Author Topic: Match orientation to layout  (Read 2594 times)
UWPMVG
  • Mosquito
« on: September 22, 2011, 05:17:17 AM »
Is it possible to change the "match orientation to layout" to TRUE for existing blocks in AutoCAD using VB.NET?
I have managed to change existing blocks to annotative using: btr.Annotative = AnnotativeStates.True
I've searched everywhere for an answer. Please help!
huiz
  • Certified Prof C3D
Re: Match orientation to layout
« Reply #1 on: September 22, 2011, 06:01:29 AM »
Isn't it a property of a block definition? Not a block property but from the definition.
UWPMVG
  • Mosquito
« Reply #2 on: September 22, 2011, 06:24:27 AM »
Does that mean that I can't change it afterwards and therefore need to redefine the block?
huiz
« Reply #3 on: September 22, 2011, 07:14:09 AM »
It is not a property which you can change per block. So yes, change it in the definition.
UWPMVG
  • Mosquito
« Reply #4 on: September 22, 2011, 08:49:45 AM »
Do you have any idea how that is done? I want all blocks with a specific name in the drawing to match the layout orientation.
Jeff H
« Reply #5 on: September 22, 2011, 02:32:30 PM »
You can check the block's PaperOrientation enum value which is read-only but use  the DBObject.SetPaperOrientation Method which a BlockTableRecord is a DBObject
Here is a example showing both members for changing  "match orientation to layout" to TRUE for a block named 'C'
You might need to Regen for changes to show up
        <CommandMethod("ChangePaperOreintation")> _
        Public Sub ChangePaperOreintation()
            Dim doc As Document = Application.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
            Using trx As Transaction = db.TransactionManager.StartTransaction()
                Dim bt As BlockTable = trx.GetObject(db.BlockTableId, OpenMode.ForRead)
                If bt.Has("C") Then
                    Dim btr As BlockTableRecord = trx.GetObject(bt("C"), OpenMode.ForRead)
                    If btr.PaperOrientation = PaperOrientationStates.False Then
                        btr.UpgradeOpen()
                        btr.SetPaperOrientation(True)
                    End If
                End If
                trx.Commit()
            End Using
        End Sub
UWPMVG
  • Mosquito
« Reply #6 on: September 23, 2011, 02:01:53 AM »
Thank you very much!!!! My application now works as I wanted to.
