Author Topic: Xrecord question  (Read 2542 times)
TopoWAR
Xrecord question
« on: November 02, 2011, 01:27:39 PM »
hello friends.
can be accessed from a dwg to information in another drawing from Xrecord lisp?
thanks!
Thanks for help
Re: Xrecord question
« Reply #1 on: November 02, 2011, 02:55:30 PM »
If I understand your question, Yes with ObjectDBX
TopoWAR
« Reply #2 on: November 02, 2011, 02:59:55 PM »
The following code is the beginning, but do not know how to proceed, somebody help? thanks
(setq
    odbx (if (< (setq vers (substr (getvar "acadver") 1 2)) "16")
      (vla-GetInterfaceObject
        (vlax-get-acad-object)
        "ObjectDBX.AxDbDocument"
        (strcat "ObjectDBX.AxDbDocument." vers)
    list_dicc (list)
  (vla-open odbx "c:\\drawing.dwg")
  (setq dicc (vlax-get odbx 'dictionaries))
« Last Edit: November 02, 2011, 06:25:43 PM by TopoWAR »
Thanks for help
TopoWAR
« Reply #3 on: November 02, 2011, 06:27:35 PM »
s.o.s. help :-(
Thanks for help
« Reply #4 on: November 02, 2011, 07:52:37 PM »
I may have some time tomorrow but here is some reading & subroutines.
-----------  Ldata - xData -------------
http://www.theswamp.org/index.php?topic=30445.0 Quick XData Functions by Lee Mac
http://www.theswamp.org/index.php?topic=31804.0
http://www.theswamp.org/index.php?topic=5003.0  MP - dictionaries and xRecords
http://www.theswamp.org/index.php?topic=1283.0  Ldata vs xData
http://www.theswamp.org/index.php?topic=4395.0
http://www.theswamp.org/index.php?topic=8829.0
http://www.theswamp.org/index.php?topic=29381.0
http://www.theswamp.org/index.php?topic=23294.msg281024#msg281024 Ldata
http://www.theswamp.org/index.php?topic=29564.0
http://www.theswamp.org/index.php?topic=18490.0  Ldata example
  Data Structures
http://www.theswamp.org/index.php?topic=37660.msg427038#msg427038 LeeMac
------   ObjectDBX  ----------
http://www.theswamp.org/index.php?topic=29933.msg354958#msg354958 ]Loop Drawings & execute a lisp
http://www.theswamp.org/forum/index.php?topic=7335.msg91135#msg91135]Re: Change the same details of a number of drawing titleblocks
http://www.theswamp.org/forum/index.php?topic=6307.0]DBX Testing
http://www.theswamp.org/forum/index.php?topic=7498.0]run a lisp in dwgs WITHOUT opening the dwgs?
http://www.theswamp.org/forum/index.php?topic=3650.0]Jeff_M or anyone familiar with ObjectDBX
http://www.theswamp.org/forum/index.php?topic=2671.0]Find Text in a Closed Drawing
http://www.theswamp.org/forum/index.php?topic=1821.0]Block Adding
http://www.theswamp.org/index.php?topic=22932.msg275882#msg275882]Copy various collections
http://www.theswamp.org/index.php?topic=22932.msg275940#msg275940]Copy a Layout
http://www.theswamp.org/index.php?topic=29933.0   MapDbxDocs  by Tim Willey
http://www.theswamp.org/index.php?topic=31827.0  by Lee Mac
http://www.theswamp.org/index.php?topic=23805.msg288265#msg288265  Import Layers
--------------  Find / Replae Text  ----------------------
http://www.theswamp.org/index.php?topic=4591.msg272347#msg272347
