Ok, thanks to the help of those on this board, I have my first pass at my new version of this routine. The command will convert all xrefs to overlay or attach as applicable. I would like input on this command and what might be able to be done to make it faster or even more stable. I previously had a version of this routine that someone else started and I fixed, but it did not always work correctly and had some problems with crashing. As a result, I have completely rewritten it myself using what I have learned since working on that routine, much of which I have learned from the people on the swamp.
Edit 03/03/2013 to update the code:
; Xref to Attach/Overlay **
; Written by: Chris Wade **
; Version 2.1a **
; 12/07/2011 **
; - Adjusted code to temporarily disable all reactors to prevent interference with LISP routine. **
; Version 2.1 **
; 12/05/2011 **
; - Changes that attachment type for all XRefs. **
; - X2A - Changes all xrefs to attached method. **
; - X2O - Changes all xrefs to overlay method. **
; - Known Limitations: **
; - Viewport specific layer overrides may not be restored. **
(defun C:x2a ()
(xmethodflip "a")
(defun C:x2o ()
(xmethodflip "o")
(defun xmethodflip (mode / *ACAD_DOC* *PaperSpace* *ModelSpace* *Active* *ActiveID* allReactors cLayout BlockDef xObj2 SS2 LS Temp Clip ClipLength ClipCount ClipTemp Clip1 Clip2 xIsClipped XNameList BlockCollection xInsPt xLayer xScaleX xScaleY xScaleZ xRotation xPath Obj2 xObj xObjName xLayout xOwnerID); Mode - O = Overlay / A = Attach
(setvar "cmdecho" 0)
(setq *ACAD_DOC* (vla-get-ActiveDocument (vlax-get-acad-object))
*PaperSpace* (vla-get-paperspace *ACAD_DOC*)
*ModelSpace* (vla-get-modelspace *ACAD_DOC*)
((or (= (getvar "tilemode") 1) (/= (getvar "cvport") 1))
(setq xLayout *ModelSpace*)
((and (= (getvar "tilemode") 0) (= (getvar "cvport") 1))
(setq xLayout *PaperSpace*)
;Supporting Functions
(defun x2a_NotNested (name / SS)
(setq ss (ssget "_X" (list (cons 2 name) (cons 410 (getvar "ctab"))))
SS
(defun x2a_r2d (rad /)
(/ (* rad 180) pi)
(defun x2a_GetXclip ( ename / __XClipBoundary elist xlist _xang _xnor ); Code from Lee Mac @ http://www.theswamp.org/index.php?topic=39201.msg444239#msg444239
;; Matrix x Vector - Vladimir Nesterovsky
;; Args: m - nxn matrix, v - vector in R^n
(defun mxv ( m v )
(mapcar '(lambda ( r ) (apply '+ (mapcar '* r v))) m)
;; Matrix x Matrix - Vladimir Nesterovsky
;; Args: m,n - nxn matrices
(defun mxm ( m n )
((lambda ( a ) (mapcar '(lambda ( r ) (mxv a r)) m)) (trp n))
;; Matrix Transpose - Doug Wilson
(defun trp ( m ) (apply 'mapcar (cons 'list m)))
(defun __XClipBoundary ( ename / xdict )
(setq xdict (cdr (assoc 360 (entget ename))))
(__XClipBoundary xdict)
(and
(eq "SPATIAL_FILTER" (cdr (assoc 0 (setq ename (entget ename)))))
(eq 1 (cdr (assoc 71 ename)))
(lambda ( massoc ) (massoc 10 ename))
(lambda ( key elist / item )
(if (setq item (assoc key elist))
(cons (cdr item) (massoc key (cdr (member item elist))))
(defun __dxf ( key lst ) (cdr (assoc key lst)))
(setq elist (entget ename)
_xang (__dxf 50 elist)
_xnor (__dxf 210 elist)
(if (setq xlist (__XClipBoundary ename))
(lambda ( matrix )
(lambda ( vector )
(mapcar
(function
(lambda ( point )
(mapcar '+ (mxv matrix point) vector)
xlist
(mapcar '- (trans (__dxf 10 elist) _xnor 0)
(mxv matrix
(__dxf 10 (tblsearch "BLOCK" (__dxf 2 elist)))
(mxm
(mapcar
(function
(lambda ( v ) (trans v 0 _xnor t))
(1.0 0.0 0.0)
(0.0 1.0 0.0)
(0.0 0.0 1.0)
(mxm
(list
(list (cos _xang) (sin (- _xang)) 0.0)
(list (sin _xang) (cos _xang) 0.0)
(list 0.0 0.0 1.0)
(list
(list (__dxf 41 elist) 0.0 0.0)
(list 0.0 (__dxf 42 elist) 0.0)
(list 0.0 0.0 (__dxf 43 elist))
;; by CAB 10/05/2007
;; Expects pts to be a list of 2D or 3D points
;; Returns new pline object
(defun x2a_makePline (spc pts)
;; flatten the point list to 2d
