(setq oldlst'((("num" . "1") ("code" . "CXJ.1.1-01") ("name" . "part1") ("numb" . "1") ("mate" . "") ("wein" . "") ("weia" . "") ("note" . ""))(("num" . "2") ("code" . "CXJ.1.1-02") ("name" . "part2") ("numb" . "2") ("mate" . "") ("wein" . "") ("weia" . "") ("note" . ""))(("num" . "3") ("code" . "CXJ.1.1-03") ("name" . "part3") ("numb" . "3") ("mate" . "") ("wein" . "") ("weia" . "") ("note" . ""))(("num" . "4") ("code" . "CXJ.1.1-04") ("name" . "part4") ("numb" . "4") ("mate" . "") ("wein" . "") ("weia" . "") ("note" . ""))(("num" . "5") ("code" . "CXJ.1.1-05") ("name" . "part5") ("numb" . "5") ("mate" . "") ("wein" . "") ("weia" . "") ("note" . ""))(("num" . "6") ("code" . "CXJ.1.1-06") ("name" . "part6") ("numb" . "6") ("mate" . "") ("wein" . "") ("weia" . "") ("note" . ""))(("num" . "7") ("code" . "CXJ.1.1-07") ("name" . "part7") ("numb" . "7") ("mate" . "") ("wein" . "") ("weia" . "") ("note" . ""))(("num" . "A1") ("code" . "CXJ.1.1.1-00") ("name" . "asm1") ("numb" . "1") ("mate" . "") ("wein" . "") ("weia" . "") ("note" . ""))(("num" . "A2") ("code" . "CXJ.1.1.2-00") ("name" . "asm2") ("numb" . "2") ("mate" . "") ("wein" . "") ("weia" . "") ("note" . ""))(("num" . "A3") ("code" . "CXJ.1.1.3-00") ("name" . "asm3") ("numb" . "3") ("mate" . "") ("wein" . "") ("weia" . "") ("note" . ""))(("num" . "A4") ("code" . "CXJ.1.1.4-00") ("name" . "asm4") ("numb" . "4") ("mate" . "") ("wein" . "") ("weia" . "") ("note" . ""))(("num" . "B1") ("code" . "GB/T5780-2000") ("name" . "bolt M10X45") ("numb" . "5") ("mate" . "steel") ("wein" . "") ("weia" . "") ("note" . ""))(("num" . "B2") ("code" . "GB/T6170-2000") ("name" . "nut M10") ("numb" . "5") ("mate" . "steel") ("wein" . "") ("weia" . "") ("note" . ""))(("num" . "B3") ("code" . "GB/T93-1987") ("name" . "washer 10") ("numb" . "5") ("mate" . "65Mn") ("wein" . "") ("weia" . "") ("note" . ""))(("num" . "B4") ("code" . "GB/T95-2002") ("name" . "washer 10") ("numb" . "5") ("mate" . "steel") ("wein" . "") ("weia" . "") ("note" . ""))))(setq newlst'(("num" "1" "2" "3" "4" "5" "6" "7" "A1" "A2" "A3" "A4" "B1" "B2" "B3" "B4")("code" "CXJ.1.1-01" "CXJ.1.1-02" "CXJ.1.1-03" "CXJ.1.1-04" "CXJ.1.1-05" "CXJ.1.1-06" "CXJ.1.1-07" "CXJ.1.1.1-00" "CXJ.1.1.2-00" "CXJ.1.1.3-00" "CXJ.1.1.4-00" "GB/T5780-2000" "GB/T6170-2000" "GB/T93-1987" "GB/T95-2002")("name" "part1" "part2" "part3" "part4" "part5" "part6" "part7" "asm1" "asm2" "asm3" "asm4" "bolt M10X45" "nut M10" "washer 10" "washer 10")("numb" "1" "2" "3" "4" "5" "6" "7" "1" "2" "3" "4" "5" "5" "5" "5")("mate" "Q235-A" "40Cr" "60Si2Mn" "1Cr18Ni9Ti" "HT250" "ZG1Cr18Ni9Ti" "40Cr" "" "" "" "" "steel" "steel" "65Mn" "steel")("wein" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "")("weia" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "")("note" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "")))
(mapcar (function (lambda (a b) (cons a (mapcar (function cdr) b)))) (mapcar (function car) (car l)) (apply (function mapcar) (cons (function list) l)))
(setq l oldlst)
(defun f (l) (if (car l) (cons (cons (caaar l) (mapcar (function cdar) l)) (f (mapcar (function cdr) l))) ))
Hi,ElpanovEvgeniy!In addition,I need your helpHow to moving, delete, insert the operation for oldlst, but Don't change item "num" ?Again for help!Think you !
