Author Topic: Help with Attributes  (Read 2320 times)
Arizona
« on: November 07, 2011, 08:47:05 AM »
Hi All,
I think I have gotten to a point with this where I can ask this as an intelligent question and I may actually understand the answer. This is what I am trying to do:
1.   Search drawing for Title block reference.
a.   Get insert point, attributes
2.   Insert new title block at same location as old title block
a.   Get attributes
3.   Compare attribute tags, get the textstring values from the old title block and put them into the new title block. Note: The tags are identically named between the old and new blocks, both blocks contain 16 attributes, labeled CTB1, CTB2, etc..
4.   Delete the old titleblock.
This is my first attempt at writing a C# program for AutoCAD (at least one that is not in the tutorial) and the only reason I have gotten this far is because of folks like Kerry, Jeff and other Swampers.
I’m pretty sure I have backed myself into a corner, so I need help (of any kind)!
I do recognize that my variables are going out of scope, so I believe this should be broken down into more procedures. Any assistance/guidance is most definitely appreciated!
This is what I have so far:
using System;
using System.IO;
using System.Linq;
using System.Text;
using Autodesk.AutoCAD.Colors;
namespace GetTitleBlkInfo
    public class GetTitleBlkInfo
        [CommandMethod("GetTitleBlk")]
        public static void GetOldTitleBlk()
            Database db = doc.Database;
            Editor ed = doc.Editor;
            string[] oldBlkName = new string[] { "ctml0012", "ctml0011", "ctml0010" };
            String strBlkName = "J:\\acad\\ctml0013.dwg";
            Point3d InsPoint = new Point3d();
            //AttributeCollection oldAttCol;
            //AttributeCollection newAttCol;
            string newName = "ctml0013";
            string oldName = "";
            int i = 0;
            //Start Transaction
                //Get the block table and check for old titleblock
                BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
                while (i < 3)
                    if (bt.Has(oldBlkName[i]))
                        oldName = oldBlkName[i];
                        //Open BlkTable Record for modelspace
                        BlockTableRecord btr = tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord;
                        foreach (ObjectId blkid in btr)
                            BlockReference oldTBlkRef = tr.GetObject(blkid, OpenMode.ForRead) as BlockReference;
                            if (oldTBlkRef.Name == oldName)
                                ed.WriteMessage("\nblock name is: " + oldTBlkRef.Name);
                                InsPoint = oldTBlkRef.Position;
                                Scale3d scale = oldTBlkRef.ScaleFactors;
                                //oldAttCol = oldTBlkRef.AttributeCollection;
                            }//close if oldtblkref.name
                        }//close foreach ObjectId
                    }//close if oldBlkName
                    i = i + 1;
                }//close while i
                if (!bt.Has(newName))
                    bt.UpgradeOpen();
                    Database tmpDb = new Database(false, true);
                    tmpDb.ReadDwgFile(strBlkName, System.IO.FileShare.Read, true, null);
                    //insert the block into the block table
                    ObjectId BlkId = db.Insert(strBlkName, tmpDb, true);
                    //Get the block Table record for the block
                    BlockTableRecord newBtr = (BlockTableRecord)tr.GetObject(BlkId, OpenMode.ForWrite);
                    //Name the block table record
                    newBtr.Name = newName;
                    //create the block reference and get modelspace Block table record
                    BlockReference br = new BlockReference(InsPoint, BlkId);
                    BlockTableRecord ms = (BlockTableRecord)tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
                    br.Position = InsPoint;
                    ms.AppendEntity(br);
                    tr.AddNewlyCreatedDBObject(br, true);
                    //newAttCol = br.AttributeCollection;
                }//close if newName
                InsertAttributes(oldName);
                //commit the changes and dispose of the transaction
                tr.Commit();
            }//close using
        }//close public
        public static void InsertAttributes(string oldBName)
            BlockReference tblkNew;
            string newBName = "ctml0013";
            //Start Transaction
                BlockTable bt2 = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
                        BlockTableRecord btr2 = tr.GetObject(bt2[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord;
                        foreach (ObjectId blkid in btr2)
                            BlockReference TBlk = tr.GetObject(blkid , OpenMode.ForRead) as BlockReference;
                            if (TBlk.Name == oldBName)
                                BlockReference tblkOld = (BlockReference)tr.GetObject(blkid, OpenMode.ForRead);
                                oldAttCol = tblkOld.AttributeCollection;
                            if (TBlk.Name == newBName)
                                tblkNew = (BlockReference)tr.GetObject(blkid, OpenMode.ForWrite);
                                newAttCol = tblkNew.AttributeCollection;
                        foreach (ObjectId attOldId in oldAttCol)
                            foreach (ObjectId attNewId in newAttCol)
                                    AttributeReference oldAtt = (AttributeReference)tr.GetObject(attOldId, OpenMode.ForRead);
                                    AttributeReference newAtt = (AttributeReference)tr.GetObject(attNewId, OpenMode.ForWrite);
                                    if (oldAtt.Tag == newAtt.Tag)
                                        newAtt.TextString = oldAtt.TextString;
                                        tblkNew.AttributeCollection.AppendAttribute(newAtt);
                                        tr.AddNewlyCreatedDBObject(newAtt, true);
                                }//close foreach attNewId
                           }//close foreach attOldId
                tr.Commit();
            }//close second transaction
        } //close public
    }//close class
}//close namespace
Jeff H
Re: Help with Attributes
« Reply #1 on: November 07, 2011, 10:55:54 AM »
If the attributes are the same and are in the same location then all you would need to do change the BlockReference.BlockTableRecord property
Example using OldTB and NewTB
         [CommandMethod("ReplaceTB")]
        public void ReplaceTB()
                BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
                BlockTableRecord oldBtr = (BlockTableRecord)tr.GetObject(bt["OldTB"], OpenMode.ForRead);
                foreach (ObjectId id in oldBtr.GetBlockReferenceIds(true, false))
                    BlockReference bref = (BlockReference)tr.GetObject(id, OpenMode.ForWrite);
                    bref.BlockTableRecord = bt["NewTB"];
                tr.Commit();
Arizona
« Reply #2 on: November 07, 2011, 12:42:06 PM »
Thanks for the response Jeff!
