Author Topic: -={ Challenge }=- Give Change  (Read 11766 times)
David Bethel
Re: -={ Challenge }=- Give Change
« Reply #30 on: August 13, 2011, 11:19:53 AM »
Maybe for us simple minded folks :)
(defun givechange (a dl / d q c)
(defun remove (expr lst);;;TonyT or VNesterowski
  (apply 'append (subst nil (list expr) (mapcar 'list lst))))
  (while (and (> a 0)
              (> (length dl) 0))
         (setq d (apply 'max dl)
               q (fix (/ a d))
               a (- a (* d q))
               dl (remove d dl))
          (if (> q 0)
              (setq c (cons (cons d q) c))))
  (reverse c))
R12 Dos - A2K
« Reply #31 on: August 13, 2011, 11:23:55 AM »
A simple approach David, but the greedy algorithm will have trouble with examples such as (givechange 40 '(25 20 10 5 1))  :wink:
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #32 on: August 13, 2011, 11:43:23 AM »
Another optimisation:
my answer:
(defun change_v5 (n l / i)
  (cond ((or (not l) (< n 0)) '(32767 nil))
        ((< n (car l)) (change_v5 n (cdr l)))
        ((zerop (rem n (car l))) (list (setq i (/ n (car l))) (cons (car l) i)))
        ((f1 (f2 n (cdr l)) (change_v5 (- n (car l)) l) (car l)))
(defun f1 (a b c)
  (cond ((not a) (f3 n l))
        ((< (car a) (1+ (car b))) a)
        ((= (caadr b) c) (cons (1+ (car b)) (cons (cons c (1+ (cdadr b))) (cddr b))))
        ((cons (1+ (car b)) (cons (cons c 1) (cdr b))))
(defun f2 (n l / i)
  (setq i 0
        l (mapcar '(lambda (a / b c)
                     (setq b n
                           n (rem n a)
                           c (/ b a)
                           i (+ i c)
                     (cons a c)
                  (vl-sort l '>)
  (if (= n 0)
    (cons i l)
(defun f3 (n l / i)
        ((f1 (f3 n (cdr l)) (change_v5 (- n (car l)) l) (car l)))
« Reply #33 on: August 13, 2011, 11:51:15 AM »
Give me a minute, I think my head just exploded  :lol:
David Bethel
« Reply #34 on: August 14, 2011, 07:46:30 AM »
We Yanks don't have a 20p.  Maybe the Founding Fathers were mathematicians as well and we didn't know it!  -David
R12 Dos - A2K
« Reply #35 on: August 14, 2011, 07:52:19 AM »
We Brits don't have 25p, I was just looking to the general case for an arbitrary set of denominations for which dynamic programming must be used   :wink:
Coincidentally, the greedy algorithm will produce the optimal result for the US currency system.  :-)
Jürg Menzi
  • Oberegg, Switzerland
« Reply #36 on: July 02, 2012, 06:51:39 AM »
A little bit offtopic...
Hi Lee
Great solution, thanks!
Had this problem:
http://www.theswamp.org/index.php?topic=42146.0
So I used your solution a little bit modified:
  1. ...
  2.  (while (and (setq e (nth c b)) (< c n))
  3.   (setq h (assoc++ e h) c (+ c e))
  4.  )
  5.  (cons (- n c) h)
  6. )
The problem was, that my application requires the ability to get a remainder.
Thanks again and have a good day :-)
Cheers
A computer's human touch is its unscrupulousness!
MENZI ENGINEERING GmbH
Current A2k16... A2k24 - Start R2.18
« Reply #37 on: July 02, 2012, 07:53:49 AM »
Thank you Jürg! I'm pleased that my solution was useful in applications other than this challenge  :-)
