Author Topic: save a dwg before opening another dwg  (Read 5338 times)
andrew_nao
« on: August 19, 2011, 02:04:43 PM »
does anyone have any suggestions on what would be the best way via lisp code to do the follow:
lets say you have dwg A opened, you do some work and dont sve and you want to open dwg B but before dwg B can open dwg A is automatically saved and then dwg B can now open
Re: save a dwg before opening another dwg
« Reply #1 on: August 19, 2011, 02:19:11 PM »
A command reactor comes to mind:
(or *cmdreactors*
    (setq *cmdreactors* (vlr-command-reactor nil '((:vlr-commandwillstart . strtcmd))))
(defun strtcmd (calling-reactor strtcmdinfo /)
  (or *adoc* (setq *adoc* (vla-get-activedocument (vlax-get-acad-object))))
  (if (and (wcmatch (car strtcmdinfo) "OPEN") (= (getvar 'dwgtitled) 1))
    (vla-save *adoc*)
Note this will not work when "tabbing" through drawings.
« Last Edit: August 19, 2011, 02:25:37 PM by ronjonp »
« Reply #2 on: August 19, 2011, 02:36:42 PM »
I thought something like this:
(if (null *save-reactor*)
    (setq *save-reactor* (vlr-editor-reactor nil '((:vlr-begindwgopen . savedrawing))))
(defun savedrawing ( reactor params )
    (if (= 1 (getvar 'DWGTITLED))
        (vla-save
                (   *activedoc*   )
                (   (setq *activedoc* (vla-get-activedocument (vlax-get-acad-object)))   )
Since a drawing may be opened from Windows Explorer, without using the Open command, but I can't get it to fire  :-(
ribarm
  • Marko Ribar, architect
« Reply #3 on: August 19, 2011, 04:48:30 PM »
I use, simply this :
(defun c:opsave ( / aobj adoc )
(setq aobj (vlax-get-acad-object))
(setq adoc (vla-get-activedocument aobj))
(vla-save adoc)
(vlax-release-object adoc)
(vla-open (vla-get-documents aobj) (getfiled "Open dwg file" "" "dwg" 4) :vlax-false)
(vl-cmdf "close" "")
M.R. on Youtube
BlackBox
« Reply #4 on: August 19, 2011, 05:20:59 PM »
(vla-save adoc)
 :whistle:
(vla-open (vla-get-documents aobj) nil :vlax-false)
BlackBox
« Reply #5 on: August 19, 2011, 05:30:02 PM »
Building on my last post, I'd slightly revise Marko's code:
(defun c:OPSAVE  ( / file)
  (if (setq file (getfiled "Open dwg file" "" "dwg" 4))
    ((lambda (acObj)
       (vla-save (vla-get-activedocument acObj))
       (vla-open (vla-get-documents acObj) file :vlax-false)
       (vl-cmdf "close" ""))
  (princ))
@ Marko - While it is good practice to release vla-objects, there's no need to do so with internal objects such as the acad-object, and activeDocument. Just saying.
« Last Edit: August 26, 2011, 12:57:33 PM by RenderMan »
BlackBox
« Reply #6 on: August 19, 2011, 05:33:37 PM »
FWIW - You could also explore the SDI System Variable (not sure of what version, or vertical you work with?). SDI = 1 the user is prompted for save upon OPEN command.
