Author Topic: Help me with scale viewport  (Read 1484 times)
vnanhvu
« on: June 06, 2011, 02:38:53 AM »
When I Work With Layout. I Use Command Mview For Create A Viewport. I Use This Lisp To Modify Scale Viewport By Click On Frame Viewport. But When I Use Command Mview>object And Click Object Ex.:cirlce Or Rectang, My Lisp No Value. Thank For All
THANK FOR ALL
(defun c:WQQ(/ ent dz Viewport newVal)
  (if (/= (getvar "cvport") 1)
    (alert "\nChi co the chay tren khong gian giay (Layout).")
      (while
(not (and
       (setq ent (car (entsel "\nChon Viewport : ")))
       (if ent (= (cdr (assoc 0 (entget ent))) "VIEWPORT") )
(princ "\nkhong phai Viewport. Chon lai : ")
      (setq dz (getvar "dimzin"))
      (setvar "dimzin" 8 )
      (setq Viewport (vlax-Ename->Vla-Object ent)
    newVal (GetScale (getstring(strcat "\nNhap Scale Standard (vd. 1/50, 1:50, 50 ) <" ( getvport_scale Viewport)"> :")) ))
      (if newVal (vla-put-CustomScale Viewport newVal))
      (setvar "dimzin" dz )
(defun GetScale (Str  / Sc)
    ((/= (type Str) 'STR) nil)
    ((or (setq Pos (vl-string-search ":" Str))(setq Pos (vl-string-search "/" Str)))
     (setq Sc (vl-catch-all-apply
'(lambda () (/ (distof (substr Str 1 Pos)) (distof (substr Str (+ 2 Pos)))) ) ) ) )
    ((setq Sc (vl-catch-all-apply '(lambda () (/ 1 (distof Str))))))
  (if (vl-catch-all-error-p Sc)
    (setq Sc nil)
  Sc
(defun getvport_scale (viewport / sc csc)
  (setq sc (vla-get-StandardScale viewport))
      ((= sc acVpScaleToFit)
       (setq csc 1.0)
      ((= sc acVpCustomScale)
       (setq csc (/ 1 (vla-get-CustomScale viewport)))
       (if (= csc 0.0) (setq csc 1.0))
      ((= sc acVp1_128in_1ft) (setq csc 1536.0))
      ((= sc acVp1_64in_1ft) (setq csc 768.0))
      ((= sc acVp1_32in_1ft) (setq csc 384.0))
      ((= sc acVp1_16in_1ft) (setq csc 192.0))
      ((= sc acVp3_32in_1ft) (setq csc 128.0))
      ((= sc acVp1_8in_1ft) (setq csc 96.0))
      ((= sc acVp3_16in_1ft)(setq csc 64.0))
      ((= sc acVp1_4in_1ft) (setq csc 48.0))
      ((= sc acVp3_8in_1ft) (setq csc 32.0))
      ((= sc acVp1_2in_1ft) (setq csc 24.0))
      ((= sc acVp3_4in_1ft) (setq csc 16.0))
      ((= sc acVp1in_1ft) (setq csc 12.0))
      ((= sc acVp3in_1ft)(setq csc 4.0))
      ((= sc acVp6in_1ft)(setq csc 2.0))
      ((= sc acVp1ft_1ft)(setq csc 1.0))
      ((= sc acVp1_1) (setq csc 1.0))
      ((= sc acVp1_2) (setq csc 2.0))
      ((= sc acVp1_4) (setq csc 4.0))
      ((= sc acVp1_8) (setq csc 8.0))
      ((= sc acVp1_10) (setq csc 10.0))
      ((= sc acVp1_16) (setq csc 16.0))
      ((= sc acVp1_20) (setq csc 20.0))
      ((= sc acVp1_30) (setq csc 30.0))
      ((= sc acVp1_40) (setq csc 40.0))
      ((= sc acVp1_50) (setq csc 50.0))
      ((= sc acVp1_100)(setq csc 100.0))
      ((= sc acVp2_1) (setq csc 0.5))
      ((= sc acVp4_1) (setq csc 0.25))
      ((= sc acVp8_1) (setq csc 0.125))
      ((= sc acVp10_1) (setq csc 0.1))
      ((= sc acVp100_1) (setq csc 0.01))
  (if (member (getvar "lunits") '(1 2 3 5))
     (strcat "1:" (rtos csc ))
     (strcat (rtos (/ 12 csc) 4 5) "=" (rtos 12 4))
Tharwat
  • Hypersensitive
Re: Help me with scale viewport
« Reply #1 on: June 06, 2011, 04:00:17 AM »
Check this out ..... although the Viewports toolbar would do the trick easily .
(defun c:Test (/ vp sc)(vl-load-com)
  ; Tharwat 06. 06. 2011
  (if (and (setq vp (ssget "_:L" '((0 . "VIEWPORT"))))
           (setq sc (getdist "\n Enter scale factor for Viewport :"))
      (vla-put-CustomScale (vlax-ename->vla-object (ssname vp 0)) sc)
Tharwat
vnanhvu
« Reply #2 on: June 06, 2011, 04:15:46 AM »
hi Tharwat!
can you explain for me a question, i happy if you help.
when i use dimension annotative style, with your lisp  , my viewport is value, but dim not display. it appear only i click viewport toolbar. Why, i dont understand. What way fit ? ( ex.: i use dim annotative 1/50. it display only in viewport 1/50.BUt i use your lisp with 1/50 viewport, viewport change into 1/50 without dim. it only display when i click viewport toolbar 1/50 )
Thanks again.
Tharwat
  • Hypersensitive
« Reply #3 on: June 06, 2011, 04:35:31 AM »
I did not get your point , but if you that does not help with annotative dims , you can play with it through the Annotative Scale list .
« Reply #4 on: June 06, 2011, 11:17:14 AM »
You have to look for assoc 330 to get the viewport created from an object. Perhaps this will get you pointed in the right direction:
(defun getvport (/ e)
  (if (setq e (car (entsel)))
    (cond ((eq (cdr (assoc 0 (entget e))) "VIEWPORT") e)
  ((and (setq e (cdr (assoc 330 (entget e)))) (eq (cdr (assoc 0 (entget e))) "VIEWPORT")) e)
(getvport)
