Author Topic: Breaking up code - how?  (Read 2491 times)
Jeremy
« on: November 27, 2011, 04:44:43 PM »
I suppose I should have posted this as a challenge but it is a problem that I am trying to solve but have only been partially successful at. I would like to be able to read a line of AutoLISP code and break it up into its syntactic units. I would like to feed a string of code and get back a list of two elements, the first element is a list of the actual code broken up into units and the second element is the code commenting (if any). In the list of syntactic units I would like each string in its own list so that I can identify them separate from the other pieces. Some examples, would probably be clearer:
"(+ 2 3)" -> (list (list "(" "+" "2" "3" ")") nil)
"(abs 4);absolute value" -> (list (list "(" "abs" "4" ")") ";absolute value")
"(strcase (strcat "cat" "dog"))"
   -> (list (list "(" "strcase" "(" "strcat" ("cat")("dog") "))") nil)
Note that parentheses are to be pulled away from the functions and elements that they enclose. I'm finding all this tricky because it is not immediately clear to me how one can properly recognize both quotes and semicolons in their proper context. Separating comments seems simple until you start wondering how best to go about it. Simply finding the first semicolon is not enough because you must consider whether it is between quotes or not. I'm hoping some of you gurus might have already tackled this problem and might want to share your wisdom on it.
Re: Breaking up code - how?
« Reply #1 on: November 27, 2011, 05:31:49 PM »
Following the logic of the other examples, should this:
not be:
-> (list (list "(" "strcase" (list  "(" "strcat" "cat" "dog" ")") ")") nil)
[ FYI ]
« Reply #2 on: November 27, 2011, 06:04:25 PM »
Maybe the algorithm used in the prinh (hierarchical print) function defined here can give you some ideas:
Example:
(prinh '(strcase (strcat "cat" "dog")))
Result:
    STRCASE
        STRCAT
        "cat"
        "dog"
*shrug*
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #3 on: November 28, 2011, 02:50:39 AM »
My old program, it is a full analysis of code into components.
Perhaps this code can help you ...
program code syntax highlighting
;; web-04.lsp
(defun ea_lsp-html (f / a fl i l rf s str w wf)
*   by ElpanovEvgeniy
*   Idea of program Chen Qing Jun
*   last version 2007-06-10
*   yuanqiu@gmail.com
*   My version  20.11.2008
*   Examples:
*   (ea_lsp-html (getfiled "Select a Lisp File" "D:\\Work\\" "lsp" 8))
*   (ea_lsp-html f)
 (setq rf (open f "r")
       wf (open (strcat (vl-filename-directory f) "/" (vl-filename-base f) ".html")
                "w"
          ) ;_  open
 ) ;_  setq
 (write-line
  (STRCAT
;;;   <s0> - (
;;;   <s1> - subr
;;;   <s2> - "\""
;;;   <s3> - 'int
;;;   <s4> - 'real
;;;   <s5> - 'usubr
;;;   <s6> - ;  ;||;   ;;
;;;   <s7> - ;  "'"
;;;   Добвляем заголовок и стили, для локального просмотра
   "<html><head><style>
pre {
    font-family: Courier, Verdana, Arial, sans-serif;
    color: black;
font-size: 12pt;
font-weight: 600;
    overflow: auto;
border-left: 3px solid #d0d0f0;
margin-left: 5px;
padding-left: 10px;
/*height: 800px;  Высота блока */
.s0 {color: red;}
.s1 {
    color: blue;
    font-size: 12pt;
font-weight: 600;
.s2 {color: #FF00FF;}
.s3 {color: #00CC00;}
.s4 {color: #009900;}
.s5 {color: #0000ff;}
.s6 {color: purple; background:#C0C0C0;}
.s7 {color: #800000;}
</style><title>"
   (VL-FILENAME-BASE f)
   (VL-FILENAME-EXTENSION f)
   "</title></head>\n<body><h3>"
   "</h3><pre>"
  ) ;_ strcat
  wf
 ) ;_  write-line
 (setq l
       (list
        (strcase (strcat ";;\t" (VL-FILENAME-BASE f) (VL-FILENAME-EXTENSION f)) t)
       ) ;_  list
 ) ;_  setq
 (while (car (setq l (cons (read-line rf) l))))
