yah, if you dont have qview drawings open and try to plot in the foregound, crash everytime, I'm pretty positive a fix didnt make it into the service pack either.
Quote from: Krushert on September 26, 2011, 12:58:16 PMQuote from: cmwade77 on September 23, 2011, 11:52:01 AMWe use Publish, here are the restrictions we have found:Prior to 2012, you must turn off background publishing, if you are publishing to a multi-sheet fileYou cannot have more than 4 tabs per drawing fileYou cannot have more than 10 viewports per tab, if you are publishing to a multi-sheet fileYou do not have to use Sheet Set manager, but it helps a lotI read that with Lawyer voice that states all the limitations for those sweepstakes or drug TV commercials.Yeah, I could see that, but I find Publish works great if you observe these limitations. It works very well in 2012, they did make a lot of fixes.
Here is a free onehttp://through-the-interface.typepad.com/through_the_interface/plotting/
