Author Topic: AREACALC.VLX  (Read 5719 times)
vinnypoon
AREACALC.VLX
« on: January 31, 2005, 01:25:41 PM »
I found a nice area calculation tool last week called areacalc.vlx. The area text info is a reactor object so it update dynamically as the associated polyline changes. The only problem is that the area is in square inches not sq.ft.. Does anyone use a similar function but in sq.ft.? Thanks
AREACALC.VLX
« Reply #1 on: January 31, 2005, 01:33:07 PM »
No, I don't. Did you try contacting the author? Maybe they can change the code and give you a new version bsaed on sq.ft.
CADaver
AREACALC.VLX
« Reply #2 on: January 31, 2005, 03:03:27 PM »
(defun CalcAREA ()
  (setq a 0
        ss (ssget '((-4 . "<OR")(0 . "CIRCLE")(0 . "region")(0 . "*polyline")(-4 . "OR>"));;;'((0 . "*POLYLINE"))
  (if ss
      (setq n (1- (sslength ss)))
      (while (>= n 0)
        (command "_.area" "_o" (ssname ss n))
        (setq a (+ a (getvar "area"))
              n (1- n))
      ) ;;close while
     );;close progn
    (alert "\nNo Polylines selected!")
) ;;close if
) ;;close defun
(defun C:ListAREA ()
(calcarea)
(if (/= a 0)
     (alert
        (strcat "The total area of the selected object(s) is\n\n     "
        (strcat
             (rtos a 2 2) " Sq In,\nor\n        "
             (rtos (/ a 144.0) 2 2) " Sq Ft, \nor\n             "
             (rtos (cvunit a "sq in" "Acres") 2 3) " Acres")
(defun C:TAGAREA ()
(calcarea)
(if (/= a 0)
(setq str3
        (strcat
             (rtos (/ a 144.0) 2 2) " Sq Ft\\P"
             (rtos (cvunit a "sq in" "acres") 2 3) " Acres"
(txstla)
(setq at2  (getpoint "\nLocation for text... "))
(command "Mtext" at2 "R" "0" "J" "MC" "W" "0" str3 "")
vinnypoon
AREACALC.VLX
« Reply #3 on: January 31, 2005, 04:05:23 PM »
Yes I have contacted the author, and he is working on it. I was just wondering if anyone else already have a solution for this.
Quote from: Mark Thomas
vinnypoon
AREACALC.VLX
« Reply #4 on: January 31, 2005, 04:08:10 PM »
Thanks! However upon entering the command Calcarea, autocad returned the following msg.
Unknown command "CALCAREA".  Press F1 for help.
Quote from: CADaver
(defun CalcAREA ()
  (setq a 0
  (if ss
      (while (>= n 0)
              n (1- n))
      ) ;;close while
     );;close progn
) ;;close if
) ;;close defun
(calcarea)
(if (/= a 0)
     (alert
        (strcat
(defun C:TAGAREA ()
(calcarea)
(if (/= a 0)
(setq str3
        (strcat
(txstla)
CADaver
AREACALC.VLX
« Reply #5 on: January 31, 2005, 05:38:40 PM »
Sorry, CALCAREA is a subroutine enter the command LISTAREA or TAGAREA.
LISTAREA will pop the area up in an alert box in Sq. In., Sq.Ft., or Acres
TAGAREA will place mtext on the drawing containing the Sq.ft. and Acres.
Notice, too, that it only works for circles regions and plines.
danny
AREACALC.VLX
« Reply #6 on: January 31, 2005, 05:55:03 PM »
CADaver,
I got this error message.  Seems like the code is missing the subroutine (TXSTLA)
Command: tagarea
Select objects: 1 found
Select objects:
_.area
Specify first corner point or [Object/Add/Subtract]: _o
Select objects:
Area = 3228.8444, Perimeter = 217.1356
Command:
 no function definition: TXSTLA
; error: An error has occurred inside the *error* functionAutoCAD variable
setting rejected: "blipmode" nil
CADaver
AREACALC.VLX
« Reply #7 on: January 31, 2005, 06:01:48 PM »
Quote from: danny
CADaver,
AACKK ,sorry again, I missed it when I scanned for it earlier.  that's another subroutine for setting layers and styles for text.  Find the
(TXSTLA) and delete that entire line.  Today just isn't my day.
Or here's the whole dang thang agin, minus the troublesome bit.
(defun CalcAREA ()
  (setq a 0
  (if ss
      (while (>= n 0)
              n (1- n))
      ) ;;close while
     );;close progn
) ;;close if
) ;;close defun
(calcarea)
(if (/= a 0)
     (alert
        (strcat
(defun C:TAGAREA ()
(calcarea)
(if (/= a 0)
(setq str3
        (strcat
danny
AREACALC.VLX
« Reply #8 on: January 31, 2005, 06:12:31 PM »
Mondays...
Scott
AREACALC.VLX
« Reply #9 on: January 31, 2005, 06:51:13 PM »
Not sure where I got this, but it works well.