 (setq l   (reverse (cdr l))
       s   (car l)
       i   0
       l   (cdr l)
       str ""
 ) ;_  setq
 (while s
    ((= (setq a (ascii s)) 0)
     ;; пустая строка
     (write-line (strcat str "\n") wf)
     (setq s   (car l)
           l   (cdr l)
           str ""
     ) ;_  setq
    ((or (= a 32) (= a 9))
     ;; пробелы и табуляция
     (setq str (strcat str (substr s 1 1))
           s   (substr s 2)
           i   0
     ) ;_  setq
    ((or (= a 39) (= a 46))
     ;; апостроф
     (setq str (strcat str "<span class=s7>" (substr s 1 1))
           s   (substr s 2)
     ) ;_  setq
     (while (= (ascii s) 39)
            s   (substr s 2)
      ) ;_  setq
     ) ;_  while
     (setq str (strcat str "</span>"))
    ((< 39 a 42)
     ;; скобки
     (setq str (strcat str "<span class=s0>" (substr s 1 1))
           s   (substr s 2)
     ) ;_  setq
     (while (< 39 (ascii s) 42)
            s   (substr s 2)
      ) ;_  setq
     ) ;_  while
    ((= a 59)
     ;; многострочные коментарии
     (if (= (substr s 2 1) "|")
      ;;(ищем конец коментариев..
      (progn (setq str (strcat str "<span class=s6>"))
             (while (and s (not (setq i (vl-string-search "|;" s))))
              (write-line (strcat str s) wf)
              (setq s   (car l)
                    l   (cdr l)
                    str ""
              ) ;_  setq
             ) ;_  while
             (setq str (strcat (substr s 1 (+ 2 i)) "</span>"))
             (setq s (substr s (+ 3 i)))
      ) ;_  progn
       (write-line (strcat str "<span class=s6>" s "</span>") wf)
       (setq s   (car l)
             l   (cdr l)
             str ""
       ) ;_  setq
      ) ;_  progn
     ) ;_  if
    ((= a 34)
     ;; текстовые строки
     (progn (setq str (strcat str "<span class=s2>")
                  i   0
                  fl  t
            ) ;_  setq
            (while (and s fl)
             (while (and s
                         (setq i (vl-string-search "\"" s (setq i (1+ i))))
                         (not (or (zerop i)
                                  (not (= (substr s i 1) "\\"))
                                  (= (substr s (1- i) 2) "\\\\")
                              ) ;_  or
                         ) ;_  not
                    ) ;_  and
             ) ;_  while
             (if (null i)
              (setq str (strcat str s "\n")
                    s   (car l)
                    l   (cdr l)
                    i   -1
              ) ;_  setq
              (setq str (strcat str (substr s 1 (1+ i)) "</span>")
                    s   (substr s (+ 2 i))
                    fl  nil
                    i   0
              ) ;_  if
             ) ;_  if
            ) ;_  while
     ) ;_  progn
    ((progn (setq i (apply (function min)
                           (vl-remove-if (function null)
                                         (list (vl-string-search "(" s)
                                               (vl-string-search ")" s)
                                               (vl-string-search " " s)
                                               (vl-string-search "\t" s)
                                               (vl-string-search "'" s)
                                               (vl-string-search ";" s)
                                               (vl-string-search "\"" s)
                                               (strlen s)
                                         ) ;_  list
                           ) ;_  vl-remove-if
                    ) ;_  apply
                  w (substr s 1 i)
                  s (substr s (1+ i))
            ) ;_  setq
            (or (= (setq a (type (eval (read w)))) 'subr)
                (= (strcase w) "NIL")
                (= (strcase w) "T")
            ) ;_  or
