hi all ... im new to swamp & i was hoping someone could help me
pls. bear with me if its bit lengthy ...
i have attached a zip file that contain 2 drawing files
1. sample drawing.dwg
2. autolevels.dwg
once you've open the 1st item you will notice that the way the elevation was drawn was around the main "plan" similarly all the attribute LEVEL tag's are placed to it.
i've found this "autolevels.dwg" tag from another site, only trouble is it is relative to the "ucs/world" only and i have tried rotating it but it does not allow me to do so.
i was hoping for someone could help alter it by having some kind of a "marker" to the tag's base in which the marker can be placed at a specific location and it will stay there to become the 0.0 mark and increment from there when user move the "tag" itself.
think of it like a "Ship anchored in the ocean"
anchor = represent the marker @ 0 level
ship = represent the level tag that when moved (vertically/ horizontally) its automatically updated
so if i copy the "(ship+anchor=one set)" and place it someplace in the drawing it will act on its own without affecting other "(ship+anchor)" like a shipyard or in a marina.
i hope im making sense
i was hoping the resulting "level tag" can be tailor similar to the sample dwg eg; "CH = 3000" (the unit is in mm)
thank you all very much for your patience and help
regards,
tot -- is using win xp/ autocad r2009
