If you use the static (Shared in VB) method of the Regex class, you have to separate the expressions in the pattern with the OR operator (|):
string[] point = Regex.Split(LineArray[i], ",|;|\t");
You can use the String.Split() method with characters, insted:
string[] point = LineArray[i].Split('\t', ',', ';');