     ) ;_  progn
     (setq str (strcat str "<span class=s1>" w "</span>"))
    ((= a 'usubr) (setq str (strcat str w)))
    ((= a 'int)
     (setq str (strcat str "<span class=s3>" w "</span>"))
    ((= a 'real)
     (setq str (strcat str "<span class=s4>" w "</span>"))
    (t (setq str (strcat str w)))
   ) ;_  cond
   s
  ) ;_  progn
  (if (and s (= (ascii s) 0))
   (progn (write-line str wf)
          (setq s   (car l)
                l   (cdr l)
                str ""
                i   0
          ) ;_  setq
   ) ;_  progn
  ) ;_  if
 ) ;_  while
 (write-line "</pre></body></html>" wf)
 (close rf)
 (close wf)
) ;_  defun
irneb
« Reply #4 on: November 28, 2011, 12:02:16 PM »
Here's an quick attempt from me:
(defun string-parse+ (str chars / lst split n)
  (setq n   -1
        lst (vl-remove-if
              'null
              (mapcar '(lambda (c)
                         (setq n (1+ n))
                         (if (vl-position c chars)
                           n
                      (vl-string->list str)
  (foreach n (reverse lst)
    (setq split (cons (substr str (1+ n) 1) (vl-remove "" (cons (substr str (+ n 2)) split)))
          str   (substr str 1 n)
  (if (/= (car lst) 0)
    (cons (substr str 1 (car lst)) split)
    split
(defun split-code (code / portions string lst)
  (setq portions (string-parse+ code (vl-string->list "() \n\r\t\";")))
  (while portions
      ((wcmatch (car portions) "\"")
       (if string
         (setq lst (cons (strcat "\"" string "\"") lst) string nil)
         (setq string "")
      (string
       (setq string (strcat string (car portions)))
      ((eq (car portions) ";")
       (setq lst      (cons (apply 'strcat (cdr portions)) lst)
             portions nil
      ((not (wcmatch (car portions) " ,\t,\n,\r"))
       (setq lst (cons (car portions) lst))
    (setq portions (cdr portions))
  (if string (setq lst (cons (strcat "\"" string "\"") lst)))
  (if (and (car lst) (not (eq (car lst) "")))
    (cons (reverse (cdr lst)) (list (car lst)))
    (cons (reverse (cdr lst)) nil)
Seems to work for your examples. A few assumptions  :pissed: ...  :lmao: :
  • The code must be a single string value, not a list or multiple arguments. So you need to escape the double-quotes in your last example (the cat & dog one).
  • The comment will always be the line-end type comment, no multi-line comments.
  • I'm not including the semi-colon in the comment, though it would include any semi-colons following the first one.
  • Any blank space not inside a comment or a string will be removed. Thus things like code indents will disappear.
Jeremy
« Reply #5 on: November 28, 2011, 03:53:21 PM »
Wow, You guys are busy as bees! I'm always amazed at how fast people post around here. I think some tinkering with one or more of the examples will get me close enough to what I need. Thanks all. :-)
irneb
« Reply #6 on: November 29, 2011, 01:21:21 PM »
Glad to help. Here's a fix on my code to account for escaped double quotes inside of strings.  Replace the ((wcmatch (car portions) "\"") ... ) with:
       (if string
         (if (wcmatch string "*\\")
           (setq string (strcat string "\""))
         (setq string "")
And to include the semi-colon:
       (setq lst      (cons (apply 'strcat portions) lst)
             portions nil
It should now work fine, here's the result of a test:
_$ (split-code "(test 123.4 \"String with ; and escaped \\\"quote\\\"\") ;| Multiline Comment\n|;")
(("(" "test" "123.4" "\"String with ; and escaped \\\"quote\\\"\"" ")") ";| Multiline Comment\n|;")
The multiline comments only work if they're at the end of the code. To get multilines working when they're at the start / midway I'll leave for your exercise (Tip: use similar to what I've done for strings).
