HI LEE
your lisp is good. can you develope it more? ex.: your lisp creat some layers, which have " EL_COMPONENTS" layer.... i sett it's lineweight 0.3... and Color 2... If my old draw existed layer " EL_COMPONENTS", your lisp not effect to " EL_COMPONENTS". Can you develop your lisp to fix this pro. When use your lisp, every layer change belong newlayer ( both color, lineweight....etc.. )
Thanks LEe again.(defun MakeLayer ( name colour linetype lineweight willplot bitflag description )
;; © Lee Mac 2010
(or (tblsearch "LAYER" name)
(entmake
(append
(list
(cons 0 "LAYER")
(cons 100 "AcDbSymbolTableRecord")
(cons 100 "AcDbLayerTableRecord")
(cons 2 name)
(cons 70 bitflag)
(cons 290 (if willplot 1 0))
(cons 6
(if (and linetype (tblsearch "LTYPE" linetype))
linetype "CONTINUOUS"
(cons 62 (if (and colour (< 0 (abs colour) 256)) colour 7))
(cons 370
(if (minusp lineweight) -3
(fix
(* 100
(if (and lineweight (<= 0.0 lineweight 2.11)) lineweight 0.0)
(if description
(list
(list -3
(list "AcAecLayerStandard" (cons 1000 "") (cons 1000 description))
(defun c:norlays nil (vl-load-com)
;; © Lee Mac 2010
;; Specifications:
;; Description Data Type Remarks
;; Layer Name STRING Only standard chars allowed
;; Layer Colour INTEGER may be nil, -ve for Layer Off, Colour < 256
;; Layer Linetype STRING may be nil, If not loaded, CONTINUOUS.
;; Layer Lineweight REAL may be nil, negative=Default, otherwise 0 <= x <= 2.11
;; Plot? BOOLEAN T = Plot Layer, nil otherwise
;; Bit Flag INTEGER 0=None, 1=Frozen, 2=Frozen in VP, 4=Locked
;; Description STRING may be nil for no description
;; Function will return list detailing whether layer creation is successful.
(lambda ( lst / lts ) (setq lts (vla-get-Linetypes (vla-get-ActiveDocument (vlax-get-acad-object))))
(mapcar 'cons (mapcar 'car lst)
(mapcar
(function
(lambda ( x )
(and (caddr x)
(or (tblsearch "LTYPE" (caddr x))
(vl-catch-all-apply 'vla-load (list lts (caddr x) "acad.lin"))
(apply 'MakeLayer x)
lst
; Name Colour Linetype Lineweight Plot? Bitflag Description
( "EL_COMPONENTS" 7 "CONTINUOUS" -3 T 0 nil )
( "EL_CONSTR_COMP" 1 "CONTINUOUS" -3 T 0 nil )
( "EL_FITTINGS" 4 "CONTINUOUS" -3 T 0 nil )
( "EL_LABEL" 1 "CONTINUOUS" -3 T 0 nil )
( "EL_LABEL_TXT" 252 "CONTINUOUS" -3 T 0 nil )
( "EL_TERMINALS" 1 "CONTINUOUS" -3 T 0 nil )
( "EL_TERMINALS_PE" 24 "CONTINUOUS" -3 T 0 nil )
( "EL_TERMINALS_TXT" 252 "CONTINUOUS" -3 T 0 nil )
( "EL_TXT" 252 "CONTINUOUS" -3 T 0 nil )
( "EL_WIRES" 252 "CONTINUOUS" -3 T 0 nil )
( "GE_ANNOTATION" 7 "CONTINUOUS" -3 T 0 nil )
( "GE_LABEL" 10 "CONTINUOUS" -3 T 0 nil )
( "GE_LABEL_TEXT" 253 "CONTINUOUS" -3 T 0 nil )
( "GE_TXT_LANGUAGE_DU" 252 "CONTINUOUS" -3 T 0 nil )
( "GE_TXT_LANGUAGE_EN" 252 "CONTINUOUS" -3 T 0 nil )
( "GE_TXT_LANGUAGE_FR" 252 "CONTINUOUS" -3 T 0 nil )
( "GE_TXT_LANGUAGE_GE" 252 "CONTINUOUS" -3 T 0 nil )
( "LA_HEADER_FRAME" 7 "CONTINUOUS" -3 T 0 nil )
( "LA_HEADER_TXT" 7 "CONTINUOUS" -3 T 0 nil )
( "LA_MATLIST" 254 "CONTINUOUS" -3 T 0 nil )
( "LA_MATLIST_FRAME" 254 "CONTINUOUS" -3 T 0 nil )
( "LA_MATLIST_POS" 254 "CONTINUOUS" -3 T 0 nil )
( "LA_MATLIST_TXT" 252 "CONTINUOUS" -3 T 0 nil )
( "LA_TITLE_FRAME" 7 "CONTINUOUS" -3 T 0 nil )
( "LA_TITLE_LOGO" 10 "CONTINUOUS" -3 T 0 nil )
( "LA_TITLE_LOGO_TXT" 7 "CONTINUOUS" -3 T 0 nil )
( "LA_TITLE_TXT" 7 "CONTINUOUS" -3 T 0 nil )
( "LA_VIEWPORTS" 230 "CONTINUOUS" -3 nil 0 nil )
( "PN_ACCESSORIES" 30 "CONTINUOUS" -3 T 0 nil )
( "PN_ACTUATORS" 160 "CONTINUOUS" -3 T 0 nil )
( "PN_AIR_LINE_EQUIPMENT" 40 "CONTINUOUS" -3 T 0 nil )
( "PN_BRACKET_MOUNTING" 1 "ACAD_ISO12W100" -3 T 0 nil )
( "PN_CABINET" 8 "CONTINUOUS" -3 T 0 nil )
( "PN_CABINET_DIM" 8 "CONTINUOUS" -3 T 0 nil )
( "PN_COMPONENTS" 7 "CONTINUOUS" -3 T 0 nil )
( "PN_CONDUCTS" 3 "CONTINUOUS" -3 T 0 nil )
( "PN_CONSTR_COMP" 2 "CONTINUOUS" -3 T 0 nil )
( "PN_DRAIN" 3 "HIDDEN" -3 T 0 nil )
( "PN_EXHAUST" 104 "CONTINUOUS" -3 T 0 nil )
( "PN_FITTINGS" 30 "CONTINUOUS" -3 T 0 nil )
( "PN_IDENTIFICATION" 4 "CONTINUOUS" -3 T 0 nil )
( "PN_PILOT_SUPPLY" 3 "HIDDEN" -3 T 0 nil )
( "PN_PORT_NUMBERS" 8 "CONTINUOUS" -3 T 0 nil )
( "PN_PRESSURE_SWITCHES" 200 "CONTINUOUS" -3 T 0 nil )
( "PN_PROPORTIONAL_VALVES" 226 "CONTINUOUS" -3 T 0 nil )
( "PN_SECTIONS" 3 "CONTINUOUS" -3 T 0 nil )
( "PN_SUB-BASES" 8 "ACAD_ISO12W100" -3 T 0 nil )
( "PN_SUB-BASE_CONDUCTS" 2 "CONTINUOUS" -3 T 0 nil )
( "PN_SUPPLY" 3 "CONTINUOUS" -3 T 0 nil )
( "PN_TXT" 3 "CONTINUOUS" -3 T 0 nil )
( "PN_VACUUM" 60 "CONTINUOUS" -3 T 0 nil )
( "PN_VALVES" 240 "CONTINUOUS" -3 T 0 nil )
( "PN_VALVES_OVERRIDE" 1 "CONTINUOUS" -3 T 0 nil )
