Author Topic: Getting eNoInputFiler error  (Read 2385 times)
TJK44
« on: November 16, 2011, 02:03:36 PM »
Hello,
I am getting an eNoInputFiler error at this line of code, wondering if anyone could tell me what this error means?
xrefdb.ReadDwgFile(curdir2 & "\Master.dwg", FileShare.ReadWrite, False, "")
Thanks,
Ted
MexicanCustard
Re: Getting eNoInputFiler error
« Reply #1 on: November 16, 2011, 02:08:08 PM »
try,
xrefdb.ReadDwgFile(curdir2 + "\\Master.dwg", FileShare.ReadWrite, False, "");
TJK44
« Reply #2 on: November 16, 2011, 02:14:25 PM »
Still getting the same error, this is how it is setup before reaching that line of code.
            Dim xrefdb As Database = New Database(False, False)
            Dim fName2 As String = database.Filename
            Dim curdir2 As String = Path.GetDirectoryName(fName2)
MexicanCustard
« Reply #3 on: November 16, 2011, 02:27:48 PM »
Are you using the Session CommandFlag?  Seems it can cause the problem according to some post over at forums.autodesk.com but I didnt see any solutions over there.
TJK44
« Reply #4 on: November 16, 2011, 02:39:27 PM »
Removing the Session command flag allowed it to progress past that point. Thanks.
Jeff H
« Reply #5 on: November 16, 2011, 02:42:15 PM »
Have you tried
to check if the file exists because you create a new database then try to use its filename.
I would guess the error means it is trying to 'DwgInFields' and there is no file to read in database??
Jeff H
« Reply #6 on: November 16, 2011, 02:44:36 PM »
If System.IO.File.Exists(.........) Then
TJK44
« Reply #7 on: November 16, 2011, 03:47:31 PM »
The file did exist and I was still getting that error
