Author Topic: Wow, a new one today!!!  (Read 3965 times)
craigr
« on: August 29, 2011, 09:35:19 AM »
We use the simple floor plans of a building and add our equipment to that floor plan.
We always get our floor plans from outside engineers.
After 15 years of this, I ran into something I have never seen. -
FIVE floors in ONE drawing!! This includes typical building equipment, HVAC, plumbing, etc....
The file size is only 571kb.
Just another example of learning something new every day.
craigr
Matt__W
  • I like my water diluted.
Re: Wow, a new one today!!!
« Reply #1 on: August 29, 2011, 10:04:07 AM »
I hope they aren't stacked on top of each other.
Autodesk Expert Elite
craigr
« Reply #2 on: August 29, 2011, 10:04:47 AM »
Yes, they are.
It's really different.
Matt__W
« Reply #3 on: August 29, 2011, 10:07:04 AM »
Yes, they are.
It's a NIGHTMARE to have to deal with that when you aren't familiar with their work process.  We've seen that before.  Trying to strip out the various floors to use as backgrounds is tedious & time-consuming at best.
craigr
« Reply #4 on: August 29, 2011, 10:15:36 AM »
Most, but not all of the layers had something similar to '5th' at the end of the layer names, which helped a lot.
Though, I think I would have put the '5th' at the begining of the name, to group that layers together.
It wasn't HORRIBLE to pull everything apart, and I'm not complaining. It was just so radically different from what I typically see.
craigr
« Reply #5 on: August 29, 2011, 10:33:12 AM »
That's exactly the way I work. You need a layer filter from them to easily switch from floor to floor and discipline to discipline.
Once you understand the technique it simple enough.
F1_ = Floor Plan 1st Floor
F2_ = Floor Plan 2nd Floor
FJ1_ = Floor Joist
You get the picture.  8-)
« Reply #6 on: August 29, 2011, 10:36:29 AM »
As long as they were NOT all on layer ZERO with color and linetype set to BY OBJECT you should be golden.   ;-)
craigr
« Reply #7 on: August 29, 2011, 10:37:52 AM »
THAT would be HORRIBLE -- LOL!!
Jeff H
« Reply #8 on: August 29, 2011, 10:42:50 AM »
That just seems to make it more complicated and open for more errors
craigr
« Reply #9 on: August 29, 2011, 10:45:48 AM »
I went back and looked at the original and there were no layer filters.
The filter thingy would make it much easier.
« Reply #10 on: August 29, 2011, 11:04:07 AM »
I use the Express Tools layer manager just because I started that way but you need to have them sent you the layer filters as an exported file. Although not too difficult to recreate.
I thought that the Layer Filter was saved in the drawing for both types of layer filters. Did you check for Express Tools layer filters?
craigr
« Reply #11 on: August 29, 2011, 11:06:18 AM »
I don't have 'Express Tools'.
A coworker is the one that dealt with this original file. She told me about it.
She just deleted the floors, (layers), we don't need. - Of course, keeping the original file.
« Reply #12 on: August 29, 2011, 11:21:38 AM »
Sounds like you have this one under control but I would be glad to look for the Express Tools Layer Filters if you like.
craigr
« Reply #13 on: August 29, 2011, 11:22:31 AM »
That's okay, but thanks for the offer.
Greg B
  • Tell me a Joke!
« Reply #14 on: August 29, 2011, 12:13:31 PM »
DataCAD does it that way.  Pretty slick really.  Lot's of managing of layers built into the program.
Allows you to make sure the walls line up from floor to floor easier.
If you make sure you have the right layers on and off when exporting the receiving party should have had no problems!
