Author Topic: VB Newbie - Cloning Styles for a Conversion Routine, Difficulty Level  (Read 1393 times)
Chillme1
  • Must learn to earn!
I would like to ask questions or see examples from those who have developed a conversion routine involving dimension and/or text styles and that are based on a cloned version of a CAD Standard-based DIMSTYLE?
QUESTION 1: How difficult in the length or in the complexity of code is it to obtain a clone and apply the clone's proerties to these (dimension or text) type of entities?  :oops:
Thanks, Clint
Mechanical Designer / Process Piping
AutoCAD Toolsets 2022
Newbie Betimes - LISP Programmer
Jeff H
Re: VB Newbie - Cloning Styles for a Conversion Routine, Difficulty Level
« Reply #1 on: October 11, 2011, 01:09:14 PM »
If I understand your question I think DeepClone will do fine then change whatever properties needed
        <CommandMethod("CloneTextDimStyle")> _
        Public Sub CloneTextDimStyle()
            Dim doc As Document = Application.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
            Using trx As Transaction = db.TransactionManager.StartTransaction()
                Dim dimTbl As DimStyleTable = trx.GetObject(db.DimStyleTableId, OpenMode.ForWrite)
                Dim dimBtr As DimStyleTableRecord = trx.GetObject(dimTbl("Standard"), OpenMode.ForRead)
                Dim dimMap As New IdMapping
                Dim newDimBtr As DimStyleTableRecord = dimBtr.DeepClone(dimTbl, dimMap, True)
                newDimBtr.Name = String.Format("{0} (Clone)", dimBtr.Name)
                newDimBtr.Dimalt = Not newDimBtr.Dimalt
                newDimBtr.Dimaltd = newDimBtr.Dimaltd + 1
                dimTbl.Add(newDimBtr)
                trx.AddNewlyCreatedDBObject(newDimBtr, True)
                trx.Commit()
            End Using
        End Sub
Chillme1
« Reply #2 on: October 19, 2011, 06:23:34 AM »
I appreciate the code snippet and will try it and get back to you. It may be a while!
Thanks, Clint
