Author Topic: unable to pick endpoints  (Read 6662 times)
t-bear
« Reply #15 on: February 03, 2005, 10:56:16 AM »
Is it quicker/easier than the library?  Can you pick start/end if the dist is unknown? How about along a path (great for tubing)?
CADaver
« Reply #16 on: February 03, 2005, 12:01:26 PM »
Quote from: t-bear
I think so.
Quote from: t-bear
Sure, uses (getdist)
Quote from: t-bear
Well it's a steel program so no it won't extrude along a path.
I've found that blocks are considerably lighter memory-wise than 3dsolids or regions, and less susceptible to errant corners than surfaces. We also have tools in place for changing the length of the shapes, or switching them out for a different shape.
t-bear
« Reply #17 on: February 03, 2005, 12:48:48 PM »
The only thing I use surfaces for is eccentric reducers ... I still can't get those reducers to open!! Arrrrggggggghhhhhh!!!!
Oh well, I've lived without them for all this time.....
AfricaAD
« Reply #18 on: February 03, 2005, 07:12:12 PM »
I have another one I sometimes use as well. It only creates the shapes & more simple to use, but has some errors. What I would like to do is convert the shapes into blocks after it is drawn using the entmake program. Unfortunately, I am no coder.  :cry:
CADaver
« Reply #19 on: February 03, 2005, 07:45:05 PM »
Quote from: AfricaAD
Neither am I.  I used the dreaded
(command...Built the shape with PLINE, then EXTRUDEd it, then BLOCKed it.
