Author Topic: LDD tip/trick  (Read 3516 times)
DanB
LDD tip/trick
« on: February 03, 2005, 07:58:18 AM »
Maybe this is already well known but I just discovered this. You can "recall" your last LDD command you ran by just typing "LDD" at the command line. I was spot labeling surface points through LDD then moving text out of the way, I could go right back to my terrain label spot by just typing "LDD"
Dan
