Author Topic: MLeader attaching to the wrong side of MText  (Read 2133 times)
zoltan
« on: August 04, 2011, 06:46:25 PM »
I am trying to create a MLeader that attaches to the right side of the MText when the leader is going to the left.  For some reason, it is attaching to the wrong side.
[CommandMethod("TestMLeader", "TestMLeader", "TestMLeader", CommandFlags.Modal)]
        public void TestMLeader()
            Document acadDocument = Application.DocumentManager.MdiActiveDocument;
            using (Transaction trans = acadDocument.TransactionManager.StartTransaction())
                BlockTable acadBlockTable = (BlockTable)trans.GetObject(acadDocument.Database.BlockTableId, OpenMode.ForRead);
                BlockTableRecord modelSpace = (BlockTableRecord)trans.GetObject(acadBlockTable[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
                //Leader to the right.
                MLeader leader1 = new MLeader();
                leader1.AddLeader();
                leader1.AddLeaderLine(0);
                leader1.AddFirstVertex(0, new Point3d(0.0, 0.0, 0.0));
                leader1.AddLastVertex(0, new Point3d(2.0, -2.0, 0.0));
                leader1.SetDatabaseDefaults();
                leader1.TextAttachmentDirection = TextAttachmentDirection.AttachmentHorizontal;
                leader1.TextAngleType = TextAngleType.HorizontalAngle;
                leader1.TextAlignmentType = TextAlignmentType.LeftAlignment;
                leader1.TextAttachmentType = TextAttachmentType.AttachmentMiddleOfTop;
                MText mText1 = new MText();
                mText1.SetDatabaseDefaults();
                mText1.Contents = "Text\\PText\\PText";
                leader1.MText = mText1;
                modelSpace.AppendEntity(leader1);
                trans.AddNewlyCreatedDBObject(leader1, true);
                //Leader to the left.
                MLeader leader2 = new MLeader();
                leader2.AddLeader();
                leader2.AddLeaderLine(0);
                leader2.AddFirstVertex(0, new Point3d(0.0, 0.0, 0.0));
                leader2.AddLastVertex(0, new Point3d(-2.0, -2.0, 0.0));
                leader2.SetDatabaseDefaults();
                leader2.TextAttachmentDirection = TextAttachmentDirection.AttachmentHorizontal;
                leader2.TextAngleType = TextAngleType.HorizontalAngle;
                leader2.TextAlignmentType = TextAlignmentType.RightAlignment;
                leader2.TextAttachmentType = TextAttachmentType.AttachmentMiddleOfBottom;
                MText mText2 = new MText();
                mText2.SetDatabaseDefaults();
                mText2.Contents = "Text\\PText\\PText";
                leader2.MText = mText1;
                modelSpace.AppendEntity(leader2);
                trans.AddNewlyCreatedDBObject(leader2, true);
                trans.Commit();
Jeff H
Re: MLeader attaching to the wrong side of MText
« Reply #1 on: August 04, 2011, 07:18:46 PM »
MLeader.SetDogleg
This is your original code  just hard-coded for an example.
Modified 2 lines in code that end with---//////////GET INDEX
Added 2 lines that end with----/////////USE SETDOGLOG
                int leader1index = leader1.AddLeader();//////////GET INDEX
                leader1.SetDogleg(leader1index, Vector3d.XAxis);/////////USE SETDOGLOG
                int leader2index = leader2.AddLeader();//////////GET INDEX
                leader2.SetDogleg(leader2index, Vector3d.XAxis.MultiplyBy(-1));/////////USE SETDOGLOG
                trans.Commit();
zoltan
« Reply #2 on: August 04, 2011, 10:43:46 PM »
I think that did it!
Thanks.
