Author Topic: [challenge]avoid 2 collision convex-polygon in any angle .  (Read 7656 times)
chlh_jd
« on: September 13, 2011, 04:48:23 PM »
Hi all , to avoid 2 collision convex-polygon in any angle , we supose : first polygon is collision wiht second polygon , and we just move the 2nd polygon to avoid 1st polygon,  here's your codes ...
Re: [challenge]avoid 2 collision convex-polygon in any angle .
« Reply #1 on: September 13, 2011, 04:50:23 PM »
Could you perhaps provide a diagram of the desired result?
chlh_jd
« Reply #2 on: September 13, 2011, 05:20:08 PM »
sorry for offten less . like the picture .
chlh_jd
« Reply #3 on: September 13, 2011, 05:24:29 PM »
if we up the deep , we can add min-distance (tor) , such as 1st distance to 2nd by tor or 2nd distance to 1st by tor .
« Reply #4 on: September 13, 2011, 05:24:35 PM »
Would the user specify the 'move angle'?
chlh_jd
« Reply #5 on: September 13, 2011, 11:59:09 PM »
You're right Lee .
The angle is often by user , but it's any angle .
chlh_jd
« Reply #6 on: September 14, 2011, 09:24:26 AM »
Here's mine , I believe it can be simplied .
(defun c:test (/ foo l1 l2 ang new ss oldm ent i)
  ;;by GSLS(SS)
  (defun foo
     (l1 l2 ang / l3 dis ip1)
    (setq l3 (mapcar (function (lambda (x)
(polar x ang 1e10)
     l2
    (setq dis 1e99)
    (foreach a l3
      (if (setq ip1 (l_int_pl a (polar a ang -1e20) l1))
(setq dis (min dis (distance a (mindis-pt ip1 a))))
    (foreach a l1
      (if (setq ip1 (l_int_pl a (polar a ang 1e20) l3))
(polar x ang (- dis))
    l3
  (setq oldm (getvar "modemacro"))
  (setvar "modemacro" "Select Lines for angle:")
  (setq l1 (ss-assoc 10
     (entget (car (entsel "\nSelect 1st Polygon:")))
l2 (ss-assoc 10
     (entget (car (entsel "\nSelect 2nd Polygon:")))
ss (ssget)
i 1
  (if (and l1 l2 ss)
    (foreach en (ss2lst ss nil)
      (setq
ang (angle (dxf 10 (setq ent (entget en)))
   (dxf 11 ent)
      (if (setq new (foo l1 l2 ang))
(progn(draw-pl (list new (cons 62 i)))
  (setq i (1+ i)))
(princ (strcat "angle = " (angtos ang) " error."))
  (setvar "modemacro" oldm)
(defun dxf (co en)
  (if (eq (type en) (quote ENAME))
    (setq en (entget en (quote ("*"))))
  (if (vl-consp co)
    (mapcar (function (lambda (x) (cdr (assoc x en)))) co)
    (cdr (assoc co en))
(defun ss-assoc (a lst / b res)
  (while (setq b (assoc a lst))
    (setq lst (cdr (member b lst))
  res (cons (cdr b) res)
  (reverse res)
(defun ss2lst (ss vla / a e i)
  (if (= (type ss) (quote PICKSET))
      (setq i -1)
      (while (setq e (ssname ss (setq i (1+ i))))
(if vla
  (setq e (vlax-ename->vla-object e))
  nil
(setq a (cons e a))
    nil
(defun draw-pl (lst)
  (entmake
    (append
      (list (cons 0 "LWPOLYLINE")
    (cons 100 "AcDbEntity")
    (cons 100 "AcDbPolyline")
    (cons 90 (length (car lst)))
      (mapcar (function (lambda (x) (cons 10 x))) (car lst))
      (list (cons 70 1))
      (cdr lst)
(defun mindis-pt (lst pt)
  (car
    (vl-sort lst
     (function (lambda (e1 e2)
(< (distance e1 pt) (distance e2 pt))
(defun L_INT_PL (p1 p2 l / p3 p4 p res)
  (setq l (cons (last l) l))
  (while (cadr l)
    (setq p3 (car l)
  p4 (cadr l)
  l  (cdr l)
    (setq p (inters p1 p2 p3 p4))
    (if p
      (setq res (cons p res))
  res
« Reply #7 on: September 14, 2011, 10:17:08 AM »
(defun c:test ( / an o1 o2 o3 o4 p1 p2 p3 p4 )
        (and
            (setq o1 (car (entsel "\nObject 1: ")))
            (setq o2 (car (entsel "\nObject 2: ")))
            (setq an (getangle "\nMove Angle: "))
            (setq o1 (vlax-ename->vla-object o1)
                  o2 (vlax-ename->vla-object o2)
            (vla-rotate (setq o3 (vla-copy o1)) (vlax-3D-point '(0. 0.)) (- an))
            (vla-rotate (setq o4 (vla-copy o2)) (vlax-3D-point '(0. 0.)) (- an))
            (vla-getboundingbox o3 'p1 'p2)
            (vla-getboundingbox o4 'p3 'p4)
            (vla-move o1
                (vlax-3D-point
                    (polar '(0. 0.) an
                        (-  (car (vlax-safearray->list p4))
                            (car (vlax-safearray->list p1))
            (vla-delete o3) (vla-delete o4)
qjchen
  • Best wishes to all
« Reply #8 on: September 15, 2011, 06:01:46 AM »
Lee's code can quickly move the objects to avoid collide, and maybe chlh_jd 's code is to find the min distance at the given angle~
http://qjchen.mjtd.com
My blog http://chenqj.blogspot.com (Chinese, can be translate into English)
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #9 on: September 15, 2011, 07:16:56 AM »
Your program only for convex polygons?