That is to say, in the oldlst insert (move, delete) after a item(row), one of the column "num" order unchanged.
(defun ff (l) (if (car l) (cons (mapcar (function car) l) (ff (mapcar (function cdr) l))) ))
(defun fff (oldlst newrow) (mapcar '(lambda ( x ) (if (equal (car newrow) (car x)) (setq oldrow x))) oldlst) (subst newrow oldrow oldlst))
(setq newrow '(("num" . "7") ("insert" . "") ("name" . "") ("numb" . "") ("mate" . "") ("wein" . "") ("weia" . "") ("note" . "")))
(fff oldlst newrow)
(defun StrParse_lst (str / pre_str num_str) (cond ((numberp (read str)) (setq pre_str "" num_str str ) ;_ 结束setq ) ((wcmatch str "A*,B*") (setq pre_str (substr str 1 1) num_str (substr str 2) ) ;_ 结束setq ) ) ;_ 结束cond (list pre_str num_str))(defun Add_Lst_Item (AddItemLst lst / pre_str num_str valstr oldpre_str oldnum_str sublst ret_lst) (setq pre_str (nth 0 (StrParse_lst (cdar AddItemLst))) num_str (nth 1 (StrParse_lst (cdar AddItemLst))) ) ;_ 结束setq (mapcar '(lambda (item) (setq oldpre_str (nth 0 (StrParse_lst (cdar item))) oldnum_str (nth 1 (StrParse_lst (cdar item))) ) ;_ 结束setq (cond ((and (= pre_str oldpre_str) (>= (atoi oldnum_str) (atoi num_str)) ) ;_ 结束and (setq valstr (strcat pre_str (itoa (1+ (atoi oldnum_str))) ) ;_ 结束strcat sublst (subst (vl-list* (caar item) valstr) (car item) item ) ;_ 结束subst ) ;_ 结束setq ) (t (setq sublst item)) ) ;_ 结束cond (if (and (= pre_str oldpre_str) (= (atoi num_str) (atoi oldnum_str)) ) ;_ 结束and (setq ret_lst (cons sublst (cons AddItemLst ret_lst))) (setq ret_lst (cons sublst ret_lst) ) ;_ 结束setq ) ;_ 结束if ) ;_ 结束lambda lst ) ;_ 结束mapcar (reverse ret_lst)) ;_ 结束defun
(setq newrow1 '(("num" . "7") ("code" . "insert1") ("name" . "") ("numb" . "") ("mate" . "") ("wein" . "") ("weia" . "") ("note" . "")))(setq newrow2 '(("num" . "A1") ("code" . "insert2") ("name" . "") ("numb" . "") ("mate" . "") ("wein" . "") ("weia" . "") ("note" . "")))(setq newrow3 '(("num" . "B2") ("code" . "insert3") ("name" . "") ("numb" . "") ("mate" . "") ("wein" . "") ("weia" . "") ("note" . "")))(setq lst1 (Add_Lst_Item newrow1 oldlst) lst2 (Add_Lst_Item newrow2 oldlst) lst3 (Add_Lst_Item newrow3 oldlst)) ;_ 结束setq
(defun f (n l) (cond ((not l) nil) ((equal (caar l) (car n)) (f nil (cons n l))) ((equal (caar l) (caadr l)) (cons (car l) (f n (cons (cons (cons (caaar l) (if (wcmatch (cdaar l) "#*") (itoa (1+ (atoi (cdaadr l)))) (strcat (substr (cdaadr l) 1 1) (itoa (1+ (atoi (substr (cdaadr l) 2))))) ) ) (cdadr l) ) (cddr l) ) ) ) ) ((cons (car l) (f n (cdr l)))) ))
(setq newrow1 '(("num" . "9") ("code" . "insert2") ("name" . "") ("numb" . "") ("mate" . "") ("wein" . "") ("weia" . "") ("note" . "")))
