Author Topic: Many codes listed in lisp.doc  (Read 2783 times)
xiaxiang
« on: November 28, 2011, 09:11:12 PM »
I am sorry to disturb you  but ...
I find a doc file from "forums.autodesk.com" and Many of the lisp file was listed in it,such as:
1.LSP   Copies objects and puts them in same exact place as original.
AC.LSP   Copies text to replace other text.
*****ECLN.LSP   (Empty CleaN) Cleans dwgs of unreferenced images & empty groups, empty blocks, empty text, named layer filters, and unused RegApps  objects – good for large 3D dwgs
*****ECLN.DVB   (goes with above)
ACLOCK.LSP   Anologue clock by Korean. Use CTRL_C to stop.
ADDDIR.LSP   Routine to add directories; can be changed to add, subtract or what is listed can be renamed.
ADDPRE.LSP   Adds text to beginning of text.
and much more
Who has this Archive of SWEET codes?
Many thanks!
http://forums.autodesk.com/t5/File-Attachments/no-subject/m-p/2041861/highlight/true#M4735
http://forums.autodesk.com/t5/File-Attachments/LSP-FILES-FOR-ALL-USERS/m-p/2041858/highlight/true#M4732
http://forums.autodesk.com/t5/File-Attachments/LSP-FILES-FOR-ALL-USERS/m-p/2041859/highlight/true#M4733
http://forums.autodesk.com/t5/AutoCAD-2007/lsp-files-available/td-p/2041314/highlight/true
Re: Many codes listed in lisp.doc
« Reply #1 on: November 28, 2011, 09:14:43 PM »
Just a guess, but perhaps Larry W. Ostrander.
xiaxiang
« Reply #2 on: November 28, 2011, 09:45:33 PM »
Thanks Michael
But How can  I Contact him?
jaydee
xiaxiang
« Reply #4 on: November 28, 2011, 10:09:34 PM »