qjchen
« Reply #10 on: September 15, 2011, 11:39:15 AM »
:) The following is my solution
Only for pline consist of line
by can deal with not only convex pline , but also concave pline.
The Algorithm is as in the gif
(I am not sure whether chlh_jd has the same algorithm, because I see 1e20  :-))
OK, It is late to go to bed, byebye~~
;;;; get the vertex of the polyline
(defun q:ent:lwpolyline:vertex (ent / pt_list)
  (foreach x ent
    (if (= (car x) 10)
      (setq pt_list (append(list (cdr x))pt_list))))
  pt_list
;;;; To deal the intersection of each two set
(defun q:q1:deal1(plst1 plst2 ang / a b)
  (setq a (q:q1:deal2 plst1 plst2 ang))
  (setq b (q:q1:deal2 plst2 plst1 (+ ang 3.1415926535897)))
  (if (< (cadr a) (cadr b)) (setq a b))
  a
(defun q:q1:deal2(lst1 lst2 ang / dis dis1 i lst1a p res x x1 y)
  (setq lst1a (reverse (cons (car lst1) (reverse (cdr lst1)))))
  (foreach x lst2
    (setq x1 (polar x ang 1e7) i 0)
    (foreach y lst1
       (if (setq p (inters x x1 y (nth i lst1a)))
           (if (> (setq dis1 (distance p x)) dis) (setq res p dis dis1))
       (setq i (1+ i))
  (list res dis)
;;;;; Main function
(defun c:tt( / a ang lst1 lst2 o1 o2 res)
        ang (getangle "\nMove Angle: ")
        lst1 (q:ent:lwpolyline:vertex (entget o1))
        lst2 (q:ent:lwpolyline:vertex (entget o2))
        res (q:q1:deal1 lst1 lst2 ang))
(princ "\n             res = ") (princ res);Erase_DV
  (if (setq a (car res))
  (vla-move (vlax-ename->vla-object o2)
      (vlax-3D-point a)
      (vlax-3D-point (polar a ang (cadr res)))
(princ "\n By qjchen")
« Reply #11 on: September 15, 2011, 02:54:18 PM »
Yes, it was only a very simple solution  8-)
« Reply #12 on: September 15, 2011, 03:38:35 PM »
Great algorithm Chen!  8-)
Here is my version using your algorithm, I hope you don't mind  :-)
(defun c:test ( / a b c )
        (and
            (setq a (car (entsel "\nObject 1: ")))
            (setq b (car (entsel "\nObject 2: ")))
            (setq c (getangle "\nMove Angle: "))
        (vla-move (vlax-ename->vla-object b) (vlax-3D-point '(0. 0. 0.))
            (vlax-3D-point
                (polar '(0. 0. 0.) c
                    (apply 'max
                        (apply 'append
                            (apply 'mapcar
                                (cons
                                    (function
                                        (lambda ( a b ) (setq c (+ c pi))
                                            (apply 'append
                                                (mapcar
                                                    (function
                                                        (lambda ( a )
                                                            (apply 'append
        (mapcar
        (function
        (lambda ( x y )
        (if (setq z (inters a (polar a c 1e8) x y))
        (list (distance z a))
        b (cons (last b) b)
                                                    a
                                    (   (lambda ( a ) (list a (reverse a)))
                                        (mapcar
                                            (function
                                                (lambda ( a )
                                                    (apply 'append
                                                        (mapcar
                                                            (function
        (lambda ( a ) (if (= 10 (car a)) (list (cdr a))))
                                                            (entget a)
                                            (list a b)
qjchen
« Reply #13 on: September 15, 2011, 11:36:10 PM »
Thanks Lee, I am very glad that you like this algorithm~~.
And I like your concise code and beautiful code style (Evgeniy use the same style~, it make me feel dizzy, but I like it very much).
I will try to shorten my code~.
Ketxu
« Reply #14 on: September 16, 2011, 12:08:01 AM »
The 2nd LM's code make me feel dizziness ^^. But i think the 1st code can be improved to use with more Objects type  :)
