Author Topic: Profiles  (Read 2643 times)
CADwoman
Profiles
« on: February 10, 2005, 02:51:24 PM »
Hi!! I found this lisp that loads a users profile based on the login name. I don't know who wrote this, but it work nice. The only problem is if I uncomment the following line (which should reload the profile):
(vlax-invoke-method acadProfiles 'ResetProfile profilename)
it seems to have revert back to a default profile. Can someone explain to me what I did wrong? Thanks
;CODING STARTS HERE
(prompt "\nType LoginProfile to run......")
(defun C:LoginProfile (/ profilename acadprofiles actprofile
                                     thelist profilepath)
;retrieve the users login name
(setq profilename (strcase (getvar "LOGINNAME")))
;retrieve a reference to the Profiles
(setq acadprofiles (vla-get-profiles
(vla-get-preferences (vlax-get-Acad-Object))))
;retrieve the Active Profile
(setq actprofile (strcase (vla-get-ActiveProfile acadprofiles)))
;if they are not the same
(if (/= profilename actprofile)
    ;do the following
                ;get a list of the loaded profiles
                (vlax-invoke-method acadProfiles 'GetAllProfileNames 'thelist)
                 ;convert to a list
                (setq thelist (vlax-safearray->list thelist))
;if the profile is not in the list
(if (not (member profilename thelist))
;do the following
     ;store the profile file
     (setq profilepath
        (strcat "c:/profiles/" profilename ".arg"))
;if the profile is found
(if (findfile profilepath)
    ;do the following
                 ;load the profile
                 (setq NewProfile (vlax-invoke-method
                 acadprofiles 'ImportProfile
                 profilename profilepath :vlax-true))
   ;make the profile the Active Profile
   (vla-put-ActiveProfile acadProfiles profilename)
    );progn
    ;profile file cannot be found - exit
    (prompt (strcat "\nCannot find profile " profilepath))
);if
 );progn
;it is loaded but make the profile the Active Profile
);if
    );progn
                ;Uncomment the next line to reload the Profile.
                ;(vlax-invoke-method acadProfiles 'ResetProfile profilename)
);if
);defun
;CODING ENDS HERE
Profiles
« Reply #1 on: February 11, 2005, 07:52:58 AM »
What is the name of the  "default profile" ?
I ran the code and it worked so I'm a little :?
CADwoman
Profiles
« Reply #2 on: February 14, 2005, 02:37:03 PM »
Thanks for responding to my question. The default profile is <<Unnamed Profile>>. But as far as I understand, since it loads the profile that matches your login (which I have) then shouldn't it reload the same profile?
Quote from: Mark Thomas
