Author Topic: PDF Plot - to same Directory as opened drawing  (Read 10603 times)
Timmy007
« on: September 14, 2011, 10:54:23 AM »
I'm new to this forum, and LISP in general, so I apologise if this has been asked before, however I couldn't find a definitive answer by searching on here.
I have used this LISP routine which was uploaded to the Autodesk Uni site back in 2009, I can get the routine to plot to PDF, however it seems to save the file to the last manually opened file's directory - i.e I opened a image file and then ran the routine on a previously opened dwg, and the PDF was save to the image file directory - not very useful if you're working in a large organisation!
It therefore only seems to do what I want it to if you open the dwg files directly and then run the routine there and then, it seems to revert back to the last manually opened directory to save the PDF file? I dragged and dropped lots of files and ran the routine, they ended up in My Documents - all very odd and confusing!
What I need to be able to do, is to run the routine, and the PDF will be saved in the directory in which the opened drawing is saved in. This also needs to work if you "drag and drop" the files into AutoCAD and run the routine, I'm sure its just a simple one liner but I haven't managed figure it out.
The LISP routine is below:
;A0-size Landscape Extents Fit Center Monochrome - using .pc3 file
(defun c:1PPPDF_A0LEFCM_DWG_PDF( / currtab dwgnameonly cdname)
(setq currtab (getvar "ctab"));Gets the current layout tab name
(setq dwgnameonly (getvar "dwgname"));Gets variable value for drawing name which includes the .dwg extenstion.
(setq cdname (substr dwgnameonly 1 (- (strlen dwgnameonly) 4)));Gets drawing name and strips file name extension.
(if (= (getvar "tilemode") 1);Determines if you are in Paperspace or Modelspace
(progn ;This part of program runs if you are in modelspace
(command "-plot" "y" "model" "DWG To PDF.pc3" "ISO expand A0 (841.00 x 1189.00 MM)" "M" "L" "n" "Extents" "fit" "Center" "y" "_wyg_mono.ctb" "y" "As" "n" cdname "y" "y")
);end progn
(progn ;This part of program runs if you are in paperspace
(command "-plot" "y" currtab "DWG To PDF.pc3" "ISO expand A0 (841.00 x 1189.00 MM)" "M" "L" "n" "extents" "fit" "center" "y" "_wyg_mono.ctb" "y" "n" "y" "n" cdname "y" "y")
);end progn
);end if
);end defun
Thanks in advance
Matt__W
  • I like my water diluted.
Re: PDF Plot - to same Directory as opened drawing
« Reply #1 on: September 14, 2011, 11:13:35 AM »
);end progn
);end progn
);end if
);end defun
The code isn't defining a location for the file to be saved, just the name (cdname).  You need to get the drawing prefix AND the name and combine the two to create a full path where the file is to be saved.
(defun C:Test ( / cdname cdprefix dwgnameonly FullNameAndPath)
   (setq cdprefix (getvar "dwgprefix"))
   (setq FullNameAndPath (strcat cdprefix cdname))
   (alert FullNameAndPath)
Autodesk Expert Elite
« Reply #2 on: September 14, 2011, 11:14:19 AM »
Welcome to the forum Timmy007! I hope you like it here  8-)
Give this a try:
(defun c:test ( / cm )
    (setq cm (getvar 'CMDECHO))
    (setvar 'CMDECHO 0)
    (command "_.-plot" "_y"
        (if (= 1 (getvar 'TILEMODE)) "Model" (getvar 'CTAB))
        "DWG To PDF.pc3"
        "_M" "_L" "_N" "_E" "_F" "_C" "_Y" "_wyg_mono.ctb" "_Y" "_A"
        (strcat (getvar 'DWGPREFIX) (vl-filename-base (getvar 'DWGNAME)))
        "_Y" "_Y"
    (setvar 'CMDECHO cm)
(vl-load-com) (princ)
It could probably do with some more error trapping should the plotter / paper / style not exist.
« Last Edit: September 15, 2011, 02:50:04 PM by Lee Mac »
Timmy007
« Reply #3 on: September 14, 2011, 12:17:35 PM »
Hi guys,
Thanks for the swift replies! - I'm looking forward to learning lots about LISP on the forum! it's something I've dabbled in for a few years, but never taken too seriously!
Matt, whilst what you're saying makes sense, I still get the same result when I used your code? I have placed mine below - maybe I'm doing something wrong??
(defun c:1PPPDF_A0LEFCM_DWG_PDF( / cdname cdprefix dwgnameonly FullNameAndPath)
(command "-plot" "y" "model" "DWG To PDF.pc3" "ISO expand A0 (841.00 x 1189.00 MM)" "M" "L" "n" "Extents" "fit" "Center" "y" "_wyg_mono.ctb" "y" "As" "n" cdname cdprefix dwgnameonly FullNameAndPath "y" "y")
);end progn
(command "-plot" "y" currtab "DWG To PDF.pc3" "ISO expand A0 (841.00 x 1189.00 MM)" "M" "L" "n" "extents" "fit" "center" "y" "_wyg_mono.ctb" "y" "n" "y" "n" cdname cdprefix dwgnameonly FullNameAndPath "y" "y")
);end progn
);end if
);end defun
it also then asks me for the last 2 plot promts of "save changes to plot set up" & "proceed with plot"?
