Author Topic: -= {Challenge} =- convert an hexadecimal into a decimal  (Read 15890 times)
ElpanovEvgeniy
  • Moscow (Russia)
Re: -= {Challenge} =- convert an hexadecimal into a decimal
« Reply #15 on: October 24, 2011, 02:19:32 PM »
My program also works with any number of dimensions, without limitation, as BigInterger...
The same, I look to you.  :-)
(setq s "ffffffffffffffffffffffffffffffffffffffffffffffffff")
(strlen s) ;=>> 50
(hex2dec "ffffffffffffffffffffffffffffffffffffffffffffffffff")
;=>> "1606938044258990275541962092341162602522202993782792835301375"
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #16 on: October 24, 2011, 02:56:50 PM »
The problem was born from the need to create a field in AutoCAD 2008 x64 sp1
(vla-get-Utility (vla-get-ActiveDocument (vlax-get-acad-object)))
no method 'GetObjectIDString
(vlax-invoke
  'GetObjectIDString
  (vlax-ename->vla-object (car (entsel)))
returns
; error: ActiveX Server returned the error: unknown name: "GETOBJECTIDSTRING"
_$
« Reply #17 on: October 25, 2011, 08:11:26 AM »
Hi Lee Mac!
In your code has a bug.
See if you have
(hex2dec "1234567890abcdef"); =>> "1311768467294899800"
must
(hex2dec "1234567890abcdef"); =>> "1311768467294899695"
I noticed - I think this is due to the accuracy lost when dividing doubles. I shall have to consider another method, perhaps looking at the patterns of the digits of multiples of 16.
irneb
« Reply #18 on: October 25, 2011, 08:48:37 AM »
Exactly! I get a similar, yet slightly different error using my general purpose routines:
_$ (dec->string (base->dec "7ffffcf5c20" 16))
"879689834528"
_$ (dec->string (base->dec "1311768467294899695" 16))
"5627943617999796174848"
_$ (dec->string (base->dec "1234567890abcdef" 16))
"1311768467294899712"
_$ (dec->string (base->dec "fedcba0987654321" 16))
"18364757930599071744"
_$ (dec->string (base->dec "111111111111" 16))
"18764998447377"
_$ (dec->string (base->dec "ffffffffffff" 16))
"281474976710655"
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #19 on: October 25, 2011, 08:58:17 AM »
"879689834528"
"18764998447377"
"281474976710655"
Great job!
It remains a bit:
(dec->string (base->dec  "1234567890abcdef" 16)); =>> "1311768467294899712"must
irneb
« Reply #20 on: October 25, 2011, 09:27:59 AM »
That's what I meant about a "slightly different error". Though I think it's due to the way I change a float into a string. The division by a number other than a factor of 2 would usually cause floating point errors. One of the reasons I have a (> frac 1.e-10) in that routine instead of simply a (> frac 0.).
I wonder if one shouldn't rather implement something like a BCD number system for this case. Though it seems to get to that one might just as well implement a BigNum through a list structure. Yet another point where AutoLisp has fallen behind CL. That 2147483647 is the maximum 32bit signed integer value available, now with 64bit programs it's just not good enough for stuff like ID's.
« Last Edit: October 25, 2011, 09:31:53 AM by irneb »
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #21 on: October 25, 2011, 10:15:44 AM »
I had the 46 line, to solve the task ...
VovKa
  • Ukraine
« Reply #22 on: October 25, 2011, 10:40:27 AM »
translated from the stolen vb code
(defun vk_BaseToBase (h ib ob / lst n)
  (repeat (1+ (fix (* (strlen h) (/ (log ib) (log ob))))) (setq lst (cons 0 lst)))
  (foreach c (vl-string->list h)
    (setq n   (- c
(if (< c 58)
   48
   55
  lst (mapcar (function (lambda (d)
  (setq d (+ (* d ib) n)
n (/ d ob)
  (rem d ob)
      lst
  (apply 'strcat
(reverse (mapcar (function (lambda (c)
      (chr (+ c
      (if (< c 10)
48
55
  lst
;;;(vk_BaseToBase (vk_BaseToBase "FFFFFFFFFFFFFFFFFFFFFFFFFFFFF" 16 10) 10 16)
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #23 on: October 25, 2011, 10:48:17 AM »
    (setq n   (- c
(if (< c 58)
   48
   55
n (/ d ob)
  (rem d ob)
      lst
  (apply 'strcat
      (chr (+ c
      (if (< c 10)
48
55
  lst
(setq s "FFFFFFFFFFFFFFFFFFFFFFFFFFFFF")
(strlen s) ;== 29
(strlen (vk_BaseToBase (vk_BaseToBase s 16 10) 10 16)) ;== 30
VovKa
  • Ukraine
« Reply #24 on: October 25, 2011, 11:07:46 AM »
yep, leading zeros to be removed via vl-string-left-trim
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #25 on: October 25, 2011, 11:16:54 AM »
You did a very concise program!
