Author Topic: Check my code  (Read 3557 times)
V-Man
Check my code
« on: November 16, 2011, 02:52:33 PM »
I have the following code that works great in ACADMAP2010, but when I run this on vanilla ACAD2010 it bombs. It fails on the HATCH part of the code.
(defun C:HPP ( / ss n ssss)
(command "_undo" "_g")
  (setq ss (ssget "X" '((0 . "LWPOLYLINE")(8 . "0")(70 . 1))));0=Type , 8=Layer Name , 70=lypolylines closed only
(if (= ss nil)
(alert "LwPolylines are not on the Correct LAYER!")
(if ss
  (repeat (setq n (sslength ss))
    (setq n (1- n))
    (command "_.hatch" "HONEY" "140" "" (ssname ss n) "")  )
(setq ssss (ssget "X" '((0 . "HATCH"))))
      (command ".chprop" ssss "" "c" "yellow" "")
   (command "._undo" "_end")
So I tried to change it to the following and I get nothing.
(command ".-hatch" "p" "HONEY" "140" "s" (ssname ss n) "")
Could one of you guys test this out and let me know where I am going wrong?
Thanks,
nivuahc
Re: Check my code
« Reply #1 on: November 16, 2011, 03:49:16 PM »
FWIW your codes works just fine in MEP 2011
It also works with
.hatch
_hatch
._hatch
hatch
bhatch
I don't have 'nilla CAD to test it on
alanjt
  • Standby for witty remark...
Re: Check my code
« Reply #2 on: November 16, 2011, 04:02:56 PM »
Works on my end unless the boundary is too small for the hatch pattern scale.
For fun, here's a much faster/safer way...
(defun c:HPP (/ *error* space ss i hatch)
  (defun *error* (msg)
    (and *AcadDoc* (vla-endundomark *AcadDoc*))
    (if (and msg (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*QUIT*,")))
  (vla-startundomark
    (cond (*AcadDoc*)
          ((setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object))))
  (if (setq space (vlax-get *AcadDoc*
                            (if (eq (getvar 'CVPORT) 1)
                              'paperspace
                              'modelspace
            ss    (ssget "_X" '((0 . "LWPOLYLINE") (8 . "0") (-4 . "&=") (70 . 1)))
    (repeat (setq i (sslength ss))
      (vl-catch-all-apply
        '(lambda (/)
           (setq hatch (vla-AddHatch space acHatchPatternTypePredefined "HONEY" :vlax-true))
           (vlax-invoke
             hatch
             'AppendOuterLoop
             (list (vlax-ename->vla-object (ssname ss (setq i (1- i)))))
           (vlax-invoke hatch 'Evaluate)
           (vla-put-patternscale hatch 140.)
           (vla-put-color hatch 2)
  (*error* nil)
Dropbox
alanjt
Re: Check my code
« Reply #3 on: November 16, 2011, 04:11:27 PM »
Actually, this would be better (ignores locked layers and only selects objects in the active view):
  (vla-startundomark
    (cond (*AcadDoc*)
                              'paperspace
                              'modelspace
            ss    (ssget "_A"
                         (list '(0 . "LWPOLYLINE")
                               '(8 . "0")
                               '(-4 . "&=")
                               '(70 . 1)
                                 (cons 410 (getvar 'CTAB))
                                 '(410 . "Model")
      (vl-catch-all-apply
        '(lambda (/)
           (vlax-invoke
             hatch
             'AppendOuterLoop
  (*error* nil)
Dropbox
V-Man
Re: Check my code
« Reply #4 on: November 16, 2011, 04:28:44 PM »
Great. Many thanks. I will give your code a whirl.
Thanks again.
alanjt
Re: Check my code
« Reply #5 on: November 16, 2011, 04:32:06 PM »
Thanks again.
Any time.
Dropbox