andrew_nao
« Reply #7 on: August 25, 2011, 02:40:54 PM »
maybe someone can help me get this code modified
i got this code form the augi forums here
http://forums.augi.com/showthread.php?t=27428
it saves your dwg after 10 commands and
I want to use my custom save lisp instead of the VLA-SAVE function
but when i try to put my lisp call in there it comes up as an invalid command
can anyone guide me on how i can get my callout working
(defun C:Vas ()
  (setq ASRXN1 (vlr-editor-reactor nil '((:vlr-commandended . ASCOM1)))
     ASRXN2 (vlr-lisp-reactor nil   '((:vlr-lispWillStart . ASCOM2)))
     ASRXN3 (vlr-lisp-reactor nil   '((:vlr-lispended . ASCOM3)))
 (defun ASCOM1 (CALL CALLBACK)
  (if (not LISPRUN)
  ((= (car CALLBACK) "SAVE")
  (setq ASCOUNT 0)
  ((= (car CALLBACK) "QSAVE")
  (setq ASCOUNT 0)
    (if (not ASCOUNT)
  (setq ASCOUNT 0)
  (if (> ASCOUNT 9)
    (setq ASCOUNT 0)
    ;(vla-save (vla-get-activedocument (vlax-get-acad-object)))
  (c:nsave)
; (print "AutoSave")
    (setq ASCOUNT (1+ ASCOUNT))
    (print ASCOUNT)
 (defun ASCOM2 (CALL CALLBACK)
  (setq LISPRUN 'T)
 (defun ASCOM3 (CALL CALLBACK)
  (setq LISPRUN nil)
« Reply #8 on: August 25, 2011, 03:24:30 PM »
What is (c:nsave)? If I remember correctly, command calls will error in a reactor.
andrew_nao
« Reply #9 on: August 25, 2011, 03:59:19 PM »
that is a custom lisp call
i modified the code to work for me, however if i use a custom macro this code countdown returns back to 1
anyone have any thoughts on why?
(defun copy_backup_as (/ activedoc docfullname backuppath archivename)
  (setq activedoc (vla-get-activedocument (vlax-get-acad-object)))
  ;;----- Main --------------------------
  (if (and (not (= 0 (strlen (setq docfullname (vla-get-fullname activedoc)))))
           (setq backuppath "C:\\ACADBACK\\")
           (setq archivename (strcat backuppath
                                     (vl-filename-base (vla-get-name activedoc))
                                     ".dwg"
    (vl-file-copy docfullname archivename)
    (alert "Ooooops. Unable to establish ArchiveName.")
  (prompt (strcat "\nFile Saved..." archivename))
(defun asave ()
  (if (not LISPRUN)
  (setq ASCOUNT 0)
  (setq ASCOUNT 0)
    (if (not ASCOUNT)
  (setq ASCOUNT 0)
  (if (> ASCOUNT 9)
    (setq ASCOUNT 0)
  (vl-file-delete (strcat "C:\\ACADBACK\\"
                    (vla-get-name
  (copy_backup_as)
  (prompt (strcat "\nFile Saved..." (vla-get-fullname (vla-get-activedocument (vlax-get-acad-object)))))
    (print ASCOUNT)
  (setq LISPRUN 'T)
  (setq LISPRUN nil)
 (asave)
rhino
« Reply #10 on: November 01, 2011, 10:31:44 PM »
I use this vba proggie:
http://www.afralisp.net/visual-basic-for-applications/tutorials/a-better-autosave.php
This works by setting a counter that starts when a command is called - it then resets on the user set interval/time. Sometimes in a hurry you forget to save the drawing you've worked on...this way you'll always lose only the last 10mins of your work  :mrgreen:
The code needed to be modified though; I'll post the .dvb file later tonight.
Perhaps someone here can also expand it to include an error check; for say when you open a read only drawing or the location of the save is write protected (thick CD).
rhino
« Reply #11 on: November 02, 2011, 03:14:27 PM »
heres the modded vba code:
Private Sub AcadDocument_BeginCommand(ByVal CommandName As String)
Dim OldTime
Dim NewTime
Select Case CommandName
'trigger when user selects
Case "LINE", "PLINE", "DDEDIT", "DIMLINEAR", "COPY", "MOVE", "ZOOM"
'get the time now
NewTime = (Hour(Time) * 60) + Minute(Time)
'get the time stored in USERI2
OldTime = ThisDrawing.GetVariable("Useri2")
'If the time has not been set
If OldTime = 0 Then
'set the time
ThisDrawing.SetVariable ("Useri2"), NewTime
'then end
End
End If
'if the difference is greater that 15 minutes
If (NewTime - OldTime) > 5 Then
'save the drawing
ThisDrawing.Save
'and then reset Useri2
End If
'end of the Select
End Select
End
End Sub
Private Sub AcadDocument_BeginSave(ByVal FileName As String)
End Sub
also attached the compiled dvb
