Author Topic: How to draw a line or a polyline with Foreach function  (Read 2859 times)
Coder
« on: September 12, 2011, 03:31:44 PM »
Hello everybody .
I stock with this part of code , I want to use foreach function to draw a line or polyline .
(setq pnts '((11 34.614 7.48336 0.0) (11 18.7203 7.48336 0.0) (11 14.9239 12.8179 0.0) (11 7.42747 12.8179 0.0)))
(foreach p pnts
  (command "_.line" ......
Thanks in advance
David Bethel
Re: How to draw a line or a polyline with Foreach function
« Reply #1 on: September 12, 2011, 04:12:13 PM »
There are tons of way to accomplish this
Assuming that you want to strip the 11 off of the front end of each atom:
  (while (> (length pnts) 1)
         (command "_.LINE" (cdr (nth 0 pnts)) (cdr (nth 1 pnts)) "")
         (setq pnts (cdr pnts)))
And that you don't mind destroying the list 'pnts....
-David
R12 Dos - A2K
« Reply #2 on: September 12, 2011, 04:26:43 PM »
Here is another way to consider:
(defun makelines (lst lay / lastpt newlines)
  (foreach pt lst
    (setq pt (cdr pt))                  ; strip 11
    (if lastpt
      (setq newlines
             (cons
               (entmakex
                 (list (cons 0 "LINE")  ;***
                       (cons 6 "BYLAYER")
                       (cons 8 lay)
                       (cons 10 pt)     ;***
                       (cons 11 lastpt) ;***
                       (cons 39 0.0)
                       (cons 62 256)
                       (cons 210 (list 0.0 0.0 1.0))
               newlines
    (setq lastpt pt)
  newlines
(makelines pnts "0")
(<Entity name: 7ee8b608> <Entity name: 7ee8b600> <Entity name: 7ee8b5f8>)
Coder
« Reply #3 on: September 13, 2011, 12:28:08 AM »
Thank you , both are working great .
Will it be possible with MLINE and POLYLINE ?
Appreciated a lot .
irneb
« Reply #4 on: September 13, 2011, 02:45:21 AM »
Appreciated a lot .
Well, that should be quite simple. For a pline you could go with:
(defun makeplines (lst / )
  (command "_.PLINE")
  (foreach pt lst
    (command "_None" pt)
I tested your list like this:
(makeplines (mapcar 'cdr pnts))
Note the "_None" object snap to allow it to work even if you've got running object snaps turned on. IMO it's a better idea than to temporarily set SnapMode, otherwise you need extra error traps and such.
But  ;D ... I'd advise going with CAB's idea of creating the line/pline programatically, instead of through a command call. It allows for more options and generally runs faster. How to accomplish that for an MLine might be a bit complex though.
HofCAD
« Reply #5 on: September 13, 2011, 05:43:08 AM »
Appreciated a lot .
(defun MakePlines (Pnts Lay Close / Z)
  (if (setq Z (cadddr (car Pnts)))
    Z
    (setq Z 0)
  (entmakex
    (append (list '(0 . "LWPOLYLINE")
  '(100 . "AcDbEntity")
  '(100 . "AcDbPolyline")
  (cons 8 Lay)
  (cons 90 (length Pnts))
  (cons 38 Z)
  (cons 70 Close);;;0 = open 1 = closed
    (mapcar (function (lambda (p) (cons 10 (cdr p))))
    Pnts
(setq Pnts '((11 34.614 7.48336 0.0) (11 18.7203 7.48336 0.0) (11 14.9239 12.8179 0.0) (11 7.42747 12.8179 0.0)))
(makePlines Pnts "0" 0)
Regards HofCAD CSI
VVA
« Reply #7 on: September 13, 2011, 09:00:20 AM »
Another quick example:
(defun _makepline ( lst )
    (entmakex
        (append
            (list
                (cons 0 "LWPOLYLINE")
                (cons 100 "AcDbEntity")
                (cons 100 "AcDbPolyline")
                (cons 90 (length lst))
                (cons 70 0)
            (mapcar '(lambda ( p ) (cons 10 (cdr p))) lst)
(_makepline pnts)
You might find this thread of benefit.
Andrea
« Reply #8 on: September 13, 2011, 09:14:13 AM »
some other way....
(setq ptlist '((0.0 0.0)(10.0 0.0)(10.0 10.0)(20.0 10.0)))
;;EXAMPLE 1
(command "pline")
(mapcar '(lambda (x)
   (command x)
ptlist)
(command "")
;;EXAMPLE 2
(command "_.pline")
(foreach pt PtList
 (command pt)
(command "")
;;EXAMPLE 3
   (apply 'command
    (append
       '(".pline")
        ptlist
Keep smile...
alanjt
  • Standby for witty remark...
« Reply #9 on: September 13, 2011, 09:45:22 AM »
For the LINE portion:
(defun _lines (lst)
  (mapcar '(lambda (a b) (entmakex (list '(0 . "LINE") (cons 10 a) (cons 11 b))))
          lst
          (cdr lst)
Dropbox
« Reply #10 on: September 13, 2011, 10:40:13 AM »
Very clever Alan.  8-)
irneb
« Reply #11 on: September 13, 2011, 11:06:52 AM »
Yep! Never thought of doing that. I'd have made some global variable (or rather local to surrounding defun), then setq'd from inside the lambda. Alan's is much neater!
alanjt
« Reply #12 on: September 13, 2011, 11:34:55 AM »
(defun _linesClosed (lst)
          lst
          (append (cdr lst) (list (car lst)))
Dropbox
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #13 on: January 09, 2012, 10:34:01 AM »
          lst
I recommend:
          (cons (last lst) lst)
          lst
alanjt
« Reply #14 on: January 09, 2012, 10:44:47 AM »
          lst
I recommend:
          lst
nice
Dropbox
