Author Topic: An AutoLISP/AutoCAD oddity... (also: multiple join layers LISP routine)  (Read 7273 times)
alanjt
  • Standby for witty remark...
So, I've been using this routine for quite some time - been through several rewrites (original only let you select one layer). After my last rewrite to allow for multiple select to process several layers, I noticed a strange error. I never investigated it and would just limit my selections. today, I decided to figure out why I was receiving an invalid ssget list error. I finally found that I was somehow selecting an entity that nil'ed when dumping it's entity data with entget. I decided to change the 'check' to see if the object actually returns an error before checking it against a list of already processed layers.
Thought the find was really weird and thought I'd share.
Here's the problem version:
(defun c:MJL (/ ss)
  ;; Join all on selected object(s)' layer
  ;; Alan J. Thompson, 09.09.10
  (if (setq ss (ssget "_:L"))
    ((lambda (i ctab / e la lst all)
       (while (setq e (ssname ss (setq i (1+ i))))
         (or (vl-position (cdr (setq la (assoc 8 (entget e)))) lst)
             (and (setq lst (cons la lst))
                  (setq all (ssget "_X" (list '(0 . "ARC,LINE,LWPOLYLINE") ctab la)))
                  (if (eq (getvar 'peditaccept) 1)
                    (vl-cmdf "_.pedit" "_m" all "" "_J" "" "")
                    (vl-cmdf "_.pedit" "_m" all "" "_Y" "_J" "" "")
      -1
      (cons 410 (getvar 'ctab))
and here's the rewrite I did today:
(defun c:MJL (/ pedit 4ten ss i l lst all)
  ;; Alan J. Thompson, 06.28.11
  (if (setq pedit (eq (getvar 'PEDITACCEPT) 1)
            4ten  (if (eq (getvar 'CVPORT) 1)
                    (cons 410 (getvar 'CTAB))
                    (cons 410 "Model")
            ss    (ssget "_:L")
    (repeat (setq i (sslength ss))
      (if (and (setq l (assoc 8 (entget (ssname ss (setq i (1- i))))))
               (not (vl-position l lst))
                                      4ten
                                      (car (setq lst (cons l lst)))
        (if pedit
« Last Edit: June 28, 2011, 05:00:48 PM by alanjt »
Dropbox
alanjt
Re: An AutoLISP/AutoCAD oddity...
« Reply #1 on: June 28, 2011, 04:58:06 PM »
And no, changing from while to repeat was not what fixed the error. It was one of my attempts, but the fix was checking to see if the object could be dumped with entget. From there, I just left it using repeat because I didn't feel like typing everything again.
Dropbox
I understand this is just a discussion but I'm not sure if I can still discuss much "speaking AutoLisp" but I'll give it a shot.
The following is cut from a routine which I needed to do some checking like what you describe (or what I --think-- I see from your first code example.
So my question is: couldnt you adopt a similar process and just remove all items which have similar layers? -i.e. build list(s), process list, filter list, do change.
Get the items
Get their layers
remove dup items (from above)
;;  Pseudo Code:
;;  o Select an ent(s)
;;  o Get layers from those ents
;;  ~ Clean up list of layers by removing dups
(defun Select-Ent-lst ( )
   ;; Itterate thru a Selection Set and return a list of items
   ;; used to allow end user to select some items they wish to keep
   (lambda (ss / lst cntr)
     (if (null cntr)
       (setq cntr 0) )
     (if (null lst)
       (setq lst '()) )
      (if (eq (type ss) 'PICKSET)
        (repeat (sslength ss)
           (setq lst (append lst (list (entget (ssname ss cntr)))))
           (setq cntr (1+ cntr)))
        '*ERROR* )
     lst
    (ssget)) )
(defun build-Layer-lst ( ent-lst )
  (mapcar
   ;; Build a list of layers
   '(lambda (x) (cdr (assoc 8 x))) ent-lst) )
(defun clean-lst ( my-lst / lst )
 ;; Clean up a list of items; remove duplicates
     (foreach x my-lst
       (if (not (member x lst))
         (setq lst (cons x lst))))
     (reverse lst) )
bullet
bullet
tilde?
yeah, the tilde meant something or another at one time but i switched to a different format of pseudo code years ago and i dont have that old "pesudo code key plan" any longer.  and to be honest, i dont even use this format since i lost everything a while back much either but "now" my pseudo code looks more like C. *lol*
Symbol Key:
*    =     Subject.
-    =     Task / Procedure
[    =     Begin loop
]    =     End loop
{    =     Begin block of code
}    =     End block of code
* PSEUDOCODE:
<snip>
          find layer
              locate layer in drawing
              { switch
                    case: if layer !exist
                                  find layer file
                                          parse layer file
                                          create layer
<snip>
yep, that explains it
That anaphore scares me. What do you mean by `it'?
Ref:
'"...and even Stigand, the patriotic archbishop of Canterbury, found it advisable--"'
'Found what?' said the Duck.
'Found it,' the Mouse replied rather crossly: 'of course you know what "it" means.'
'I know what "it" means well enough, when I find a thing,' said the Duck: 'it's generally a frog, or a worm. The question is, what did the archbishop find?'
[Lewis Carroll, Alice's Adventures in Wonderland, Chapter III]
:D
when my dad eats he sounds like a pig
 :lmao: That was hilarious  :lol: Was that Will Ferrell on the front row?
*blink* ...tough crowd i guess (another one of my jokes missed its mark).
Still laughing over here.....  :lmao:
Question Alan, just starting to look at the code.
In my ACAD2006 (getvar 'CTAB) returns "Model" only when in the model space tab & not in paper space, active vp or not.
Is that not true for newer versions?
alanjt
It would be that way for all versions. If you notice, I only call for (getvar 'CTAB) when (getvar 'CVPORT is equal to 1, anything else I use (410 . "Model")....or am I missing something?
Dropbox
All I use is :
needs
                                more
        tabs