David Hall
  • Automatic Duh Generator
« Reply #3 on: November 08, 2011, 11:49:22 AM »
I was looking for a way to do something similiar, but by selecting the first and second block.  This is what i have so far.
using System;
using System.Linq;
using System.Text;
namespace EditTitleBlock
    public class EditTitleBlock
            PromptEntityOptions peo1 = new PromptEntityOptions("\n Select Old Titleblock: ");
            peo1.AllowNone = true;
            PromptEntityResult per1 = ed.GetEntity(peo1);
            if (per1.Status != PromptStatus.OK)
                return;
            else
                ObjectId oldBlkId = per1.ObjectId;
                PromptEntityOptions peo2 = new PromptEntityOptions("\n Select New Titleblock: ");
                peo2.AllowNone = true;
                PromptEntityResult per2 = ed.GetEntity(peo2);
                if (per2.Status != PromptStatus.OK)
                    return;
                ObjectId newBlkId = per2.ObjectId;
                    BlockTableRecord oldBtr = (BlockTableRecord)tr.GetObject(oldBlkId, OpenMode.ForRead);
                    BlockTableRecord newBtr = (BlockTableRecord)tr.GetObject(newBlkId, OpenMode.ForWrite);
                    tr.Commit();
David Hall
« Reply #4 on: November 08, 2011, 11:51:07 AM »
Still working on processing the attributes
Arizona
« Reply #5 on: November 08, 2011, 12:53:18 PM »
I did get this to work although it may not be in the best form. It does transfer all the attribute values from the old titleblock to the new title block.
using System;
using System.Linq;
using System.Text;
namespace SwapTBlk
    public class GetTblk_Info
            int i = 0;
            //Start Transaction
                while (i < 3)
                    }//close if
                    i = i + 1;
                }//close while i
                BlockTableRecord btr = tr.GetObject(bt[oldName], OpenMode.ForWrite) as BlockTableRecord;
                foreach (ObjectId id in btr.GetBlockReferenceIds(true, false))
                    BlockReference oldTBlkRef = tr.GetObject(id, OpenMode.ForWrite) as BlockReference;
                    bt.UpgradeOpen();
                    foreach (ObjectId attNewId in newBtr)
                        Entity newEnt = (Entity)tr.GetObject(attNewId, OpenMode.ForRead);
                        if (newEnt is AttributeDefinition)
                            AttributeDefinition newAttDef = (AttributeDefinition)newEnt;
                            AttributeReference newRef = new AttributeReference();
                            newRef.SetAttributeFromBlock(newAttDef, br.BlockTransform);
                            br.AttributeCollection.AppendAttribute(newRef);
                            tr.AddNewlyCreatedDBObject(newRef, true);
                        }//if newent
                    }//close foreach attnewid
                        int counter = 1;
                        int newCounter = br.AttributeCollection.Count - 1;
                        while (newCounter >= 0)
                            counter = oldAttCol.Count - 1;
                            while (counter >= 0)
                                ObjectId attOldId = oldAttCol[counter];
                                ObjectId attNewId = newAttCol[newCounter];
                                }//close if
                                counter = counter - 1;
                            }//close while
                            newCounter = newCounter - 1;
                        }//close newcounter
                    }//close if
                BlockTableRecord oldbtr = tr.GetObject(bt[oldName], OpenMode.ForWrite) as BlockTableRecord;
                foreach (ObjectId id1 in oldbtr.GetBlockReferenceIds(true, false))
                    BlockReference oldTBlk = tr.GetObject(id1, OpenMode.ForWrite) as BlockReference;
                    oldTBlk.Erase(true);
                    tr.Commit();
            }//close using
        }//close public
    }//Close class
}//close namespace
« Last Edit: November 08, 2011, 01:40:02 PM by Arizona »
