlax-vbSingle
vlax-vbDouble
vlax-vbString
vlax-vbObject
vlax-vbBoolean
vlax-vbVariant
EDIT: fixed doubles in list.
« Last Edit: November 30, 2011, 10:23:19 PM by Se7en »
« Reply #24 on: November 30, 2011, 10:18:24 PM »
I had a few more/extra "constants" in my syntax file ...
Thanks John, about 40 extra by my count.  :-D
Subtitle: you doubled, even tripled some of your entries.
Actual unique values:
01 acAlignmentLeft
02 acAlignmentMiddle
03 acAlignmentTop
04 acAttachmentPointBottomCenter
05 acAttachmentPointBottomLeft
06 acAttachmentPointBottomRight
07 acAttachmentPointMiddleCenter
08 acAttachmentPointMiddleLeft
09 acAttachmentPointMiddleRight
10 acAttachmentPointTopCenter
11 acAttachmentPointTopLeft
12 acAttachmentPointTopRight
13 vlax-vbBoolean
14 vlax-vbDouble
15 vlax-vbInteger
16 vlax-vbLong
17 vlax-vbObject
18 vlax-vbSingle
19 vlax-vbString
20 vlax-vbVariant
 :-P
« Reply #25 on: November 30, 2011, 10:22:24 PM »
Oops, did i paste those twice? I'll fix my post...
BlackBox
« Reply #26 on: November 30, 2011, 10:23:38 PM »
Oops, did i paste those twice thrice? I'll fix my post...
FTFY - x3 :wink:
« Last Edit: November 30, 2011, 10:28:09 PM by RenderMan »
« Reply #27 on: November 30, 2011, 10:25:28 PM »
EDIT: fixed triples in list.
fixed :whistle:
« Reply #28 on: November 30, 2011, 10:28:13 PM »
One, Two times this thread has shown up in my "unread posts" because you two have thought it necessary to say what exactly?
« Reply #29 on: November 30, 2011, 10:32:02 PM »
butt-head
