Author Topic: load acaddoc and acad lsp faster?  (Read 19406 times)
0 Members and 4 Guests are viewing this topic.
alanjt
  • Standby for witty remark...
Re: load acaddoc and acad lsp faster?
« Reply #30 on: July 14, 2011, 08:39:20 AM »
Hi butzers09silverado,
Include the following in your ACADDOC.lsp:
  (lambda ( / err )
    (foreach x
        (acadlspasdoc 1)
        (blipmode 0)
        (cecolor "bylayer")
        (celtype "bylayer")
        (cmddia 1)
        (startup 1)
        (isavepercent 0)
        (tooltips 0)
        (xrefnotify 2)
        (xloadctl 2)
        (visretain 1)
        (regenmode 1)
        (attmode 1)
        (attreq 1)
        (backgroundplot 0)
        (cmljust 1)
        (demandload 3)
        (draworderctl 3)
        (elevation 0)
        (fielddisplay 1)
        (fieldeval 31)
        (gridmode 0)
        (ucsvp 0)
        (xreftype 1)
        (geomarkervisibility 0)
        (tooltips 1)
        (indexctl 3)
        (expert 5)
        (rollovertips 0)
        (publishcollate 0)
        (ssmautoopen 0)
        (osnapz 1)
        (mirrtext 0)
        (proxygraphics 0)
        (insunitsdefsource 2)
        (insunitsdeftarget 2)
        (maxsort 10000)
        (isavebak 1)
        (isavepercent 1)
        (offsetgaptype 0)
        (savefidelity 0)
        (plinegen 0)
        (plinewid 0)
        (polysides 3)
        (ucsfollow 0)
        (rasterthreshold 100)
        (rasterpercent 90)
        (elevation 0)
        (imageframe 2)
        (navvcubedisplay 0)
        (navbardisplay 0)
        (lwdisplay 0)
        (gridmode 0)
        (lwunits 0)
        (orthomode 0)
        (layoutregenctl 0)
        (hpglmode 1)
        (layerdlgmode 0)
      (if (vl-catch-all-error-p (setq err (vl-catch-all-apply 'setvar x)))
        (princ (strcat "\n--> Error: " (vl-catch-all-error-message err)))
Minus printing the error message, this is the exact method I've been successfully using for quite some time.
Dropbox
butzers09silverado
« Reply #31 on: July 14, 2011, 03:19:32 PM »
  (lambda ( / err )
    (foreach x
        (acadlspasdoc 1)
        (blipmode 0)
        (cecolor "bylayer")
        (celtype "bylayer")
        (cmddia 1)
        (startup 1)
        (isavepercent 0)
        (tooltips 0)
        (xrefnotify 2)
        (xloadctl 2)
        (visretain 1)
        (regenmode 1)
        (attmode 1)
        (attreq 1)
        (backgroundplot 0)
        (cmljust 1)
        (demandload 3)
        (draworderctl 3)
        (elevation 0)
        (fielddisplay 1)
        (fieldeval 31)
        (gridmode 0)
        (ucsvp 0)
        (xreftype 1)
        (tooltips 1)
        (indexctl 3)
        (expert 5)
        (rollovertips 0)
        (publishcollate 0)
        (ssmautoopen 0)
        (osnapz 1)
        (mirrtext 0)
        (proxygraphics 0)
        (maxsort 10000)
        (isavebak 1)
        (isavepercent 1)
        (offsetgaptype 0)
        (savefidelity 0)
        (plinegen 0)
        (plinewid 0)
        (polysides 3)
        (ucsfollow 0)
        (rasterpercent 90)
        (elevation 0)
        (imageframe 2)
        (navvcubedisplay 0)
        (navbardisplay 0)
        (lwdisplay 0)
        (gridmode 0)
        (lwunits 0)
        (orthomode 0)
        (layoutregenctl 0)
        (hpglmode 1)
        (layerdlgmode 0)
well that simplifies things... geeze, lol thank you
is that your routine or did you combine mine, i'll double check but it looks like you took my 2 files and made 1, or we have very similar setvars  :mrgreen:
edit:  after executing step 1, which was to put as many setvars as possible in acad.lsp, huge improvement.  Step 2, implement alanjt, even faster.  cut down startup noticeably.  THANK YOU.
« Last Edit: July 14, 2011, 03:27:49 PM by butzers09silverado »
« Reply #32 on: July 14, 2011, 03:26:22 PM »
I rewrote your code.
butzers09silverado
« Reply #33 on: July 14, 2011, 03:30:23 PM »
In which repsonse... alanjt re-wrote it an posted it... did you post something different than alan?
Krushert
  • FREE BEER Tomorrow!!
« Reply #34 on: July 14, 2011, 03:38:59 PM »
Thanks guys.  I learn alot of on this one, especially when I ran  Lee's "rewrote" code under the animation feature while watching the variables.
Thanks.
butzers09silverado
« Reply #35 on: July 14, 2011, 03:41:23 PM »
Thanks.
is there anyway to get that not animated, i can't see the animation... rats  ;-)  must be our sonicwall dough
BlackBox
« Reply #36 on: July 14, 2011, 03:49:41 PM »
Read this, specifically the section on "Animating the Code."  :wink:
BlackBox
« Reply #37 on: July 14, 2011, 03:50:37 PM »
I learn alot of on this one...
1+
Cheers, guys! :beer:
butzers09silverado
« Reply #38 on: July 14, 2011, 03:54:52 PM »
that's pretty awesome  :kewl:
« Reply #39 on: July 14, 2011, 05:31:12 PM »
No, Alan quoted my post  :wink:
Thanks guys :-)
Birdy
« Reply #40 on: July 16, 2011, 09:40:54 AM »
1+
x2  This has been a good read.
My question:
I'd like to alphabetize and comment the list.  Can I have a space like this between the A and B variables, and comment what they do:
  (lambda ( / err )
    (foreach x
        (acadlspasdoc 1)       ;|Loads acad.lsp into every drawing opened|;
        (attmode 1)            ;|Controls display of attributes |;
        (attreq 1)             ;|Controls whether INSERT uses default attribute settings |;
        (blipmode 0)           ;| Turns off the #!!@**!!#@ marker blips |;
        (backgroundplot 0)     ;| Controls whether background plotting is turned on or off |;
Sorry for the remedial questions....
« Reply #41 on: July 16, 2011, 09:45:04 AM »
LISP doesn't evaluate whitespace, so you can have space between any expression.
Birdy
« Reply #42 on: July 16, 2011, 09:56:52 AM »
Thanks.  Is this proper commenting within the lambda function?
« Reply #43 on: July 16, 2011, 10:03:41 AM »
IMO, I rarely use multi-line comments (I think they look ugly), and only really use them when I specifically need to comment something within an expression on the same line, e.g.:
(setvar ;| Sets a System Variable |; 'OSMODE 0)
But this is a rare occurrence.
Usually I would opt for single [;] or double semi-colons [;;], and some use triple semi-colons [;;;] for headers.
Birdy
« Reply #44 on: July 16, 2011, 10:10:24 AM »
Thanks Lee!
You have been most helpful!