(if (= (length (car pts)) 2) ; 2d point list
(setq pts (apply 'append pts))
(setq pts (apply 'append (mapcar '(lambda (x) (list (car x) (cadr x))) pts)))
(setq
pts (vlax-make-variant
(vlax-safearray-fill
(vlax-make-safearray vlax-vbdouble (cons 0 (1- (length pts))))
pts
(vla-addlightweightpolyline spc pts)
;Code to determine if layerstate is present provided by AlanJT
(defun x2a_isLayerStatePresent (doc layerstate / state)
(if (not
(vl-catch-all-error-p
(vl-catch-all-apply
'(lambda (/)
(setq state (vla-item (vla-item (vla-GetExtensionDictionary (vla-get-layers doc))
"ACAD_LAYERSTATES"
layerstate
state
;End of Supporting Functions
(vla-StartUndoMark *ACAD_DOC*)
(setq allReactors (apply 'append (mapcar 'cdr (vlr-reactors))))
(if allReactors (mapcar 'vlr-remove allReactors)) ; temporarily disable all reactors - Code by roy_043 @ http://www.theswamp.org/index.php?topic=34597.msg408535#msg408535
(setq cLayout (vla-get-activelayout *ACAD_DOC*))
(vlax-for L (vla-get-layouts *ACAD_DOC*)
(vla-put-activelayout *ACAD_DOC* L)
(setq SS (ssget "_X" (list '(0 . "INSERT") (cons 410 (getvar "ctab")))))
(SS
(setq LS 1
BlockCollection (vla-get-blocks *ACAD_DOC*)
(while (x2a_isLayerStatePresent *ACAD_DOC* (strcat "X2A-" (rtos LS 2 0)))
(setq LS (+ LS 1))
(vl-cmdf "._-layer" "_a" "_save" (strcat "X2A-" (rtos LS 2 0)) "" "" "")
((lambda (i / Ent)
(while (setq Ent (ssname SS (setq i (1+ i))))
(setq xObj2 (vlax-ename->vla-object Ent))
(xObj2
(setq BlockDef (vla-item BlockCollection (vla-get-name xObj2)))
((= (vla-get-isxref BlockDef) :vlax-true)
(setq xRname (vla-get-name xObj2)
xPath (vla-get-path BlockDef)
SS2 (x2a_NotNested xRname)
((Lambda (I2 / Ent2)
(While (Setq Ent2 (Ssname Ss2 (Setq I2 (1+ I2))))
(Setq Xobj (Vlax-ename->vla-object Ent2)
Xinspt (Cons (Vlax-safearray->list (Variant-value (Vla-get-insertionpoint Xobj))) Xinspt)
Xownerid (Cons (Vla-get-ownerid Xobj) Xownerid)
Xscalex (Cons (Vla-get-xscalefactor Xobj) Xscalex)
Xscaley (Cons (Vla-get-yscalefactor Xobj) Xscaley)
Xscalez (Cons (Vla-get-zscalefactor Xobj) Xscalez)
Xrotation (Cons (Vla-get-rotation Xobj) Xrotation)
Xlayer (Cons (Vla-get-layer Xobj) Xlayer)
Xisclipped (Cons (X2a_getxclip (Vlax-vla-object->ename Xobj)) Xisclipped)
-1)
(vla-detach BlockDef)
((Lambda (Ct2 / Ent2)
(While (Setq Ent2 (Ssname Ss2 (Setq Ct2 (1+ Ct2))))
((or (< (nth Ct2 xScaleX) 0) (< (nth Ct2 xScaleY) 0) (< (nth Ct2 xScaleZ) 0)); This is put here for xRefs that have been mirrored.
(vl-cmdf "._-xref" (strcat "_" mode) xPath (nth Ct2 xInsPt)(nth Ct2 xScaleX) (nth Ct2 xScaleY) (x2a_r2d (nth Ct2 xRotation)))
(setq Obj2 (vlax-ename->vla-object (entlast)))
(T
((= (strcase mode) "O")
(setq Obj2 (vla-attachexternalreference xLayout xPath (vl-filename-base xPath) (vlax-3D-point (nth Ct2 xInsPt)) (nth Ct2 xScaleX) (nth Ct2 xScaleY) (nth Ct2 xScaleZ) (nth Ct2 xRotation) :vlax-true))
((= (strcase mode) "A")
(setq Obj2 (vla-attachexternalreference xLayout xPath (vl-filename-base xPath) (vlax-3D-point (nth Ct2 xInsPt)) (nth Ct2 xScaleX) (nth Ct2 xScaleY) (nth Ct2 xScaleZ) (nth Ct2 xRotation) :vlax-false))
(vla-put-layer Obj2 (nth Ct2 xLayer))
((nth Ct2 xIsClipped)
(setq Clip (nth Ct2 xIsClipped)
ClipLength (length Clip)
ClipCount 0
((= ClipLength 2)
(setq Clip1 (nth 0 Clip)
Clip2 (nth 1 Clip)
Clip (list Clip1 (list (car Clip2) (cadr Clip1) (caddr Clip1)) Clip2 (list (car Clip1) (cadr Clip2) (caddr Clip2)))
(setq Clip (x2a_MakePline xLayout Clip))
((/= (vla-get-closed Clip) T)
(vla-put-closed Clip T)
(vl-cmdf "._xclip" (vlax-vla-object->ename Obj2) "" "_N" "_S" (entlast))
(vla-delete Clip)
-1)
-1)
(command "._-layer" "a" "restore" (strcat "X2A-" (rtos LS 2 0)) "" "")
(command "._-layer" "a" "delete" (strcat "X2A-" (rtos LS 2 0)) "" "")
(vla-put-activelayout *ACAD_DOC* cLayout)
(if allReactors (mapcar 'vlr-add allReactors)); Restores Reactors
(vla-EndUndoMark *ACAD_DOC*)
