Sorry, I still use a slightly tweaked version of publish. I've got it pretty well figured out. What are the issues you are having with it? For everything else, i type in plt, hit enter twice, and get a plot file named and saved correctly.
the problem with publish is that sometime it work,....sometime not....sometime print corectly,...sometime not...
and we always use same pagesetups. Also,...many times the publish print correctly the 22 TAB that we have in our 23.
in some case, the first or the last one do not print. why ? I dunno..they are all same pagesetup and same cardridge.
moreover,...in some case the publish can print all corectly,....if we try again 1 hour after...it miss a Layout.
so users here are very tired about that.
For some reason, we can't use Sheetset (client restriction)
so to prevent wasting time to test, print and use tree for nothing...
we'r looking for better solution.
