Author Topic: Turning off AutoCAD Map Message Dialog Box  (Read 4202 times)
cannorth
« on: September 22, 2011, 07:26:29 PM »
Hello,
  Is there anyway in LISP to turn off the AutoCAD Map Message Dialog Box in AutoCAD 2012?
Thanks,
cannorth
Matt__W
  • I like my water diluted.
Re: Turning off AutoCAD Map Message Dialog Box
« Reply #1 on: September 23, 2011, 08:36:14 AM »
Not sure which one you're referring to but FILEDIA = 0 will turn off all most dialog boxes.
Autodesk Expert Elite
cannorth
« Reply #2 on: September 23, 2011, 04:11:50 PM »
Hello,
  FILEDIA=0 doesn't turn off the dialog box.  It's an error dialog box that shows if something is wrong with Map queries or after a query has run.
Thanks,
cannorth
Crank
« Reply #3 on: September 24, 2011, 06:45:31 AM »
I don't have MAP, but something that you can try is to set bit 2 (4) of QAFLAGS (no "alert" dialogs, text display instead).
VovKa
  • Ukraine
« Reply #4 on: September 24, 2011, 07:52:08 AM »
try
(ade_errsetlevel 2)
rkmcswain
« Reply #5 on: September 26, 2011, 08:15:43 AM »
Actually, FILEDIA controls FILE DIAlogs.
CMDDIA used to control many CoMmanD DIAlogs, but it has limited effects these days. AutoCAD Map still honors it for many of its specific dialogs.
