Author Topic: AutoLISP: bmp2fas, bmp2dcl,jpg2dcl,jpg2fas, sld2html lsp2cpp cpp2lsp sld2grdraw  (Read 11667 times)
d2010
« Last Edit: December 11, 2020, 02:40:04 AM by d2010 »
trogg
NOOOO!!!
Are you assuming that Lisp (Vanilla or Visual) is going away?
Or are you advertising your product?
Kind of odd minds so brilliant they can define a new age don't know a thing about marketing. Between that, one post e-cred and the "content" at the target url (no I won't click it) I call bull5h!t.
dgorsman
Similar to many random postings over at the AutoDesk forum.  I call advert.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
Jeff H
Be careful after spending 20 minutes trying to figure out what to do at the link that had nothing on it but
CLICK
HERE
 it will take you to a YouTube video with a very catchy rave song that made me get up and dance.
  :realmad:
Please goto this page...[/url]
I make the suggestion genuinely -- please -- get someone else to do your PR.
SOFITO_SOFT
Hi all ...
The world is a very very small handkerchief.  :-) :-) :-)
Our friend D2010 has chosen to make the documentation of his convert c ++lisp a program a few weeks ago I was looking for.
I have found several, complicated and cumbersome. The code of the Romanian D2010 friend   is the clearest and most orderly of 6 or 8 programs that I can look ( Conversion of LAT / LONG to UTM in any  DATUM )
D2010 , friend ! thank you very much !!!
Greetings.  :-)
Hi..... :wink:
The other users question: The new programming language C++LISP is stupid?
MeAnswer: The swampUsers, please goto this page and read carefully
       http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/Why-does-Autodesk-ignores-the-LISP-community/td-p/1116049
Regards the swampComunity
I'm not a programmer, however I followed your link...
I couldn't tell what it was you were selling..a converter
OR
Romanian Brides?
hermanm
Chad Wanless tried this years ago.
It was (IMO) a dismal failure, not because of any lack of programming talent, but because of the fundamental disparity between a functional programming language, such as LISP, and an imperative language, such as C++.
A "simple minded" LISP->C++ translator will restrict you to writing "simple minded" LISP programs, which defeats the purpose of using LISP.
Those few individuals with the sophisticated knowledge required to translate a moderately complex LISP program (any flavor, AutoLISP or otherwise) to an efficient C++ program are unlikely to waste their talents doing so, IMO.
hermanm
BTW, I'll take "Romanian Brides" for 300, Alex.
(esp. if the forsythia is included).
 :-D
LE3
Re: The NewAge of Visual LISP, we transform the user'LISP into user C++/LISP
« Reply #10 on: August 25, 2011, 09:11:40 PM »
X2
Same impression - the logic is not the same - also the code used looks like it is ADS no ObjectARX so any new of the functions are not available?.
And why do you need your code in C++ when you do not know the language?
Would like to see how they solved the use or conversion of mapcar...
hermanm
« Reply #11 on: August 25, 2011, 09:27:57 PM »
In the "old days" (perhaps circa 1984) it might have made made some kind of sense, if you had a computationally intense program, but only knew how to write AutoLISP.
These days, it makes no sense at all, AFAIK.
Jeff H
« Reply #12 on: August 25, 2011, 09:51:26 PM »
Seems like you need to learn C++  to be able understand how they relate instead of remembering this group words 'will do the same as this Lisp'---(but not understanding why it produces the same output and the correct way to handle it in other context)
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #13 on: August 26, 2011, 01:37:14 AM »
d2010,
Can you please post several  sample Lisp files with ActiveX (VLISP) functions and methods and the converted C++ code files.
... also can you provide the code compiled for AutoCAD 2012 64 bit.
Regards
Called Kerry in my other life
I live at UTC + 13.00
jbuzbee
« Reply #14 on: August 26, 2011, 11:09:21 AM »
I think I still have a copy of one of the first prototypes of "SharpLisp".  Promising, but it never happened.  Maybe Chad was side lined by his illness?  Truly a brilliant programmer!
James Buzbee
Windows 8
