not sure i understand what you're gettin at cadaver. when i type in what you say it just tells me to select block, doesn't give me those options. the toughest thing i'm thinking would be to find and change only the 2 attributes detail #2 on sheet 5 to detail#2 on sheet 6 and not change detail #3 on sheet 5 to detail#3 on sheet 6. does anyone know what the hell i'm talking about?
dan
Works fine for me in R2002 and only changes the current layout, make sure you answer NO twice. Then again, maybe I'm missing what you're askin'??
Command: -attedit
Edit attributes one at a time? [Yes/No] <Y>:
NOPerforming global editing of attribute values.
Edit only attributes visible on screen? [Yes/No] <Y>:
NODrawing must be regenerated afterwards.
Enter block name specification <*>: [Yes/No] <Y>:
Key-in block nameEnter attribute tag specification <*>:
Key-in TAG name <right here key-in the tag name you're looking to eidt>Enter attribute value specification <*>:
Key-in value looking for13 attributes selected.
Enter string to change: 1
Enter new string: 2[/list:u]
For "Block name", Tag name", and "value specification", wildcards may be used. DET* will only look at blocks whose name starts with "DET".
Be sure to use enough letters to properly define which attributes are selected.
If you wish to select the attribute to change, answer yes to the second query and you'll be in a "select Attributes" loop where you can use Window or Crossing, etc.