AAREA.LSP
(DEFUN c:aarea ()
  (SETQ    oc (GETVAR "cmdecho")
    nc (SETVAR "cmdecho" 0)
  (SETQ getobj (ENTSEL "Select object to get area of:"))
  (COMMAND "AREA" "o" getobj)
  (SETQ    sqft  (/ (GETVAR "AREA") )
    sqyds (/ sqft 9)
    acres (/ sqft 43560)
  (ALERT
    (STRCAT "\nSquare Feet = "
        (RTOS sqft 2 3)
        "\nSquare Yards = "
        (RTOS sqyds 2 3)
        "\nAcres = "
        (RTOS acres 2 3)
  (SETVAR "cmdecho" oc)
(PROMPT "To use, enter aarea at the command line.")
(PRINC)
Scott
AREACALC.VLX
« Reply #10 on: February 01, 2005, 10:27:19 AM »
Sorry about not knowing who wrote the above code.  It is most likely someone on this forum since pretty much everone here inhabited the other forum before they desided it was better to make money instead of better the education of CAD users.  Anyway, if you recognize the code, and it belongs to you, please take your credit, as credit is deserved.
vinnypoon
AREACALC.VLX
« Reply #11 on: February 01, 2005, 11:59:25 AM »
Thanks, I have this one. The one I'm looking for uses reactor base text for the area label. The area text updates automatically as the associate pline changes.
Quote from: Scott
AAREA.LSP
(DEFUN c:aarea ()
    sqyds (/ sqft 9)
  (ALERT
        (RTOS sqft 2 3)
        "\nSquare Yards = "
        (RTOS sqyds 2 3)
        "\nAcres = "
        (RTOS acres 2 3)
(PRINC)
Andrea
AREACALC.VLX
« Reply #12 on: February 01, 2005, 02:21:57 PM »
I have this....is simple...but can help.
;;command                                     ;;
;;                         PLINE AREA         ;;
;;By: AndreaLISP     sept. 2002        ;;
(defun pline_area ()
  (setvar "CMDECHO" 0 )
  (setvar "PEDITACCEPT" 1)
  (setq HVpick1 (getpoint "superficie :"))
  (setq HVpick2 (getpoint HVpick1 "\\n To..:"))
  (command "_line" HVpick1 HVpick2 "")
  (setq line1 (ssget "l"))
  (while HVpick2
    (setq HVpick1 HVpick2)
    (if (= HVpick2 nil)
   (command "_pedit" line1 "_c" "")
   (COMMAND "_AREA" "_o" "_l")
        (setq areazone (/ (GETVAR "AREA") 144))
    (setq line2 (entlast))
    (command "_pedit" line1 "_j" line2 "" "")
    (setq line1 (entlast))))
Keep smile...
danny
AREACALC.VLX
« Reply #13 on: February 01, 2005, 02:25:39 PM »
have you tried using the ADT tags.  They not only are associated to the pline, but they can be exported to a schedule.
Andrea
AREACALC.VLX
« Reply #14 on: February 01, 2005, 05:23:35 PM »
I've also found this one..in my library...
(Defun C:DAREA ()
(SETQ SS (entsel "Select Object To Get Area of:"))
(PROGN (COMMAND "_AREA" "o" SS))
(setq SqMeters (/ (SETQ Sqmm (/ (GETVAR "AREA") 1)) 1000000)) ;Change 1 to 1000 for Arch. Scale
(alert (strcat "\n Polyline Area" "\n\nSq mm's = " (rtos Sqmm 2 2) "\n Sq m's = " (rtos SqMeters 2 2))) ;put up alert box
(PRINC)
;  Print the Area of a closed polyline
(defun C:AREAPRT ()
; error function
  (defun *error* (msg)
      (not
   (member
     msg
     '("console break" "Function cancelled" "quit / exit abort")
    ) ; if
; reset variables below
;end error function
  (setq   A1 0
   A_Old 0
  (while (/= A1 nil)
    (prompt "Pick Area...")
    (command "area" "o" pause)
    (setq A1 (/ (getvar "AREA") 144)) ;convert inches to feet
    (if   (= A_Old A1)
      (EXIT)
      (Progn
   (prompt "/nPick Text Location...")
   (setq TXT (strcat (rtos A1 2 2) " Sq. Ft."))
;             Check if the drawing height is set to 0:
   (setq dwg_style (getvar "textstyle"))
   (setq styledata (tblsearch "style" dwg_style))
   (setq dwg_ht (cdr (assoc 40 styledata)))
   (if (= dwg_ht 0)
     (command "text" pause "" "0" TXT "")
;        ELSE do this
     (command "text" pause "0" TXT "")
   ) ; endif
   (setq A_Old A1)
(DEFUN c:aarea ()
sqyds (/ sqft 9)
(ALERT
(RTOS sqft 2 3)
"\nSquare Yards = "
(RTOS sqyds 2 3)
"\nAcres = "
(RTOS acres 2 3)
(PRINC)
Keep smile...
