Made this one a while ago, see if helps...
// overload no scale factor or set the view - just make the layout
public void LayoutAndViewport ( Database db, string layoutName, out ObjectId rvpid, string deviceName, string mediaName, out ObjectId id )
// set default values
rvpid = new ObjectId();
bool flagVp = false; // flag to create a new floating view port
double viewSize = (double)AcadApp.GetSystemVariable("VIEWSIZE");
double height = viewSize;
double width = viewSize;
Point2d loCenter = new Point2d(); // layout center point
Point2d vpLowerCorner = new Point2d();
Point2d vpUpperCorner = new Point2d();
Document doc = AcadApp.DocumentManager.MdiActiveDocument;
LayoutManager lm = LayoutManager.Current;
id = lm.CreateLayout(layoutName);
Layout lo = tr.GetObject(id, OpenMode.ForWrite, false) as Layout;
if (lo != null)
lm.CurrentLayout = lo.LayoutName; // make it current!
#region do some plotting settings here for the paper size...
ObjectId loid = lm.GetLayoutId(lo.LayoutName);
PlotInfo pi = new PlotInfo();
pi.Layout = loid;
PlotSettings ps = new PlotSettings(false);
PlotSettingsValidator psv = PlotSettingsValidator.Current;
psv.RefreshLists(ps);
psv.SetPlotConfigurationName(ps, deviceName, mediaName);
psv.SetPlotType(ps, Autodesk.AutoCAD.DatabaseServices.PlotType.Layout);
psv.SetPlotPaperUnits(ps, PlotPaperUnit.Inches);
psv.SetUseStandardScale(ps, true);
psv.SetStdScaleType(ps, StdScaleType.ScaleToFit); // use this as default
pi.OverrideSettings = ps;
PlotInfoValidator piv = new PlotInfoValidator();
piv.Validate(pi);
lo.CopyFrom(ps);
PlotConfig pc = PlotConfigManager.CurrentConfig;
// returns data in millimeters...
MediaBounds mb = pc.GetMediaBounds(mediaName);
Point2d p1 = mb.LowerLeftPrintableArea;
Point2d p3 = mb.UpperRightPrintableArea;
Point2d p2 = new Point2d(p3.X, p1.Y);
Point2d p4 = new Point2d(p1.X, p3.Y);
// convert millimeters to inches
double mm2inch = 25.4;
height = p1.GetDistanceTo(p4) / mm2inch;
width = p1.GetDistanceTo(p2) / mm2inch;
vpLowerCorner = lo.PlotOrigin;
vpUpperCorner = new Point2d(vpLowerCorner.X + width, vpLowerCorner.Y + height);
LineSegment2d seg = new LineSegment2d(vpLowerCorner, vpUpperCorner);
loCenter = seg.MidPoint;
#endregion
if (lo.GetViewports().Count == 1) // Viewport was not created by default
// the create by default view ports on new layouts it
// is off we need to mark a flag to generate a new one
// in another transaction - out of this one
flagVp = true;
else if (lo.GetViewports().Count == 2) // create Viewports by default it is on
// extract the last item from the collection
// of view ports inside of the layout
int i = lo.GetViewports().Count - 1;
ObjectId vpId = lo.GetViewports()[i];
if (!vpId.IsNull)
Viewport vp = tr.GetObject(vpId, OpenMode.ForWrite, false) as Viewport;
if (vp != null)
vp.Height = height; // change height
vp.Width = width; // change width
vp.CenterPoint = new Point3d(loCenter.X, loCenter.Y, 0.0); // change center
//vp.ColorIndex = 1; // debug
// zoom to the Viewport extents
Zoom(new Point3d(vpLowerCorner.X, vpLowerCorner.Y, 0.0),
new Point3d(vpUpperCorner.X, vpUpperCorner.Y, 0.0), new Point3d(), 1.0);
rvpid = vp.ObjectId; // return the output ObjectId to out...
tr.Commit();
} // end of transaction
// we need another transaction to create a new paper space floating Viewport
if (flagVp)
BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
BlockTableRecord btr_ps = (BlockTableRecord)tr.GetObject(bt[BlockTableRecord.PaperSpace], OpenMode.ForWrite);
Viewport vp = new Viewport();
vp.Height = height; // set the height
vp.Width = width; // set the width
vp.CenterPoint = new Point3d(loCenter.X, loCenter.Y, 0.0); // set the center
//vp.ColorIndex = 2; // debug
btr_ps.AppendEntity(vp);
tr.AddNewlyCreatedDBObject(vp, true);
vp.On = true; // make it accessible!
rvpid = vp.ObjectId; // return the ObjectId to the out...
tr.Commit();