My version is somewhat more complicated ...
« Reply #26 on: October 25, 2011, 11:25:36 AM »
Not as clean as VovKa's:
(defun hex2dec ( str / l1 l2 mat pas vec x x1 )
    (setq vec (mapcar '(lambda ( x ) (- x (if (< x 58) 48 55))) (vl-string->list (strcase str)))
          pas (_pascalmatrix (length vec) '((1.0)))
          mat pas
    (repeat 5 (setq mat (mxm mat pas)))
    (setq l1 (reverse (vxm vec mat))
          x1 (car l1)
    (while (< 0 x1)
        (setq l2 (cons (chr (+ (fix (rem x1 10)) 48)) l2)
              l1 (cdr l1)
              x1 (+ (/ (fix x1) 10) (cond ((car l1)) (0)))
    (apply 'strcat l2)
(defun _pascalmatrix ( n l )
    (if (< n 2)
        l
        (_pascalmatrix (1- n)
            (cons
                (mapcar '+ (cons 0.0 (car l)) (append (car l) '(0.0)))
                (mapcar (function (lambda ( x ) (cons 0.0 x))) l)
;; Matrix Transpose - Doug Wilson
;; Args: m - nxn matrix
(defun trp ( m )
    (apply 'mapcar (cons 'list m))
;; Matrix x Matrix - Vladimir Nesterovsky
;; Args: m,n - nxn matrices
(defun mxm ( m n )
    ( (lambda ( a ) (mapcar '(lambda ( r ) (mxv a r)) m)) (trp n))
;; Matrix x Vector - Vladimir Nesterovsky
;; Args: m - nxn matrix, v - vector in R^n
(defun mxv ( m v )
    (mapcar '(lambda ( r ) (apply '+ (mapcar '* r v))) m)
(defun vxm ( v m )
    (mapcar '(lambda ( r ) (apply '+ (mapcar '* r v))) (trp m))
Using the algorithm described here.
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #27 on: October 25, 2011, 11:31:43 AM »
Hi Lee Mac!
Great job!
Program is working properly.
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #28 on: October 25, 2011, 11:32:28 AM »
my version:
(defun eea-hex2dec (s / L f1 f2 f3 f4 f5)
  (defun f1 (s)
    (mapcar (function (lambda (a)
                        (- a
                           (if (<= a 57)
                             48
                             55
            (vl-string->list (strcase s))
  (defun f3 (i)
    (defun f2 (i)
      (if (> i 9)
        (append (f2 (/ i 10)) (f2 (rem i 10)))
        (list i)
    (reverse (f2 i))
  (defun f4 (l)
    (if l
      (cons (car l) (f4 (mapcar (function (lambda (a) (cons 0 a))) (cdr l))))
  (defun f5 (l / f)
    (if l
      (cons (apply (function +) (mapcar (function car) l)) (f5 (vl-remove nil (mapcar (function cdr) l))))
  (setq s (f1 s)
        l '(0)
  (while s
    (setq l (mapcar (function (lambda (a) (* a 16))) l)
          l (cons (+ (car l) (car s)) (cdr l))
          s (cdr s)
    (setq l (f5 (f4 (mapcar (function f3) l))))
  (while (vl-some (function (lambda (a) (> a 9))) l) (setq l (f5 (f4 (mapcar (function f3) l)))))
  (apply (function strcat) (mapcar (function itoa) (reverse l)))
« Reply #29 on: October 25, 2011, 11:54:11 AM »
Very nice algorithm VovKa  8-)
