Author Topic: DBMOD = 5 when I start AutoCAD  (Read 18109 times)
Matt__W
  • I like my water diluted.
« on: August 10, 2011, 11:49:19 AM »
In my custom ACAD.lsp file I have (acad-push-dbmod) at the beginning and (acad-pop-dbmod) at the end, yet every time I check DBMOD after opening AutoCAD, it has a value of 5.
Thoughts?  Suggestions??
Autodesk Expert Elite
alanjt
  • Standby for witty remark...
Re: DBMOD = 5 when I start AutoCAD
« Reply #1 on: August 10, 2011, 12:11:13 PM »
Are you making edits to the drawing upon startup? Mine always says 5, but I also have it insert all styles (dim, mleader) and create/reset textstyles.
Dropbox
Krushert
  • FREE BEER Tomorrow!!
« Reply #2 on: August 10, 2011, 12:12:22 PM »
Well you could just save the drawing file and that will reset it back to zero.  :-P :evil:
alanjt
« Reply #3 on: August 10, 2011, 12:14:07 PM »
Sucky prompt to receive when starting a new drawing (granted, you could it to only save if not a "Drawing#.dwg" file).
Dropbox
Krushert
« Reply #4 on: August 10, 2011, 12:32:30 PM »
**We really need to get a sarcasm smilely.**  :-)
alanjt
« Reply #5 on: August 10, 2011, 12:35:36 PM »
Dropbox
Krushert
« Reply #6 on: August 10, 2011, 12:47:13 PM »
 :-D :-D :-D
dgorsman
« Reply #7 on: August 10, 2011, 01:13:00 PM »
Possibly from using ACAD.lsp rather than ACADDOC.lsp?  Or there may be drawing changes made in an appended S::STARTUP function which runs after the push/pop dbmod setting?  Or drawing changes made by an MNL depending on the load order of the MNL vs. the ACAD.lsp.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
Matt__W
« Reply #8 on: August 10, 2011, 01:26:40 PM »
OOOHHH, BURN!!!
Matt__W
« Reply #9 on: August 10, 2011, 01:27:20 PM »
Oooh, MNL.  Forgot about that one.  I'll go check.
BlackBox
« Reply #10 on: August 10, 2011, 01:40:28 PM »
Edit: Scratch... just saw dgorsman's quoted post from previous page.
I also use ACAD.lsp to set profile paths, etc., however DBMOD = 0 at start with Drawing1.
Consider the load order at startup:
linky
A. CUI files loaded:
1. Enterprise
2. Main
3. Partials to Main
4. Partials to Enterprise
B. acad*.* files loaded:
1. Files listed in acad.rx
2. acad2009.lsp
3. acad.lsp  <--
4. acad2009doc.lsp
5. acaddoc.lsp
6. acad.dvb
C. CUI-associated MNL and LSP files loaded:
1. Enterprise named MNL
2. Enterprise loaded LSP and MNL
3. Main named MNL
4. Main loaded LSP and MNL
5. Partials to Main named MNLs
6. Partials to Main loaded LSPs and MNLs
7. Partials to Enterprise named MNLs
8. Partials to Enterprise loaded LSPs and MNLs
D. Startup suite files loaded
E. Startup routines run:
1. AcadStartup() called (AutoCAD startup)
2. AcadDocument_Activate() called (Drawing startup)
3. (S::STARTUP) called
4. SCR loaded from /b switch
Edit: ^^ Corrected
... Is it possible that you have something loading/executing via ACADDOC.lsp, CUI(s), or (S::STARTUP)?
« Last Edit: August 10, 2011, 02:02:14 PM by RenderMan »
Matt__W
« Reply #11 on: August 10, 2011, 01:49:24 PM »
I'm running/loading a few things in S::Startup but that's between the PUSH/POP.  Hehehehe... pushpop!  I didn't think that would make a difference.  Maybe it does??
alanjt
« Reply #12 on: August 10, 2011, 01:51:33 PM »
What's the benefit of running the push/pop (heh heh) on startup?
Dropbox
Matt__W
« Reply #13 on: August 10, 2011, 01:52:36 PM »
Don't try to steal my joke.   :pissed:
I'm forcing some changes to some sysvars to keep everything running smoothly.
alanjt
« Reply #14 on: August 10, 2011, 01:54:50 PM »
No thievery.
Wait, so what does the push/pop do?
Dropbox
