Author Topic: New PlotSettings exists but doesn't show in PageSetup Window.  (Read 2103 times)
VB_AutoCad_Guy
My new PageSetup doesn't show in the Pagesetup dialog.
Please help.... I don't know where I'm going wrong.
I can find it using:
But the code in the second section doesn't work properly.
<CommandMethod("its")> _
    Public Sub IteratePage()
        '' Get the current document and database, and start a transaction
        Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
        Dim acCurDb As Database = acDoc.Database
        Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
            '' This example returns the PageSetup table for the current database
            Dim acPltDic As DBDictionary
            Dim acPltDicEntry As DBDictionaryEntry
            Dim acPageSetup As PlotSettings
            Dim PL1 As PlotSettings = New PlotSettings(True)
            PL1.PlotSettingsName = "X"
            acPltDic = acTrans.GetObject(acCurDb.PlotSettingsDictionaryId, _
                                               OpenMode.ForRead)
            '' Step through the PageSetup table and print each PageSetup name
            Dim objId As ObjectId
            For Each acPltDicEntry In acPltDic
                MsgBox("Key: " & acPltDicEntry.Key)
                'Get PageSetup
                objId = acPltDic.GetAt(acPltDicEntry.Key)
                acPageSetup = objId.GetObject(OpenMode.ForRead)
                MsgBox("Pagesetup: " & acPageSetup.PlotSettingsName)
            Next
            '' Dispose of the transaction
        End Using
    End Sub
    <CommandMethod("aps")> _
Public Sub AddPlotSetting_DOTNET()
        'TODO: Finish Cleaning Print Function
        Dim s_PlotSettingsFile As String = "C:\TEST.dwg"
        Dim s_PageSetupName As String = "catdog"
        Dim s_MediaName As String = "11 x 17"
        Dim s_PlotDeviceName As String = "\\rdops1\RDO0071"
        Dim s_StyleSheetName As String = "Monochrome.ctb"
        Dim d_PaperHeight As Double = 11
        Dim d_PaperWidth As Double = 17
        Dim is_PlotStyles As Boolean = True
        Dim int_PlotRotation As PlotRotation = PlotRotation.Degrees000
        Dim int_PlotType As Autodesk.AutoCAD.DatabaseServices.PlotType = Autodesk.AutoCAD.DatabaseServices.PlotType.Extents
        Dim int_StandardScale As Integer = StdScaleType.ScaleToFit
        Dim is_PlotCentered As Boolean = True
        Dim myPoint As New Autodesk.AutoCAD.Geometry.Point2d(0, 0)
        Dim CurrentDatabase As Database = Application.DocumentManager.MdiActiveDocument.Database
        Using currentTransaction As Transaction = CurrentDatabase.TransactionManager.StartTransaction
            '' Reference the Layout Manager
            Dim acLayoutMgr As LayoutManager
            acLayoutMgr = LayoutManager.Current
            ed.WriteMessage("Current Layout: " & acLayoutMgr.CurrentLayout)
            '' Get the current layout
            Dim acLayout As Layout
            acLayout = currentTransaction.GetObject(acLayoutMgr.GetLayoutId(acLayoutMgr.CurrentLayout), _
                                               OpenMode.ForRead)
            'TODO: Confirm New Print Object is Created
            'Create PlotSetting
            Dim pl As PlotSettings = New PlotSettings(acLayout.ModelType)
            pl.CopyFrom(acLayout)
            Dim plinfo As PlotInfo = New PlotInfo
            plinfo.Layout = acLayout.ObjectId
            'Create PlotSettingsValidator
            Dim psv As PlotSettingsValidator = PlotSettingsValidator.Current
            psv.RefreshLists(pl)
            'Set Plot Type
            psv.SetPlotType(pl, Autodesk.AutoCAD.DatabaseServices.PlotType.Extents)
            'set plot scale
            psv.SetUseStandardScale(pl, True)
            psv.SetStdScaleType(pl, StdScaleType.ScaleToFit)
            'Center the plot
            psv.SetPlotCentered(pl, True)
            'Rotation
            psv.SetPlotRotation(pl, PlotRotation.Degrees000)
            psv.SetPlotOrigin(pl, myPoint)
            'Set Media Size
            psv.SetCanonicalMediaName(pl, "Letter")
            'TODO: Validate StyleSheetName
            psv.SetCurrentStyleSheet(pl, s_StyleSheetName)
            '' Set the plot device to use
            psv.SetPlotConfigurationName(pl, s_PlotDeviceName, "Letter")
            'Make Default PageSetup Yes/No?
            'psv.SetDefaultPlotConfig(pl)
            'Set the PageSetup Name
            pl.PlotSettingsName = s_PageSetupName
            pl.PlotHidden = False
            MsgBox("Resident: " & pl.IsTransactionResident)
            'Add to Plot Settings to Drawing Database
            pl.AddToPlotSettingsDictionary(CurrentDatabase)
            currentTransaction.Commit()
        End Using
    End Sub
