I make a lisp for break object, but make error with osnap ( turn off NEAREST regime osnap(defun c:BRR(/ cobj ent ov pt1 pt2 tmp vl str); brk -> Break Curve
(command "undo" "be")
(setq vl '("osmode" "orthomode" "cmdecho") ; Sys Var list
ov (mapcar 'getvar vl)) ; Get Old values
(mapcar 'setvar vl '(545 0 0))
(if (and (setq Ent (car (entsel "\nChon doi tuong can chia :")))
(wcmatch (cdr (assoc 0 (entget ent))) "*LINE,ARC")
(not (redraw ent 3))
(setq pt1 (getpoint "\nDiem dau :"))
(setq pt2 (getpoint "\nDiem cuoi :")) )
(setq cObj (vlax-ename->vla-object Ent)
pt1 (vlax-curve-getClosestPointto cObj (trans pt1 1 0))
pt2 (vlax-curve-getClosestPointto cObj (trans pt2 1 0)))
(if (> (vlax-curve-getParamAtPoint cObj pt1)
(vlax-curve-getParamAtPoint cObj pt2))
(setq tmp pt1 pt1 pt2 pt2 tmp) )
(command "._break" ent "_non" (trans pt2 0 1) "_non" (trans pt2 0 1))
(if (equal pt1 (vlax-curve-getStartPoint cObj) 0.001)
(command "change" ent "" "p" "LA" (lcurr) "")
(command "._break" ent "_non" (trans pt1 0 1) "_non" (trans pt1 0 1))
(command "change" (entlast) "" "p" "LA" (lcurr) "")
(redraw ent 4)
(mapcar 'setvar vl ov) ; reset Sys Vars
(command "undo" "e")
(alert "Khong hop le !"))
(princ))
(defun lcurr(/ e)
(setq str (getstring t "\n Nhap ten layer hoac Enter de pick vao doi tuong :"))
(if (= str "")
(while (null (setq e (entsel "\n pick vao doi tuong :"))))
(setvar "clayer" (cdr(assoc 8 (entget(car e)))))
(while (null (tblsearch "layer" str))
(setq str (getstring t "\n Nhap lai ten layer :"))
(setvar "clayer" str)
). Can you help me fix this error. Thank you very much
