Author Topic: Help: Explode Line types  (Read 5057 times)
luiscarneirorm
« on: October 27, 2011, 04:46:54 AM »
Hi.
For some time I've been trying to develop an application for my work, and this forum has helped me a lot because I have learned here and found some very interesting things.
I have tried this function, but the best I've found, has some bugs to me.
In some cases the function works well, but in more complicated cases as dash-dot lines, or when the line to explode is not  within the visualization window...
For the amazing things I've seen around here, I think that even now there is this function that I seek, as the case may help me find it ...
« Last Edit: October 27, 2011, 12:07:15 PM by luiscarneirorm »
Re: Help: Explode Line types
« Reply #1 on: October 27, 2011, 07:35:04 AM »
Doesn't that violate the EULA?
« Reply #2 on: October 27, 2011, 08:36:20 AM »
Please read this statement in the code:
;;;    "[c]opying of this computer program or its documentation except as
;;;    permitted by this License is copyright infringement under the laws of
;;;    your country.  If you copy this computer program without permission of
;;;    Autodesk, you are violating the law."
See #7 in the Guide Lines
http://www.theswamp.org/index.php?topic=9202.0
We can try and help you with your code but you must be careful not to post code that has copy restrictions.
« Last Edit: October 27, 2011, 08:40:32 AM by CAB »
alanjt
  • Standby for witty remark...
« Reply #3 on: October 27, 2011, 08:41:48 AM »
No sharing of the Autodesk LISP tweaks. :P
Dropbox
luiscarneirorm
« Reply #4 on: October 27, 2011, 12:08:37 PM »
Ups...
Sorry.  :|
But somebody could indicate a function we do it???
Matt__W
  • I like my water diluted.
« Reply #5 on: October 27, 2011, 01:26:12 PM »
WMFOUT....WMFIN...EXPLODE.
But don't thank me.  http://cadpanacea.com/node/121
Autodesk Expert Elite
« Reply #6 on: October 27, 2011, 05:38:46 PM »
Worked for me in 2006.
Care to post a DWG example where it doesn't work?
luiscarneirorm
« Reply #7 on: October 28, 2011, 06:48:28 AM »
here are the drawings in question.
in this case the lines are thickness, and the point after the function is as a small line, but in the case of lines without thickness the point just disappears.
luiscarneirorm
« Reply #8 on: November 22, 2011, 10:57:15 AM »
Hi, Can someone help me?
I've been researching this to try to resolve my problem but have not found any solution  :x
My goal it's explode some linetypes (DASHED, DASHDOT, ...) to simple lines.
I've done it manually but I lose too much time on this
The original lines is in the "before_explode" file, and the treated file it's the "after_explode"...
Tanks in advance.