Lee, I will have to have a more detailed look at your code, as it errors and doesn't run, but I'll have a look to see if I can decifer the problem - and probably then ask you for help with it! lol  :lol:
« Reply #4 on: September 14, 2011, 02:12:12 PM »
What error do you get Timmy? I gave it a quick test before posting and all seemed to be fine  :?
Timmy007
« Reply #5 on: September 15, 2011, 03:59:15 AM »
Hi Lee,
when I run the LISP it starts to run, but then crashes out I've pasted in the command line text for you to see where its crashing.
Command: test
Unknown command "Y".  Press F1 for help.
Unknown command "AS".  Press F1 for help.
Unknown command "N:\PROJECTS\A059001 - A059500\A059473\ACAD\ELDON\SHEET
FILES\ELECTRICAL\A059473-1-28-E-2000_03".  Press F1 for help.
« Reply #6 on: September 15, 2011, 06:20:33 AM »
Looks like Lee may have this name incorrect, try this spelling  "_wyg_mono.ctb"
Although there is a Yes before the Drawing name that looks out of place too.   :-o
« Last Edit: September 15, 2011, 06:24:54 AM by CAB »
Timmy007
« Reply #7 on: September 15, 2011, 08:16:43 AM »
I've managed to get the paperspace printing to work now, and it creates the PDF to the dwg files origin directory which is great!! I've used a combination of the original routine, and Lee's and Matt's - so thanks for your help  :-)
What I can't seem to get is the model space to work... This seems to place the pdf in the last opned file driectory (as before) but now also calls the PDF file "n" or "y". I know this is to do with something within the routine, but i'm stumped after that!
(defun c:1PPPDF_A0LEFCM_DWG_PDF( / cm cdname cdprefix dwgnameonly FullNameAndPath)
    (setvar 'CMDECHO 0)
(command "-plot" "y" "model" "DWG To PDF.pc3" "ISO expand A0 (841.00 x 1189.00 MM)" "M" "L" "n" "Extents" "fit" "Center" "y" "_wyg_mono.ctb" "y" "As" "n" (strcat (getvar 'DWGPREFIX) (vl-filename-base (getvar 'DWGNAME))) "y" "y")
);end progn
(command "-plot" "y" currtab "DWG To PDF.pc3" "ISO expand A0 (841.00 x 1189.00 MM)" "M" "L" "n" "extents" "fit" "center" "y" "_wyg_mono.ctb" "y" "n" "y" "n" (strcat (getvar 'DWGPREFIX) (vl-filename-base (getvar 'DWGNAME))) "y" "y")
);end progn
);end if
);end defun
« Reply #8 on: September 15, 2011, 02:50:58 PM »
Hi Lee,
Command: test
I see I mispelled the ctb filename - please try my updated code above.  :-)
Timmy007
« Reply #9 on: September 16, 2011, 06:58:15 AM »
Hi Lee
Thanks for amending the code, I tested it out this morning, and it wprks great in model space. How would I amend it to work in paperspace also?
My code above works flawlessly in paperspace - which should be fine for what we need it for, but itsn't as clean as your code - I'm still very new to LISP  :-D
« Reply #10 on: September 17, 2011, 09:02:22 AM »
Assuming the prompts are correct for your code, give this a try:
    (setvar 'CMDECHO 0)
        (command "_A")
        (command "_N" "_Y")
    (command "_N" (strcat (getvar 'DWGPREFIX) (vl-filename-base (getvar 'DWGNAME))) "_Y" "_Y")
rhino
« Reply #11 on: September 19, 2011, 02:11:55 PM »
might want to look at this code:
http://www.theswamp.org/index.php?topic=28078.0
the prompts and command sequence needs to be tweaked to work in paperspace though...
rhino
« Reply #12 on: October 12, 2011, 11:04:56 PM »
Is there a way to pass the file name and location to cutepdf via vba?
The following link shows how the file name and path are provided for an ms. access document...
http://bytes.com/topic/access/answers/879916-create-pdf-report-using-cutepdf-means-vba
We have a batch plot routine and would like to use cutepdf for plotting as ACAD 2007 dwg to pdf.pc3 results in large pdf files
As cutepdf behaves like a printer it opens outside the ACAD shell - which is why we can't pass the file name or path via lisp...
Thanks for the help.
pBe
« Reply #13 on: October 13, 2011, 03:54:51 AM »
One thing i noticed when using "DWG to PDF.pc3" is somehow it wont print "RTEXT" entity.
We had a diesel expression at the bottom left corner of our standard Title Block and it just wont show on the resulting pdf
since we lost our cutepdf.pc3, we ended up using "ADOBE PDF.pc3"  which prompts for filename.
Its not like we cant change the titleblock but its more of  nagging issue with me.
Any thoughts on this?
cmwade77
« Reply #14 on: October 13, 2011, 12:07:50 PM »
What version of AutoCAD? In 2012 this seems to work fine.
