Author Topic: Drafting Settings  (Read 2074 times)
Coder
Drafting Settings
« on: September 19, 2011, 12:55:07 AM »
Hello .
The value of my current osmode is 4143 and the MidPoint option is checked ( is on ) .
How can I know MidPoint option is check or not in my drafting settings through the value of the osmode  ?
Many thanks
kruuger
Re: Drafting Settings
« Reply #1 on: September 19, 2011, 01:17:52 AM »
Hello .
Many thanks
(defun c:test ()
  (if (zerop (logand 2 (getvar "osmode")))
    (princ "\n MID snap off")
    (princ "\n MID snap on")
k.
pBe
« Reply #2 on: September 19, 2011, 01:25:56 AM »
another
(setvar 'osmode (boole 6 2 (getvar 'osmode)))
Toggle MID on and off
Coder
« Reply #3 on: September 19, 2011, 01:46:19 AM »
Thank you so much guys ,
That's great .
« Reply #4 on: September 19, 2011, 09:08:35 AM »
Here is an oldie.
;;  CAB  10/5/2006
;;  Function to return the current osmode setting in the form of a string
;;  If (getvar "osmode") = 175
;;  (get_osmode)  returns   "_end,_mid,_cen,_nod,_int,_per"
;;  Usage
;;  (osnap (getpoint) (get_osmode))
(defun get_osmode (/ cur_mode mode$)
  (setq mode$ "")
  (if (< 0 (setq cur_mode (getvar "osmode")) 16383)
    (mapcar
      '(lambda (x)
         (if (not (zerop (logand cur_mode (car x))))
           (setq mode$ (strcat mode$ (cadr x)))
      '((0 "_non,")  (1 "_end,")   (2 "_mid,")   (4 "_cen,")   (8 "_nod,")
        (16 "_qua,") (32 "_int,")  (64 "_ins,")  (128 "_per,") (256 "_tan,")
        (512 "_nea,")(1024 "_qui,")(2048 "_app,")(4096 "_ext,")(8192 "_par")
  mode$
Coder
« Reply #5 on: September 19, 2011, 09:36:44 AM »
Very nice routine Mr CAB.
Thanks a lot .
« Reply #6 on: September 19, 2011, 10:53:53 AM »
You're welcome.
Dinosaur
« Reply #7 on: September 19, 2011, 11:19:28 AM »
Hello .
Many thanks
All are fine codes, but I believe that every possible combination of O-SNAP settings has a unique numerical value for OSMODE.  Thus, if your OSMODE value is indeed found to be 4143 your MidPoint setting must be checked or "ON" by definition.
« Reply #8 on: September 19, 2011, 11:44:24 AM »
Hello .
How can I know MidPoint option is check or not ...??
when it doesn't SNAP to an object's Mid-point would be a good check.    ;-)
