Author Topic: Setting DIMSCALE  (Read 5111 times)
JimAndi
Setting DIMSCALE
« on: August 23, 2011, 10:15:32 AM »
Hi All,
I am getting a Error with this code:
Double LTSCALEV, DIMSCALEV;
DIMSCALEV = Convert.ToDouble(dsTITLEBLOCK4.Rows[0]["DIMSCALE"].ToString());
Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("DIMSCALE", DIMSCALEV);
I am getting a "eInvalidInput" error with the value of DIMSCALEV
Jeff H
Re: Setting DIMSCALE
« Reply #1 on: August 23, 2011, 10:32:47 AM »
Since this works fine
                Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("DIMSCALE", 2.5);
I would think your problem is with
« Reply #2 on: August 23, 2011, 10:39:51 AM »
public static void SetSystemVariable(string name, object value)
kaefer
« Reply #3 on: August 23, 2011, 11:12:31 AM »
Another possible pitfall, albeit one AutoCAD takes care of, AFAIK:
 System.Convert.ToDouble("2.5") might return 25.0. If in doubt, throw in System.Globalization.CultureInfo.InvariantCulture.
JimAndi
« Reply #4 on: August 23, 2011, 12:11:38 PM »
I tried this: Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("DIMSCALE", 12.0); and get the same error
Jeff H
« Reply #5 on: August 23, 2011, 12:31:08 PM »
What year and or vertical are you using?
Ad if you try this all by itself does it fail?
         [CommandMethod("DimScaler")]
        public void DimScaler()
JimAndi
« Reply #6 on: August 23, 2011, 12:54:45 PM »
VS-2010 .NET 4.0 in C#.  AutoCAD 2012
This works fine
  Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("LTSCALE", 6.0);
This errors
JimAndi
« Reply #7 on: August 23, 2011, 01:19:14 PM »
Fixed it....  must be inside the document.LockDocument(); function
Glenn R
« Reply #8 on: August 25, 2011, 08:52:02 AM »
No, it doesn't. It will depend entirely on the context of where it's being called from.
