CadFrank,
What is the filepath of your .txt file?
But anyways i'm not sure I understand what you mean.
You will need to use two backslashes or a single forward slash to specify the filepath since a single backslash is used in LISP as an escape character.
Escape Character.The backslash is used as an escape character to give a sequence of characters an alternative meaning, e.g.:
"\n" = new line character
"\t" = tab character
Hence, if you need to use a literal backslash you need to mark it as a literal by prefixing it with another backslash ("\\").
Test these expressions in your console to understand:
(princ "C:\timetracker.txt")
(princ "C:\\timetracker.txt")
