Author Topic: Iterate through documents and close drawings  (Read 2534 times)
alexborodulin11
« on: August 25, 2011, 09:08:27 PM »
Why after iterating through all drawings with closing each document similar to code shown below, one drawing is still on the screen. How to iterate and close all drawings?
  Dim docs As DocumentCollection
        Dim doc As Document
                docs = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager
        For Each doc In docs
            'do things,
'then
'doc.CloseAndDiscard() or
'doc.CloseAndSave(doc.Name)
        Next
Re: Iterate through documents and close drawings
« Reply #2 on: August 25, 2011, 09:44:07 PM »
Welcome to the Swamp!!!
Are you in Application execution context?-----Session command flag
This works fine for me
         <CommandMethod("CloseAllDrawings", CommandFlags.Session)> _
        Public Sub CloseAllDrawings()
            Dim docs As DocumentCollection = Application.DocumentManager
            For Each doc As Document In docs
            Next
This will leave one the current document open.
It executes in the 'document context'
        <CommandMethod("CloseAllDrawingsWithoutSession")> _
        Public Sub CloseAllDrawingsWithoutSession()
                Try
                Catch ex As System.Exception
                End Try
            Next
If I remember correctly since it executes in 'document context' it is locked automatically not allowing it to close
alexborodulin11
« Reply #3 on: August 25, 2011, 10:04:24 PM »
the same result: current drawing is still open
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #4 on: August 25, 2011, 10:34:11 PM »
Works for me
// (C) kdub
using System;
// This line is not mandatory, but improves loading performances
[assembly: CommandClass(typeof(CloseAllDocuments.MyCommands))]
namespace CloseAllDocuments
    public class MyCommands
        [CommandMethod("CloseAllDrawings", CommandFlags.Modal | CommandFlags.Session)]
        public void CloseAllDrawings()
            DocumentCollection docs = Application.DocumentManager;
            foreach (Document doc in docs)
                doc.CloseAndDiscard();
Called Kerry in my other life
I live at UTC + 13.00
alexborodulin11
« Reply #5 on: August 25, 2011, 10:45:11 PM »
Jeff:
Adding
solved the problem
Thank you!
Alex
