Author Topic: Trignometry  (Read 33574 times)
SEANT
Re: Trignometry
« Reply #30 on: August 11, 2011, 04:00:03 AM »
I see it now.
Sean Tessier
AutoCAD 2016 Mechanical
SEANT
Re: Trignometry
« Reply #31 on: August 11, 2011, 05:50:13 AM »
How about:
o = (COS(ASIN((170*SIN(A)))/180))*180) – (COS(A)*180)
Sean Tessier
SEANT
Re: Trignometry
« Reply #32 on: August 11, 2011, 06:26:05 AM »
This may be more succinct:
« Last Edit: August 11, 2011, 07:09:59 AM by SEANT »
Sean Tessier
Krushert
  • FREE BEER Tomorrow!!
Re: Trignometry
« Reply #33 on: August 11, 2011, 08:05:23 AM »
Thanks all, I guess I really deserved this.
As mentioned before, we were picking on each other in good fun or at the very least I was.  None of this was directed at you, we just use your O.P. to get us going which as you can see does not take much.  And yes we get distracted with Squirrels and other things with bushy tails also.   So do not take it heart.
From your problem I can see it is above my pay grade so I will leave it to the more knowledgeable ones.
Cheers.
Whoops forgot to read page three of this thread.  Ahh excel to rescue.
« Last Edit: August 11, 2011, 09:18:08 AM by Krushert »
Stefan
Re: Trignometry
« Reply #34 on: August 11, 2011, 08:52:36 AM »
Just the trig stuff..
[Edit] ... missed some text formatting ...
« Last Edit: August 11, 2011, 08:58:35 AM by Stefan »
Re: Trignometry
« Reply #35 on: August 11, 2011, 09:25:40 AM »
The above post proves my point; that a well formed question will yield a well formulated answer.
Although, I wonder why any use of 'trig' would be needed to 'solve' the unknown angles; given that it was drawn correctly in cad to start with?
caddman6425
Re: Trignometry
« Reply #36 on: August 11, 2011, 11:05:17 AM »
Writting a routine that draws all Steal Beams as structural members.  Can put into any configuration and in one configuration  need to know the plum cut programaticaly for ofset bearing points.  Yes I knew that it can be solved using lisp or a calculator but I had to prove it to understand it.
caddman6425
Re: Trignometry
« Reply #37 on: August 11, 2011, 06:14:24 PM »
I want to thank everyone that contributed to this question.  I did figre the solution this morning at about 2:00 A. M. but all of yours was helpfull.
