Author Topic: AREACALC.VLX  (Read 5721 times)
fred_bock
AREACALC.VLX
« Reply #15 on: February 02, 2005, 06:03:49 AM »
this print area is a good start... but is any way that can change it to m² ???
i'm rearching for a way to calculate areas into a xls table .. or even into a cad table.... the only way i found by now is using the ADT tools...
there is a way to write at one cell to get the value of a polyline ??
Scott
AREACALC.VLX
« Reply #16 on: February 02, 2005, 09:20:16 AM »
fred_bock
I have a routine that will extract the areas of polylines to a text file.  I use it to calculate pond volumes.  Let me know if your intested.  It was written by John Kaul.  It is pretty useful to me.
Scott
CADwoman
AREACALC.VLX
« Reply #17 on: April 04, 2005, 12:53:08 PM »
Thanks, how can I edit this so that it displays SqFt when MEASUREMENT=0 and SqMeters when MEASUREMENT=1
Quote from: CADaver
Quote from: danny
CADaver,
I got this error message.  Seems like the code is missing the subroutine (TXSTLA)
AACKK ,sorry again, I missed it when I scanned for it earlier.  that's another subroutine for setting layers and styles for text.  Find the
(TXSTLA) and delete that entire line.  Today just isn't my day.
Or here's the whole dang thang agin, minus the troublesome bit.
(defun CalcAREA ()
  (setq a 0
        ss (ssget '((-4 . "<OR")(0 . "CIRCLE")(0 . "region")(0 . "*polyline")(-4 . "OR>"));;;'((0 . "*POLYLINE"))
  (if ss
      (setq n (1- (sslength ss)))
      (while (>= n 0)
        (command "_.area" "_o" (ssname ss n))
        (setq a (+ a (getvar "area"))
              n (1- n))
      ) ;;close while
     );;close progn
    (alert "\nNo Polylines selected!")
) ;;close if
) ;;close defun
(defun C:ListAREA ()
(calcarea)
(if (/= a 0)
     (alert
        (strcat "The total area of the selected object(s) is\n\n     "
        (strcat
             (rtos a 2 2) " Sq In,\nor\n        "
             (rtos (/ a 144.0) 2 2) " Sq Ft, \nor\n             "
             (rtos (cvunit a "sq in" "Acres") 2 3) " Acres")
(defun C:TAGAREA ()
(calcarea)
(if (/= a 0)
(setq str3
        (strcat
             (rtos (/ a 144.0) 2 2) " Sq Ft\\P"
             (rtos (cvunit a "sq in" "acres") 2 3) " Acres"
(setq at2  (getpoint "\nLocation for text... "))
(command "Mtext" at2 "R" "0" "J" "MC" "W" "0" str3 "")
AREACALC.VLX
« Reply #18 on: April 04, 2005, 01:34:24 PM »
I updated my area print to display meters, perhaps it will work for you.
http://www.theswamp.org/phpBB2/viewtopic.php?p=16451#16451
