Author Topic: getting initals from a sting in lisp  (Read 2360 times)
marcoblanco120
« on: August 18, 2011, 03:43:28 PM »
Can anyone provide a function that will pull the first letter only from each word in a multi-word text string?
i.e. "My name is Bill" returns "MNIB"
Re: getting initals from a sting in lisp
« Reply #1 on: August 18, 2011, 03:47:33 PM »
Quick 'n dirty:
(defun _Initials ( s )
    (vl-list->string
        (apply 'append
            (mapcar
               '(lambda ( a b ) (if (and (= 32 a) (/= 32 b)) (list b)))
                (cons 32 (vl-string->list s))
                (vl-string->list (strcase s))
_$ (_Initials "My name is Bill")
"MNIB"
« Reply #2 on: August 18, 2011, 10:51:56 PM »
Obfuscated fun in case Se7en is bored ...
(defun _Initials ( text )
    ((lambda (a b c) ((lambda (d) (a (mapcar 'b (cons 32 d) d))) (c text)))
     (lambda (a) (vl-list->string (vl-remove-if 'null a)))
     (lambda (a b) (if (and (= 32 a) (/= 32 b)) b))
     (lambda (a) (vl-string->list (vl-string-trim " \n\t" (strcase a)))))
« Last Edit: August 18, 2011, 10:56:48 PM by MP »
« Reply #3 on: August 18, 2011, 11:34:35 PM »
heh. I cant read lisp anymore--? like in the old days ?--so it's all obfuscated to me now. *lol*
« Reply #4 on: August 19, 2011, 11:44:56 AM »
I thought it would be fun to construct a mini parser for generating acronyms while I was waiting for one of my coworkers. So using my other parser "studies" as a basis, I generated this (However, I only spent 15 minutes on this so beware):
enum Token
    tok_eof = -1,
    // end of file
    tok_identifier = -2
static std::string IdentifierString;
static int CurTok;
// oops; globals
static int gettok()
    static int LastChar = ' ';
    //   skip whitespace
    while (isspace(LastChar))
        LastChar = getchar();
    if (isalpha(LastChar)) {
        IdentifierString = LastChar;
        while (isalpha(LastChar))
        return tok_identifier;
    // Check for end of file.  Don't eat the EOF.
    if (LastChar == EOF)
        return tok_eof;
    // Otherwise, just return the character as its ascii value.
    int ThisChar = LastChar;
    return ThisChar;
static int getNextToken()
    return CurTok = gettok();
static void HandleIdentifier()
    std::cout << IdentifierString;
    getNextToken();
    // prime the next token
    return;
static void MainLoop()
    while (1)
        switch (CurTok)
        case tok_eof:           return;
        case tok_identifier:    HandleIdentifier(); break;
        default:                getNextToken(); break;
int main(int argc, char *argv[])
    std::cout << "\nPress \"CTRL-Z\" when finished.\n";
    MainLoop();
    return 0;
Of course this is grossly over doing it but I wanted this to represent a mini model of my LispParser trial (it not really an accurate model, but it's kind of in the same spirit).
Now, watch this. We can eliminate quite a bit of code by making two minor changes to the gettok() function.
static int gettok()
    //   skip whitespace
        IdentifierString += LastChar;   // changed
        return gettok();                // changed
        return 0;
    gettok();
    std::cout << IdentifierString << '\n';
    return 1;
Same functionality (almost).
With the first example you can generate a GIANT acronym from a file full of text like:
[COMPILEDEXENAME].exe < [FILENAME]
pBe
« Reply #5 on: August 20, 2011, 05:48:45 AM »
Another one
(Defun _Initials (str)
(apply 'strcat
      (mapcar '(lambda (j)
               (substr (vl-symbol-name j) 1 1))
               (read (eval (strcat "(" str ")")))))
« Reply #6 on: August 20, 2011, 07:41:45 AM »
Interesting approach pBe, no need for the 'eval' though  :wink:
pBe
« Reply #7 on: August 20, 2011, 09:40:44 AM »
(eval... )
I am wondering myself  :laugh:
Thanks Lee
